SVS 25-31 PC Plus vs. DIY Sub
  • engtaz
    engtaz Posts: 7,671
    edited October 2007
    Solid walls make a big difference.
    engtaz
    engtaz
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    Music Joe wrote: »
    My uneducated guess is, the upper floor is more like a typical box, playing in sympathy to the sub on all 6 sides, whereas basements tend to have 5 very solid sides plus a sturdier roof too.It should take some serious power to get a basement singing.
    Probably the case.
    Although it takes quite a bit of power to fill up my basement, I have my sub set flat, so it's not running out of power or anything.
    The sub sounds really good in the basement.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • engtaz
    engtaz Posts: 7,671
    edited October 2007
    The dreaded Bose 901's have had problems in rooms without solid walls. The reflexions were messed up if the walls were not solid.
    engtaz
    engtaz
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    engtaz wrote: »
    engtaz
    Maybe this is why Levinson has a concrete bunker for a listening room, according to a high end dealer ?
  • Serendipity
    edited October 2007
    engtaz wrote: »
    engtaz
    Interesting - my Def Techs are bipolar; although they are not exactly Bose 901s, they do depend on room acoustics...
  • engtaz
    engtaz Posts: 7,671
    edited October 2007
    when I said messed up, I meant there absorbed instead of reflexed off the walls.
    Kind of mushy.
    Does that make since? (long day)
    engtaz
    engtaz
