Friday is where its at...
VR3
2 Ch, Stereo Subwoofers...
Going to be interesting to hear true seperation of bass...
Who has ran stereo subs before?
Post edited by VR3 on
I stereo subs, I like it very much. I know bass is non directional, but you can feel which side the bass is coming from.
EnjoyDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I have, but they were two different subs.
Great stereo separation, though.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
The problem is that you can wind up with nulls at certain frequencies due to cancellation.
Shall see...
Going to run a chart to see what the response looks like and will try to correct as needed.
Any setup tips? Not like I have many placement choices though haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Shall see...
I'd try the two stereo subs in the FRONT of the room (to the left and right of the window) and in the REAR of the room w/phase inverted 180deg.polkaudio RT35 Bookshelves
+1....I'd try the two stereo subs in the FRONT of the room (to the left and right of the window) and in the REAR of the room w/phase inverted 180deg."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Have a look at this article for setup tips.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
Umm...
The idea of having subs in the rear of the room is cool...
But lol - I only have room for two in the front... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'd like to try that at some point. Would be interesting.
MikeC78 had dual SVS Ultra's at the Chicagoland PF. Now THAT was INSANE :eek: :cool:
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
That what I have in my room, two PC-Ultra's. I use an active crossover between the preamp and power amp and have the subs located behind the Dynaudio monitors. Provides amazing results.MikeC78 had dual SVS Ultra's at the Chicagoland PF. Now THAT was INSANE :eek: :cool:
Vr3MxStyler2k3 wrote: »Umm...
Then you need to get a bigger room...how about the den?polkaudio RT35 Bookshelves
Agreed. You're probably wasting money with HUGE dual subs in such a small room. You won't be able to truly appreciate how good your system is. The soundstage will be compromised no matter what you do.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
+1
My system sounded fairly good in a 8.5*10 bedroom and very good in a 12*20 living room, but when I moved it to a larger 21.5*22 room it sounded amazing! Mind blowing is a better way to describe it...
Why don't you move it to the den so that your family can enjoy the system?polkaudio RT35 Bookshelves
my family dosnt appreciate it.
I'll move to a bigger room when I move out.
Until then, my small room will do. I have components that can be in a large room. Thats all that counts.
And yes, I know my room dosnt allow my system to shine.
Small room is not a problem; I have a 10x13 with big full range speakers and sound is the best I've had. I'm sure the 14 different acoustic panels help though.
Yeah I definitely gotta add some more acoustic panels, particularly in the front corners.
Honestly, while my system is big - its not over-bearing in my room. To me its oddly balanced.
I dont know, I've heard the pluses of having a larger room, much better staging and seperation comes to mind. But right now, I'm going to maximize my room out for what it is, bottom line.
I guess it comes down to, why buy small things that can't be used in a big room because you are in a small one because when you get to a big room, you will have to buy new stuff... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »my family dosnt appreciate it.
I thought they did...
My family really appreciates it; they use the system more than I do.polkaudio RT35 Bookshelves
Sid,
I have decided the only thing that is really going to work for you is eight subs.
You need four for the floor, two front and back to cover the horizontal plane and four, two front and back downfiring from the ceiling to cover the vertical.....now you are covered.
Get to work.
RT1 -
..or you could get speakers that don't need subs.
Just a thought.
having so many subs is probally just a phase for me, haha
However, one plus I like to having subs is the ability to tune it with the EQ's, since I would never put an EQ on my mains.
But I would love to have a pair of fully full range towers.
Your AR's were beastly. Bass was absolutely amazing on those.
I would love to have a subwoofer per channel. So eight subs isnt to far off.
Have larger subs for the mains, a dedicated sub to each channel, center, surrounds, etc etc
Then two LFE subs... so that would be 7 subwoofers, go 7.1 --- and have 9 subs
Granted, I am joking. HAHA
But still
Its fun none the less. I love subwoofers. They are just a fun part of the hobby for me.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sid,
Believe it or not my recommendation actually comes straight from Polk Paul, of course it is about buying product.
Just last night I juiced the Amazings listening to In the Flesh, those four subs per speaker kick ****.
RT1 -
I've had 3 different powered towers and 2 passive towers all full range inroom.
The largest with 500/1000 watt powered 15"s (side firing)always felt like the slab was being tapped with a sledge hammer but, it wasn't part of the mix. With one woofer shut down it still had the same effect ,just less so.
If the crossover was turned up into the 40hz range double kick drums mixed one left channel and one right had a nice right-left boxing punch effect.
Set lower and the low octave became disconnected.The mids,the tweeters and even the Carver sourced internal switching amps where really good but the cabinets and 15's is where corners where cut.
Price point design physics strikes again. 2-3 grand (new)offers many mighty fine almost full rangers but far fewer (new)full rangers.
I guess I've added nothing really since my example wasn't excellent powered sub pairs vs excellent single.
I wouldn't want to detract from the one voice aspect of my current fullrangers in a medium sized room. The stage is so stable and coherent, I can turn and move my head a lot yet it all stays in perfect place. I look at the speakers right there yet the sound exsists in various size focused locations all over the the room. The same model speaker in a large room staged better but sounded more anemic in the lows.
Only the phasey-ist studio effects are diffuse. Again in my medium 2000 cu ft room the lowest bass of the 6/6.5" drivers handle all but the most powerful up loud trip hop,pop,synth, keys ,bombastic levels of big kettle and native drums.
By shutting the doors I can get more quantity but, the lowest octave pays for it. I'm thinking a fullrange(lower 20's)coupled with one well matched and powerful low distortion sub would be the way to go. Would it give me more dynamics at all volumes w/o destroying the balance I have?
Towers run sans crossover with the sub taking over where they leave off makes sense to me. A powered unit capable enough to need no boundary enforcement with some nice room matching electronics.
I would like to try out a Fathom or DD-15. Anyone here hear those in home or in good room conditions?
I haven't heard any of the expensive top subs in home.
3 grand could get 2 nice subs but, should be able to get one great one. -
Enjoy! I know you're excited...polkaudio RT35 Bookshelves
Sid,
Have you heard of the SubMersive1 by Mark Seaton? If so what your opinion.
http://www.avsforum.com/avs-vb/showthread.php?t=759877&page=1&pp=30
Thanksengtaz
I have not, I've read alot about it and seems really cool.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sounds like a nice sub. Cool.polkaudio RT35 Bookshelves
Sid,
Thanks, nice link...very interesting read. Bookmarked it and Seatonsound to see if that BMF goes into production or a Submersive in Rosewood markets. The prices look exceptional and Velodyne looks like it's out. -
So - how is it?
We want pics!
