What receiver is good for..
FittyFieFo
What receiver is good for the Polk RTI10's? My budget is $200-$400, and been looking on eBay for a good reliable receiver to power these babies up. I want to try and get the most out of these speakers with clean power and clear sound. So if anyone can help me find a receiver to these speakers, that'd be great! (eBay). Also, for this receiver, I plan on plugging in my TV, XBOX (Movies and Games), and the PolkRTI10's.
I found one..is this one good?
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=rx-v2400&category0=
Thanks!!!
Thanks!!!
Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
Hi
That Yamaha is very nice. It sounded ok at the local hi-fi store.
I'd also consider one of the (used) following (based on the research I made before buying my RTi10s, and considering your budget)
Denon >= 38XX
Marantz >= 5XXX
HK >= 3XX
Onkyo >= 6XX
I, also was on a tight budget, so I bought an Onkyo 604.
After a few month I added a used 2 channel amp (Onkyo Integra A9711) to beef up the fronts.
good luck, and welcome to CP."If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'" -
Hi
Denon >= 38XX
Marantz >= 5XXX
HK >= 3XX
Onkyo >= 6XX
Thanks for the welcome! Do you think that Yahama will be good for me? I mean it's a starter kit for me. I'm on a tight budget after buying the RTI10's now. I'm a noob when it comes to receivers or anything about electronics, my interest in the past month has driven me to buy the Polks. I'll take a look around for the receivers you listed, but the Yahama is just "ok." Will it bring out the best..or somewhat the best out of my speakers?Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables -
The phrase "bring out the best" might lead you yo some heavy spending ... some of the folks here will tell you that anything less then a tube power amp, and a tube preamp is a crime. then again, they're nuts (all said in good spirit of course
That Yamaha you linked (Rx v2400) is pretty cool as a starter kit, and even a little further. sound wise you'll be set, then only thing is that it is a little obsolete on the electronics department. no DTS, no PL II,
its not very future proof either because there is no DTS or HDMI.
However, its more then ok to get you going. you'll enjoy Dolby Digital movies, very much.
Personally I found I wouldn't mind throwing some more power at my 10s, so I bought a nice used power, which I connect to the preouts on my AVR. I say start small, and once you feel you better know what you are after, join the upgrade squad."If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'" -
Welcome to the club!
I don't want to sound like I'm crappin on your choices...but many say that yammi and rti are like oil and water.
The other issue is that any stand alone receiver in this price range is not going to "bring out the best" in your 10's. For that you need external amplification. -
hmm...while I thank you again for the welcome! I guess I over-exaggerated on the bring out the best. I'm putting these in a 11' by 17' foot room. I just want them to sound GOOD. Not no crappy quality. Will the Yahama do it for me though?
And as forno DTS, no PL II,
I'm not really sure what that is...
And yes, in the future after I graduate college, I will upgrade.
Thanks for all your help!Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
What do you prefer (Brand and Model, $200-$400) (eBay)?
I am also buying a power converter: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130141281570&ssPageName=STRK:MEWA:IT&ih=003Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
FWIW, I ran my 8s on a yammie, thank god that didn't last long! I then purchased a HK 335 and an outlaw mono along with 2 marantz MM700 monos as well. Now they sound good. My Ht room is 13ft couch-tv and 23 ft long. I say buy something with preouts and is as cheap as possible and by some amps.
Yamaha's tend to be bright and RTi's are bright speakers. Thats too much "bright". Go for a warmer sounding brand (HK,Denon and many others) and stay used with your budjet.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Denon's & HK's seem to be good matches for the RTI's. Try to get one with preamp outputs to make upgrading easier in the future.
For the Denon's look for used 3802, 3803, 3805, series.
My brother scored a killer deal on a 3803 a month or so ago on ebay.
Good luck.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I also got the HK AVR335 from Harman Direct off ebay. Great receiver and has the extras to get you by for a couple years. I paid $225 shipped and you could take the extra cash and try to get a decent 2 channel amp for the fronts.
Grr!!! Too many options. I really don't know what to look for in a receiver. Can't someone just pick something out for me lol? I looked at some of the Denon's. Pretty expensive.
hmm...Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Check out HK. The prices are lower then Denon and they are very popular on here. I'm not crazy about the build quality but I had a bad experience.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
FittyFieFo wrote: »I'm not really sure what that is...
DTS is an advanced 5 channel movie soundtrack format.
HDMI, is the interface (actually there are different versions of it already)
for Hi Definition content. Audio and Video.
Check out a home theater glossary , it will help you better understand the specs of the AVRs you find on ebay."If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'" -
Here are 3 choices. The first one happens to be the receiver I have. It does great.
http://cgi.ebay.com/Denon-AVR-3802-7-1-channel-770-Watt-Receiver_W0QQitemZ200138744903QQihZ010QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/DENON-AVR-3803-A-V-7-1-CHANNEL-SURROUND-SOUND-RECEIVER_W0QQitemZ140146226490QQihZ004QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Denon-AVR-3805-7-1-channel-770-Watt-Receiver_W0QQitemZ170138114890QQihZ007QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItemMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
yeah those are the ones I looked at. hmm..maybe I'll make an offer so I don't have to wait on these
Thanks again!!! (Thanks to Carpenter too!)
Any others? (From HK or others that I don't know about)Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
There are several threads about your exact question and from waht I was able to gather Yammy's tend to be bright and so do the RTi series.
HK and Denon would be your best bet.
Good luck"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I've narrowed my choices to Denon and HK then. Thank you so much for gathering and researching this for me, I'm a huge noob
But I think the Denon 3802 and 3803 are my choices
Will they work well with my rti10's?Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
FittyFieFo wrote: »Will they work well with my rti10's?
Anything will work, it depends on how well you want it to work -
Will the Denon 3802 work very well with them :-DSamsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
yes it will, its a good choice for your budget, and not just for your budget. Denon makes fine AVRs. a mint one will serve you many years.
good luck."If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'" -
Yes it will work well right now, & you have the option to upgrade to more power in the future.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have a Yamaha HTR-5890 that I no longer use. Original packaging and accessories. I can part with it for $250 all-in. Let me know if you want pics. It's in pristine condition.
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200016 -
Thoughts on this receiver guys? (I don't know much, I'll get back to your offer) Thanks!Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
No prob. I'm always willing to make a deal.
It's a good receiver with preouts. However, again many people have found the combo of Yammies & RTI's way too bright/harsh with the tweeter. It would probably give me a headache within an hour.
Solid what did you replace the Yammie with?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
$250 for that receiver is an insane deal, but i also heard bad things about yammie and the rti series. i have an HK 445 and i really like it. when i was looking at a receiver for my rti10's about a month ago, i got alot of people saying to go with HK - i was going to get a 340, but the 445 went on sale at vanns with free shipping so i jumped on it. keep an eye on Harman Direct (http://stores.ebay.com/Harman-Audio)- they sell HK refurbs with FULL factory warranty and you can find AMAZING deals there. the 340 doesn't have HDMI but it does have pre-outs so you can add a separate amp later down the line. that would be an excellent receiver for youMy 2 ch. rig
RTi10 Cherry (bi-wire)
HK AVR 445
Xbox 360 w/ HD-DVD attachment
Not too bad for a dorm room I think?
I may be biased, but my RTi8s, 6s, 4s and Fxi3s ran beautifully on that system. It had the balls to really get that system pumping. In terms of brightness . . . well maybe, but I saw it more as sound that took me by the balls and let me know who was boss. I rarely had listening fatigue after a couple hours of use.
I replaced my Yammie with a Rogue Tube Audio Preamp, PS Audio Trio DAC and PS Audio Trio A-100. This was quite step up. I also sold my Rtis for Lsi15s, Totem Rainmakers, Totem Arros and Totem Hawks.
I'll let you decide on the deal for a couple of days. Let me know. I plan to put it on ebay middle of next week.
