Is it possible to fix dented dust caps?
Phasearray
Suppose some idiot(such as I) got a screw driver too close to the dust cap and the resulting magntic field pulls the screw driver into the dust cap causing the entire thing to dent inwards. Is there a way to pull it back out?
Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340
Post edited by Phasearray on
i've heard you can use a needle to make a small hole in the middle of it. Then take a paper clip type object to pull it out. Never done it myself though...
Use the cardboard on an empty paper towel role and put it on top of the dome, then suck the air out with your mouth. It worked like a charm for me.
omg genius. Imma try thisReceiver - Onkyo HT-R340
Subwoofer - Onkyo SKW-340 -
Wrap some tape around your fingers and pull out the dent.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
The 6503 dust caps don't work with tape but the mid's in my 3.1's dust caps do work with their dust caps. 6503 are more cloth like then the mids in the 3.1's are more plastic like.engtaz
I've done this and it worked like a charm. Needle-method should reserved for very stubborn dents. I'd sure like to see a jpg image of a girl using the paper-towel-roll vacuum method. Tape method may or may not work. Definitely worth a try though. -
a needle hole won't affect the performance? anything with "poke hole" and "speaker" in the same sentence scares me. . . probably just flashbacks to newbie threads about adding ports to speakers and such.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Phasearray-
So did you resolve the problem or what? -
Real easy... Use a vaccuum hose, make sure you partially cover the end of the hose with your fingers... you dont want to rip the dust cap off. Ive done it a few times with no problems. I definitely wouldnt poke a hole with a pin.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
I second the vacuum hose, super easy and quick.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
I've gotten the vacuum method to work, and also blue tack on the tip of a pen (sort like the duct tape/ finger solution). Never tried the needle point...Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Phasearray-
nope...Guess the needle is nextReceiver - Onkyo HT-R340
dang actually this method fixed the big ding. The smaller dent caused by some idiot(most likely me) who used glue(super glue, bad idea) has made the dent probably so hard it will never pop back into place.Receiver - Onkyo HT-R340
I have a dented 6511. I tried the tape method with no success. I will try the vacuum cleaner but the cap looks like it is cloth and air will pull through it.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
The needle works great for stubborn/ridged dust caps. I also notice no sound difference from the tiny pin hole, but I'm sure someone will debate me on that...
It is actually a mid bass driver. I pulled it out but I ended up with a very slight tear in the dust cap.
ScottCould you post a pic of that tweeter? If you have removed it, could you also post a pic of the back?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
If it's a vented dust cap(some air can pass through), I don't see putting a tiny hole in it being a issue besides aesthetics. I can see a problem only if it's a sealed cap, and even then, it may not be noticeable."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I used to use the paper clip trick on car audio subs back before everyone went to inverted/molded in dust caps. I figured if they were stupid enough to have them in the back of their car with crap rolling around to dent it, then a little whole in it wouldn't matter. It was a car sub...who cared. lol
Of course, you can always put a tiny dab of glue on the pin hole and it will seal it back up.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner. -
Use a duck tape it works for me.Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
GAH! The word is DUCT not duck! It's tape that is used to secure two piece of DUCTing together. Usually the DUCTing is made or aluminum or galvanized steel hence the silver color of the DUCT tape so as to be aesthetically pleasing and maybe mask the presence of your handiwork.
The tape, while good for many purposes, does surprisingly poorly at securing two water fowl together.Expert Moron Extraordinaire
I have duck tape, when I ask my son to get me the grey tape I get it thrown at me. So I named it duck tape.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Duck tape is the best tape:
http://www.duckproducts.com/ -
Sorry guys I misspelled it, but it really works.Front: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
Actually, Duck Tape is a real product.
Yeah and it's a BRAND name not the actual name of the tape. Anything you see from Duck Tape has a registered trademark next to the "Duck".Expert Moron Extraordinaire
+1 got the paper tube idea, fixed the dented cone on a project speaker i'm working on the first shot!Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Polk PSW-350 Sub -in storage.
Yamaha RX-V681 A/V Reciever
Sony SCD-CE595 SACD Player -
try the vacuum methodFronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
Bubblegum, worked for me.
Vacuum did not work, gaff tape did not work, sticky anything did not work. Only the small pin hole and paper clip worked for me. Very stubborn dust caps.
