What receiver is good for..
13»
  • FittyFieFo
    FittyFieFo Posts: 482
    edited August 2007
    My TV only has a Red/White/Yellow Port. No S-Video.
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    www.bluejeanscable.com
    Very good cables, well made, & they won't take you to the cleaners like Monster!
  • FittyFieFo
    edited August 2007
  • daboyz
    daboyz Posts: 5,207
    edited August 2007
    Didn't your X come with a cable? If you have an older TV I'd just stick with the cable that came with it. I doubt it'd do a ton for you. If you upgrade your TV then look at a better cable.
