OK HT Subwoofer
What I can get OK subwoofer for HT around $250ish.
I currently have PSW10 which is good for music but for movie I didn't hear its there. Its frequency response is 35Hz - 200Hz. Does it matter? My other speakers are RTi4, CSi3. Thanks for any input.
Post edited by MKZ on
In $250 used range look at bigger Polk, JBL, Infinity. If you go ~$100 more, you should be able to pick up JBL studio S120PII (400 Watts RMS into 12" driver). I really liked that sub for movies.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Do you know how long it usually take when you ordered it? The frequency range is quite impressive. -
Audiogon has a polk for $175-->
http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1185893517
How "-ish" is your $250 limit? They also have a velodyne for $300 + shipping-->
http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1187823130"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
It's hit or miss. It can take a couple of days to a few weeks. I'd call or email them.Do you know how long it usually take when you ordered it? The frequency range is quite impressive."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It has very good reviews at amazon. Let me go listen and get back to you. Thank you. -
I couldn't find that JBL at Circuitcity, Bestbuy or J&R. What others models can I go look at? Thanks.
What about JBL CVSUB50? Would it sounds the same as JBL S120PII? Thanks.
For that budget - your best bet would be DIY if you have any building skills at all. Other than that - I would just save a bit more / longer. It seems like around $350-$400 is where the decent home theater subs start.
Polk is supposed to be releasing some really nice subs this year. (really, they are...) it may be worth waiting and see what they have come up with.
(Matt apparently got tired of an entire forum dedicated to his speakers saying his subs sucked - now if he would just listen to us about the SDA's.....)
My Polk subs are great, always have been, they blow others away. Especially Velodyne. I would just buy another 250 and stack it or put it in another position in the room, whatever sounds best to you.
RT1 -
Polk Just needs to bite the Bullet and buy SVS. Then they would be KING!
LoL "It sounded good"
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-752
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumberhttp://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-468=300-750
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-464
If you can build a box, or even easier yet go with sonotube. You will end up with a killer HT sub.
Ben -
Okay..Okay.. Do you have any specific model in mind for around $350?
The new model comes out around September like RTiA series? May be it worth waiting if they sell for the discounted price not MSRP.
SVS? Yes, I know it is great subwoofer, most forum members' favorite here. But it is beyond my limit. The lowest 10" model costs $429+40 shipping. It doesn't even have crossover line level input. I would rather go 12" model which has full features if I can afford those.
I wished I could build one by myself. Thanks for the info. -
For $350, http://www.edesignaudio.com/edv2/product_info.php?cPath=2_41&products_id=407
or
http://www.edesignaudio.com/edv2/product_info.php?products_id=309
/eD Fanboy"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face is giving you some good advice eD is the real deal for a no nonsense bottom dweller for a great price.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Hi MKZ,
I'd actually look at the way you have your existing sub hooked up. I NEVER hook up a sub the "traditional" way and run speaker cables into the sub and out from the sub to the speakers :eek: .
I have the PSW250 8 inch sub (with the phase switch set to reverse or 180) and for the size of this bugger, it rocks both on music and HT (hooked up to the SurroundBAR). I also have my PSW505 hooked up the same way to my RTi10s with the front speaker setting as large in my AVRs. Check this Polk link for more info:
http://www.polkaudio.com/education/showanswer.php?question_num=79
Hope this helps.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200 -
Hi Face,
I am currently live in apartment with hardwood floor, I am worried that the ED is the down-firing subwoofer so I don't want to get trouble with the people downstairs. would it be a problem? what do you think? I know I can't get that low frequency response unless spending $1000. -
Ron Temple wrote: »Face is giving you some good advice eD is the real deal for a no nonsense bottom dweller for a great price.
I know Ron. Thanks. -
Hi MKZ,
Hope this helps.
I connected the subwoofer with LR pre-amp out. Set the speaker config Front=Large and No Subwoofer on using Denon 1906AVR. At subwoofer, the crossover frequency is around 90~95Hz, phase 180 degree. I didn't connect the front speaker through sub since I want to bi-amp those. It sounds more cleaner to me compare to center channel. The subwoofer amp is 50W while receiver is supplying 85W/channel. I did tried the sub-out and it didn't sounds better than my current. Any idea? Thanks. -
Where are you?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I believe with your current set up, you need the subwoofer set to yes. This maybe why you are not getting the sub in HT (or maybe music either).Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
I didn't connect subwoofer through LFE sub-out, if I set to yes it will cut the frequency lower than 80Hz. -
if you can get a velodyne cheap somewhere..
MKZ you have a PM!
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Polkies,
He has connected his sub in what is known around here as the Polk Way, its just what we call it for short. Basically, using the speaker level connections.
MKZ,
If you are still not getting any "good" bass, you should set the sub in your listening position and turn it on with something that has a nice bass track or a bass tone. Then crawl around your room along the walls and see where the bass sounds the best, once you determine this you know where to set your sub, this is an old reliable technique which does require a bit of work.
RT1 -
Thank you! I have checked and replied back to you.:)Shannon W. wrote: »MKZ you have a PM!
Shannon -
reeltrouble1 wrote: »Polkies,
MKZ,
RT1
I'll try that. I'm sitting 8ft away from front bookshelf speakers and woofer. I can even feel the bass in my chest from small speakers but not from woofer. I'm not playing loud, I like to get some bass response on low volume level. Thanks RT1. -
It doesn't improved much after tweaking the sub and receiver setting. PSW10 is not as good as PSW250 like VXR8 and RT1 have. Those PSW250 are more like PSW303 RTi Series. Finally decided to get the sub this weekend after I have done enough homework. Here is the list of sub I am currently considering:
JBL S120PII $320
http://www.ubid.com/New_JBL_S120PII_12%22_400-Watt_Front-Firing_Powered_Subwoofer/a901667695.html
http://www.soundandvisionmag.com/assets/download/seismicsubslab.pdf
JBL CVSUB50 $200+
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=005&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=150138153559&rd=1&rd=1
Polk PSW404 $250
http://www.amazon.com/Polk-Audio-10-Inch-200-Watt-Subwoofer/dp/B00007G9J5/ref=pd_ts_e_3/104-9741115-1013552?ie=UTF8&s=electronics
Polk PSW505 $320
http://www.jr.com/JRProductPage.process?Product=3951153
http://www.hometheaterhifi.com/volume_12_2/polk-psw-505-subwoofer-4-2005.html
Down-Firing Sub
HSU STF-2 $380
http://www.hsuresearch.com/products/stf-2.html
Elemental Designs A2 - 300 $350
Elemental Designs A2 - 250 $300
http://www.edesignaudio.com/edv2/product_info.php?cPath=2_41&products_id=406
Outlaw LFM-1 Compact $400
http://www.outlawaudio.com/products/lfmcompact.html
I am worried about those down-firing sub since I lived in small apartment whose house rule has not to play loud music. I just don't want to get trouble. I need more opinions since I have to get the sub w/o knowing how it sounds and based on reviews and people suggestion. Hopefully some of you guys can help steer me in the right direction.
I really appreciated all of you who had put efforts and time for my sub search.
Thank you.
Don't forget the BIC H-100.
