Car Problem
Serendipity
So - I'm on my way to Lasareath's halloween party and right before we get to the Holland Tunnel to NJ the car overheats.
We pull over and when my dad opens the hood, the engine compartment is hot. Same with the vents inside the car - blowing hot air.
Wait 30 minutes with the hood open and slowly it's cooling off. Then once we decide to go again and while stuck in traffic the same thing happens.
Decided that I'm not going to make it to the party so we head back to Queens slowly with the fan turned to HI to cool the engine off. Finally I make it back home safely.
What could be wrong?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Stuck thermostat or the water pump went out. no biggie those are easy fix's/
Shannon.50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
Not knowing the car, it sounds like the thermostat stuck.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Fan clutch if it has a manual fan, or electric fan not turning on?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
How do you determine if the thermostat is bad? I looked at the car and there is coolant in the reservoir, and also the electric fan is spinning.
Aside from that, I don't know much about cars.polkaudio RT35 Bookshelves
What kind of car is it?
How many fans does it have? I'm assuming only one, so if it's turning, that's good.
And you have coolant in the reservoir, that's good. Once it's cooled off...MAKE SURE IT'S NOT HOT...take the cap off the radiator and make sure you can see coolant in there.
I'm not sure how you could tell if the thermostat is stuck...
...nor how to tell if the water pump's not working...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Squeeze the top radiator hose when the car is hot if the hose feels like there is pressure on it then its not stuck but if you can collapse it and it feels empty then its stuck! also while the car is cooled off take the radiator cap and let the car run and shine a flashlight inside the radiator to see if you can see water circulating inside it. If you cant see any movement after the car warms up rule out the thermostat then you can almost bet its the water pump! Good luck if you need to I could pm you my Phone number to try and walk you though diagnosing this. Also I'm glad to try and help but doing it over the phone or just not being there is Tough..
Shannon "RSP"50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
I would say the radiator could also be plugged up.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
The least expensive thing to try first is the T-stat. Pick up a new one and a service amnual at your favorite parts store and get busy learnin'. Don't forget to grab some Right Stuff RTV, a new gasket, and some fresh anti-freeze.
Don't drive it till ya fix it, you may warp the aluminum head. -
Thanks, I wanted to go to Lasareath's party but I didn't think it would be good to drive until it's fixed.
P.S. to Lasareath - I'm sorry that I couldn't make it to your party.polkaudio RT35 Bookshelves
audiobliss wrote: »How many fans does it have? I'm assuming only one, so if it's turning, that's good.
I really don't know how many fans, but I do know that ONE of them works.
I have coolant in the reservoir but it's over MAX. It's a little higher than before, but not by much. I don't ever recall it being so high though.
Car is still cooling down.polkaudio RT35 Bookshelves
Well, if the coolant gets really hot, it expands, and it'll flow into the reservoir tank, so that's why it's so full.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »Well, if the coolant gets really hot, it expands, and it'll flow into the reservoir tank, so that's why it's so full.
I can understand that. I remember the level used to rise after running the car, but it was never THIS high before.polkaudio RT35 Bookshelves
How come I wasn't invited to Lasareath's party?The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Attached is a picture of the coolant level. It's much higher than I have ever seen before, and over the MAX mark.
Does this tell you what's wrong?polkaudio RT35 Bookshelves
Yes. That your car overheated. Funny that. We already knew that.
The coolant level has increased because it overheated. I don't think you can say anything else from that. It's just what happens.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »The coolant level has increased because it overheated. I don't think you can say anything else from that. It's just what happens.
I was hoping that it would indicate/point to whatever was causing the problem.
The only thing I know is that low coolant indicates a leak somewhere...polkaudio RT35 Bookshelves
Also, this is the fan that I said was working. Am I supposed to look for another fan?polkaudio RT35 Bookshelves
No, if there were another fan, it'd be right there right beside that one and very visible. If you only see one, there's only one. Some cars have one, some two, and some three. My Jeep has two.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »No, if there were another fan, it'd be right there right beside that one and very visible. If you only see one, there's only one. Some cars have one, some two, and some three. My Jeep has two.
Nothing beside that one.
So - from what I hear it could be a thermostat, water pump, or radiator hose?
Just trying to narrow things down.
Thanks for all your help so far!polkaudio RT35 Bookshelves
I'm going with the thermostat too. My personal car expert is not here at the moment(son #1). He knows this stuff like nobody's business."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
From what I can see, it could be:
thermostat
water pump
stopped up radiator
I don't think a radiator hose would be the problem. Shannon was saying check the pressure in a radiator hose to check to see if the thermostat is working or not. The radiator hose is good if it's not leaking.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »I don't think a radiator hose would be the problem. Shannon was saying check the pressure in a radiator hose to check to see if the thermostat is working or not. The radiator hose is good if it's not leaking.
I misunderstood what she said. Will check the pressure once the engine compartment has cooled down a bit.
AFAIK, the radiator hose is not leaking.polkaudio RT35 Bookshelves
Yeah, probably not. If it were leaking, then you wouldn't have as much coolant, which means it would still have overheated, but I don't know if there would be enough coolant left to fill up the overflow reservoir like that. If no coolant's dripping, then you probably don't have a leak.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Sounds like your car has a problem. My suggestion is to fix it.
Yeah, and you're sober?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »Yeah, probably not. If it were leaking, then you wouldn't have as much coolant, which means it would still have overheated, but I don't know if there would be enough coolant left to fill up the overflow reservoir like that. If no coolant's dripping, then you probably don't have a leak.
That's a good thing, that there's no coolant leaking then.
Rant: On a side note, first it's PC problems and then this. Everything's been going belly up around here and it's really frustrating.polkaudio RT35 Bookshelves
Just don't try listening to music. Next you'll blow those beautiful speakers Trey sweat so much over! :eek:
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
BaggedLancer wrote: »Sounds like your car has a problem. My suggestion is to fix it.
I think we've established that already...polkaudio RT35 Bookshelves
