My Money Pit
I would think it may be best to start over with that wall / area, so a temp wall stud wise built to support the house on the side of that damaged wall about a 1' away, while the work is done.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Vr3MxStyler2k3 wrote: »2x6 for studs, jesus h christ.
They sure do build them up in Flordia -- but I guess you got to eh...
Well it should be CBS but right now there is a hurricane on the horizon and all that is between it am me is rotted plywood with a little stucco.:eek:Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Yeah, I would not live in a wooden house in Flordia...
I'd want a bomb shelter with a pretty picture covering it.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
disneyjoe7 wrote: »I would think it may be best to start over with that wall / area, so a temp wall stud wise built to support the house on the side of that damaged wall about a 1' away, while the work is done.
I am sure I can't afford that though. Does anyone have any idea what the gamut of repairs could cost? Right now I just have my Jack of All Trades guy and that's it.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Vr3MxStyler2k3 wrote: »Yeah, I would not live in a wooden house in Flordia...
If I had known it wasn't CBS I would not have bought it. Thankfully that's the only part of the house that is not but it's the weakest link.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Cool, you are one step ahead of me. Throw out all of the insulation if you haven't already. If you have a fan(s) to help speed the drying process, by all means please run all that you have, constantly for about three days, or until dry.
I'd like to ask you a question about picture #5, the photo of the outside. I can't tell exactly, but from what I see, it looks like the window ledge is not angled correctly. It may be a camera/sight (mine) issue, but it looks to me as if the rain water is being run toward the window and not away from the window. Is this the case?
I will also need to know more detail as to when the last coat of paint was applied to both the exterior and the interior, to the best of your recollection/knowledge. Also, what kind of roofing material are you using and is there a vent, chimney, or anything else protruding from the roof line within 15 feet from the edge of the roof line paralleling where the water damage exposed so far? A picture of the roof top [if obtainable] would help me as well.
Now, I have to be honest, you may think it's not an issue from up there. I could not blame you, but my experience tells me otherwise. I just want to examine all possible avenues because I have seen so many times where folks have rebuilt before actually finding the source of the leak, only to repair the repair two or three times. That's usually when I get called in.
That's all the questions I have for now. You are doing fine and are on track to getting the house back to normal. Once we have located the leak, performed some tests and dried the wood out, then we can start working on the smell. That's the easy part.
I have your back and I will not let you down. Cheer up, it's not all that bad, for I have seen WAY, WAY WAY worse. We'll find the source of the leak, we'll fix it, and then you can go back to enjoying a game of pool whilst listening to good tunes in a pad that don't stink. OK?;)~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I love the smell of mold in the morning........Smells like my first barracks room. :eek:
Hold on for just a teenie, weenie little bit, please. As soon as we get some more pic's / info. I can give you a "rough" estimate. I don't want to blow smoke up your **** until we know what we are dealing with.wingnut4772 wrote:Does anyone have any idea what the gamut of repairs could cost?
First goal. Find the leak(s).
Second goal. Assess the damage.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Do you have a neighbor that you could borrow a pressure washer from?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
This does ot look too bad. I went through two floods in a house that saw at least three. Lots of rotten stuff and mold but with a little time and some thinking I was able to fix most of it myself.
I thinK T3 can walk you throught it. Hang in there and don't give up! -
Thank you so much treitz....
The sill is angled slightly down so that's ok.
The roof is new. Over the HT is a flat roof and it was done in March of '06 as well as the the rest of the roof which is shingled (3 tab). That was my first suspicion and the roofing co. checked it and said all was ok. They were the ones who suggested the windows. It has a 10 year warranty though.
The house was newly painted in 2005.
The smell is mostly that wet, yucky wood smell with a fine bouquet of mildew (yum) so if that can really go bye bye that will be amazing.:D
My Handyguy is returning on Friday to drywall but I told him about the rotting wood and he said he would have to look at it. He works for Habitat for Humanity building homes but I don't know the extent of his skill level. He did put in the ceiling and do the HT wiring in that room though.
Edit:It just rained but I see some standing H2o on the roof. That ugly mess around the window is new sealant of some type.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Thanks. We did the ole' hose at the window bit' and saw that the water was mainly coming in at the center where there is a join of some sort down the middle. This was consistent with each window for damage. The really bad corner may also be suffering from standing water from the outside as it rained today and I noticed that the water just pools up outside that corner after the gutter dumps it.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
It seems as if you are one step ahead of me every step of the way. Too cool.
Alright, first off cancel the drywall repair. There is no sense in fixing something that's not repaired. That said, standing water on a pitched roof is red flag number one. The roofing company needs to do what they need to do to correct that issue. If they won't, there are some options that are cost effective, but won't be pretty to the eye and will not be a permanent repair. Try what you can with the roofing company and in the meantime, if you can have another company come and give you an estimate on what it would cost to have no standing water anywhere in that area, it would be helpful to you. Did the roofing company [if you have that info.] offer a warrantee of any sort?
Now, what I would suggest is to go to Home Depot, or your local hardware store and get a product called caulk remover. Follow the instructions and remove all of the caulk on the outside that the photo you provided shows that has been installed on the lower areas of the windows. This will not be an easy task. It might be, but I'm not betting on it.
We can take care of that smell in just a couple of days. I'm sorry, but you don't want to do anything about that for now, besides candles, incense or Air Wicks. Trust me, I know that smell, and I know you don't like it. Give it a couple of days and it will be gone forever. K?
I have one more suspect area that you can help me out with. That is the sliding door. Can you provide pic's of the entire area as to where the door meets the stucco, also the threshold (or the bottom of the sliding doors). I know this may sound ridiculous, but can you provide a pic with the camera as far down to the outside pavement/concrete/tile/whatever directly underneath the threshold?
Now, as far as the interior paint is concerned. Do you notice a "water mark" anywhere around the window whatsoever? The tell-tale sign would be a brown "ring" [in no particular pattern], if you will that discolors the paint from it's original color. Do you notice a watermark anywhere else within the confines of that wall/adjoining areas?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Good job Treitz, you seem to be all over thisThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Yes . I have a ten year warranty and I think they will honor it as they came out pretty quickly when I called.treitz3 wrote:Did the roofing company [if you have that info.] offer a warrantee of any sort?
Handy Guy (fernando) just did this Monday...still do it?treitz3 wrote:Follow the instructions and remove all of the caulk on the outside that the photo you provided shows that has been installed on the lower areas of the windows. This will not be an easy task. It might be, but I'm not betting on it.
No.I haven't. I will look outside tomorrow to see but I forgot to tell you the whole house was repainted about 18 months ago or so.treitz3 wrote:Now, as far as the interior paint is concerned. Do you notice a "water mark" anywhere around the window whatsoever? The tell-tale sign would be a brown "ring" [in no particular pattern], if you will that discolors the paint from it's original color. Do you notice a watermark anywhere else within the confines of that wall/adjoining areas?
Here are some more door pics. A huge culprit I have no doubt from the damage.
The roof over the HT is a flat roof but I am guessing standing water is still a no-no.....right?treitz3 wrote:That said, standing water on a pitched roof is red flag number one. The roofing company needs to do what they need to do to correct that issue.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Have the roofing company honor the warrantee. No standing water, period.
Handy guy....yes, have him remove the silicone.
18 mos? That's a good sign...damn good sign.
Now, for the threshold. Can you see underneath it? You'll have to wait for tomorrow to see in the daylight, but just for **** and giggles, try taking a flat head screwdriver and see if you can "poke" a hole all the way thru to the inside. Try this every 1/4" or so, at different angles. Try it like your life depended on it.
Can you lift the threshold up from the outside? If so, how much does it move up and down?
As for the gutter outlet, go get a product that channels the rain AWAY from the foundation, no matter what product it is.
Just out of curiosity, is your house on that side lower than the yard? Don't panic, just curious.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Plastic extenders can be used to get the water as far away from the corner as you need to. Downspouts that just dump into a pool of water at your foundation are trouble, especially when it's so easy to fix. -
Actually yes. I think so.(panic)treitz3 wrote:Just out of curiosity, is your house on that side lower than the yard? Don't panic, just curious.treitz3 wrote:Now, for the threshold. Can you see underneath it? You'll have to wait for tomorrow to see in the daylight, but just for **** and giggles, try taking a flat head screwdriver and see if you can "poke" a hole all the way thru to the inside. Try this every 1/4" or so, at different angles. Try it like your life depended on it.
No. I can't see all the way through. there is a seal on the inside. I can insert a metal ruler under it about 5 inches in two spots towards the middle but the rest is sealed.(on the outside) Something stops it from poking through to the inside. The threshhold will raise about 1/4 inch or so if I pry - in those spots .Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
OK, the sliding door is an issue, but one that can wait. Plan your finances in the future not on replacing the door, but having someone who knows WTF they are doing remove the entire lower assembly of the door frame [if possible], repairing the substrate that the threshold is mounted to, sealing and re-installing.
Don't panic. Let's take a look at what you have around that side of the house. Provide us with a pic of that wall and corners, concentrating on the ground and where it meets the foundation.
As Mr. Bob Marley would say........."Don't worry, be happy".;)
Hold on, from that pic I take it that you are taking the ruler and poking the ruler to the outside? 5 inches?:eek:wingnut4772 wrote:Something stops it from poking through to the inside.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
No. From the outside to the inside. Ha that would be a severe :eek:
I do think that we might want to get new windows if we do this and maybe a new door if we can swing it ...depending on how much that can be. At least the windows. Some don't even open because the latches have snapped off.
I will take pics of that wall in the daylight. The main thing I noticed is that the further away from the problem window spots and the door...the dryer things are. Do I have to remove the rest of the drywall..if I see it's looking dry?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Just from reading this thread, it makes me happy to be apart of the crew. Hope you get everything worked out Darla and get back to the HT/Audio enjoyment side of things. Treitz, excellent support in helping her out, you seem to be very experienced and know what youre dealing with for sure. Hats off to both of you for teamwork and getting this done. If donations are needed to get Darla on track, I'm in.Shoot the jumper.....................BALLIN.............!!!!!
put extensions on the gutter downpipes, you can get them at Home Depot for cheap.
No ma'am. Go to bed. Get some sleep. Relax. It will all be OK. Besides, I'm relying on you to be sharp minded......not sleep deprived and worried.wingnut4772 wrote:Do I have to remove the rest of the drywall?
All of the interior demolition is done from what I can see. The only exception would be if you replaced the doors and windows.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Phew!!!! I am so relieved. Allthough I will admit that putting a hammer through the wall was kinda fun.sherardp wrote:Just from reading this thread, it makes me happy to be apart of the crew. Hope you get everything worked out Darla and get back to the HT/Audio enjoyment side of things. Treitz, excellent support in helping her out, you seem to be very experienced and know what youre dealing with for sure. Hats off to both of you for teamwork and getting this done
That's what makes Club Polk so great. I am really happy to be a part of such a great group of helpful people. Thanks:)
And What the hell! Since I am tearing things up maybe I'll get Fernando to put another 20 amp dedicated circuit for the HT to give me something to look forward to when this mess is all done...how's that for hope?:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Yes it is, and after the night I have had, I was really considering it just now......wingnut4772 wrote: »Phew!!!! I am so relieved. Allthough I will admit that putting a hammer through the wall was kinda fun.wingnut4772 wrote: »And What the hell! Since I am tearing things up maybe I'll get Fernando to put another 20 amp dedicated circuit for the HT to give me something to look forward to when this mess is all done...how's that for hope?:D
Might as well, the wall is already torn apart....Assuming that the rest of the fun there doesn't set you back too much... -
By the way Darla, you can give props to Mr. Bill Ayotte for linking me to this. I normally do not read [most of the time] threads like this that are non-audio related, but he actually caught me on another forum and directed me to your issues. FYI~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Anything right now is too much but what's an extra hundred or two at this point? Actually I am dreaming out loud....I am going to have to scramble to figure this one out financially....but I am sure I will. Did someone say Ebay?:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »Anything right now is too much but what's an extra hundred or two at this point? Actually I am dreaming out loud....I am going to have to scramble to figure this one out financially....but I am sure I will. Did someone say Ebay?:D
I just did the same thing (ebay) need cash in a hurry.....My situation is all kinds of fed up....
