Teflon and Polystyrene Capacitors In SDA Speakers.
ka7niq
ka7niq Posts: 577
edited October 2007 in Vintage Speakers
I read with some interest a recommendation against the installation of Teflon or Polystyrene capacitors in Polk SDA and SRS Speakers.
The person advising against using these caps said he talked to someone in Polk Engineering.
He says Polk Engineering advised against the use of these caps, because they are too "fast".
This person instead suggests the use of Solen "fast caps". http://www.solen.ca/caps/mkp3.htm
This did not play well with me, and so I decided to go to Polks Head Engineer with the question.
God forbid, dont want to use "too fast" a cap, LOL
Don't want my electrons to get a "speeding ticket" ?
Here is what I found out, for the SDA and SRS Replacement Crossover Capacitor Knowledge Base.
I just made a call to Brad Starobin at Polk.
Here is what he said about capacitors.
He felt electrolytic are fine bypassed with Mylar for lower end product.
Polks better speakers use all Mylar or film he said.
I point blank just asked him about NOT using Teflon or Polystyrene as Dark Knight suggests. :confused:
He said Teflon and Polystyrene are excellent caps with increased transparency and smoothness in the top end. :)
He said it would be fine to use them, but they are expensive. :(
You may verify my call to Brad if you wish.
I told him I was from the Polk forum, and my name is Chris.
Post edited by ka7niq on
«13
    heiney9 Posts: 25,402
    edited October 2007
    HOLY BAT CRAP, you just don't give up :eek: .
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2007
    Masochism is a strange sickness. You need help, though I'm sure you know that.
    How many threads do we need to shut down here????????????
    SOPA
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    heiney9 wrote: »
    Just adding MY findings to the SDA Database Heiny.
    edited October 2007
    ka7niq wrote: »
    Again I ask, what's your point other than to discredit a person who has done years of research, experimenting and talked with engineers from Polk in order to update and in many instances make the vintage SDA speaker an even better sounding and performing speaker than when it was introduced.
    Pathetic.
    When exactly did you install Teflon and Poystyrene caps in your 1 oand only pair of very recently aquired SDA's. DK has more working knowledge about SDA's than you can ever hope to have.
    edited October 2007
    ka7niq wrote: »
    They aren't your findings it was told to you.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited October 2007
    ka7niq wrote: »
    Ka7niq,
    It is not clear from your post if Brad Starobin is explicitly saying that it is ok to use teflon and polystyrene caps in SDA's. According to your quote, Brad mentions that they use mylar film and electrolytics in Polk's current speakers. The advice I received in 1990 against using polystyrene and teflon caps was specific to SDA's.
    Please call Polk engineering again and clarify with Brad if he recommends the use of polystyrene and teflon capacitors in SDA loudspeakers. Better yet, ask Brad to post his response here in the forum.
    If indeed, polystyrene and teflon caps can be used in SDA's, it would be good information to know and I will certainly incorporate it in any future SDA modifications. I may even go back and retrofit my current SDA collection. Thanks.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    So Sollen caps are bad?
    Im sorry but Im alittle lost here (which in all rights, I should be, as alot of us are), but...
    Is what Brad said ..good or bad?????
    is this a follow up on the post you wrote about talking to someone about keeping the excact same caps in a xover? Not changing caps out, to diffrent types?
    ...I hate watching a debate and not knowing what is about....
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • avguytx
    avguytx Posts: 1,628
    edited October 2007
    OMG....another worthless post started.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
    billbillw Posts: 7,458
    edited October 2007
  • shadowofnight
    shadowofnight Posts: 2,735
    edited October 2007
    billbillw wrote: »
    The first rule of Fight Club is you don't talk about Fight Club
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Yes, it was told to me by Polks chief engineer.
    But Heiny, know that I am no stranger to speakers.
    I have used Teflon bypass and Polystyrene, as well as paper/oil, motor start, etc, etc.
    DarqueKnight, who publishes the SDA Compendium, recommends against the Teflon and Polystyrene Caps.
    Someone could read and follow this SDA Compendium suggestion, and possibly deny themselves the transparency made possible by these fine capacitors.
    DarqueKnights suggestions came about because of a conversation with a Polk engineering employee, not Polks chief engineer.
    I just wanted to be see what Polks chief engineer had to say about this controversy.
    Like I have always said, when you publish opinions, you leave yourself open to counter ones.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Teflon works great!!!!
    Polystyrene?...Hmmmmm....I always had a problem with my eggs sticking...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited October 2007
    ka7niq wrote: »
    Yep you've pontificated about your self procalimed knowledge about all things audio for appox 250 or your 500 posts since joining. We all know what you think you know!!!
    The only controversy is the one inside your deluded head.
    I'm sure the underling's (engineers) are no match for the Chief. Thank god you went right to the top to figure this one out. The knowledge you have uncovered is invaluable...............thank you Oh Great Special K.
    Of course nothing has changed in 17 years since DK inquired.:rolleyes:
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    heiney9 wrote: »
    I laughed so hard...I just farted....:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    jakelm wrote: »
    So Solen caps are bad?
    Im sorry but Im a little lost here (which in all rights, I should be, as a lot of us are), but...
    is this a follow up on the post you wrote about talking to someone about keeping the exact same caps in a xover? Not changing caps out, to different types?
    No, Solen caps are not bad.
    What Brad Starobin said is not bad.
    It does contradict what Darkknight said though.
    Perhaps Darkknight may want to rethink his position on these caps, that is all.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2007
    OMG, Why doesn't it stop. I have a dog like this. You take his toy and put it up on a shelf and all night long he will stare at the shelf.
    Give me the toy, give me the toy.
    K please just give it up. And it does not contradict what DK said at all. It is just another opinion. You are nobodies Daddy on this one so for the love of all that is holy stop, PLEASE!
    Man like a headache that you can't get rid of. Start a fight somewhere else Special K......................
  • Poee7R
    Poee7R Posts: 906
    edited October 2007
    ka7niq wrote: »
    My counter opinion is that you're an ****.
    Dave
    Once again we meet at last.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Ka7niq,
    Brad did make a distinction between high end and lower end product.
    He said he felt that electrolytics with a mylar bypass were good enough for lower end product.
    He prefers film caps for the higher end stuff like the LSI's.
    I did not mention SDA speakers as such.
    Since you know more about Polk speakers then I do, is there something special about the SDA Speakers ?
    They just seem like Polks to me with extra dimensional drivers, some progressive line source stuff, etc.
    The drivers seem to be used in other Polks, but I may be wrong ?
    Brad did not say this, but I take his suggestions to include the SDA Speakers when he spoke of "higher end product".
    How about you or I email him, and ask if I can post his response in the forum ?
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Joe08867 wrote: »
    No one is starting any fights but you.
    If you don't like reading my posts, please ignore them, move on to another thread.
    Don't you realize by now I do not care what you or anyone thinks.
    I just keep on keeping on.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    heiney9 wrote: »
    It has now :)
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    Disregard.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    jakelm wrote: »
    Here is an interesting read I Googled.
    Capacitors DO make an audible difference !
    Electolytic and tantalum capacitors have very poor audio characteristics and should not be used in the audio signal path. Replacing electrolytic capacitors in the audio signal path of your amplifier or preamp with film capacitors will improve sound quality. Polyester (Mylar) capacitors make a significant sound improvement and are the minimum quality audio capacitors that should be used in the audio signal path. Better are polypropylene capacitors, and even better are polycarbonate capacitors when available. Polycarbonate film used to make polycarbonate film capacitors has been discontinued for several years, only a few companies have remaining stocks of polycarbonate film which is expected to be exhausted in the next year or two. Polycarbonate film capacitors are preferred to polypropylene capacitors when available because they have a very balanced, musical sound with very little coloration. Polystyrene (also called styrene, styroflex, or styrol) are in many areas superior to polycarbonate, and are mostly new old stock as are our polystyrene, the polystyrene film has needed for manufacture of Polystyrene capacitors has not been made for years. The very best audio capacitors are polytetrafluorethylene (Teflon) capacitors, but they are generally very, very expensive and available in only a relatively few sizes.
  • Face
    Face Posts: 14,340
    edited October 2007
    Hmm..you say caps make a difference but cables don't? :rolleyes:
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited October 2007
    billbillw wrote: »
    That horse looks dead......:confused::confused:
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    So the Solen Polyproylene is better than the electrolytic, that I replaced in my 7's xover?
    But not better than the older Maylar, that I replaced as well?
    http://www.partsexpress.com/solen-metallized-polypropylene-capacitors.cfm
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited October 2007
    steveinaz wrote: »
    Come on guys, give it a break. I saw absolutley nothing wrong with Ka's post. Is this not an "audio" forum? Let the man talk.
    +100%
    Actually, this thread was, imho, one of the worst ones he started as it called out DK, but then DK kind of did the same thing. Personally, I'd like to hear what he has to say and confirm and refute it based on fact and personal experiences and not just name calling. If he has half the experience he says, it should be a little more interesting than the typical drivel that the forum puts out.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
    edited October 2007
    steveinaz wrote: »
    He called DK out and he went back and edited his post to make it look like he was just matter-of-fact inquiring. That was the reason for my post, not to persecute the guy.
    If he had just made the statement without trying to discredit DK none of this controversy would exist. But he keeps lobing them up there people are going to keep smacking them out of the park.
  • steveinaz
    edited October 2007
    H9, I noticed the slight jab as well, but DK took the high road--I think we can too.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    So its .....
    Best to worse in audio signal
    Teflon
    Polypropylene
    Maylar
    Electrolytic
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • polktiger
    polktiger Posts: 556
    edited October 2007
    I will admit to not knowing much, but I do have a question for this thread...
    How long has the chief engineer, Brad, been with Polk? Since Polk has not really sold any SDAs in many years, has he actually been involved in active engineering of the SDA speakers?
    Maybe Brad has been there for 20 years and knows all about SDAs in intricate detail. But he may actually not be intimately familiar with all the engineering of a speaker he no longer sells. (Actually, I hope he spends all his time on current models and not SDAs unless they are planning to reissue the SDA.) By comparison, I doubt NASA's cheif engineer can give you detailed engineering specs of the Apollo lunar landing modual since the project has been dead for many years
