How many of you are content with your systems?
  • madmax
    madmax Posts: 12,434
    edited June 2007
    My system sounds like ****.
    madmax
    Vinyl, the final frontier...
  • avguytx
    avguytx Posts: 1,628
    edited June 2007
    For the money I have invested in my 2-channel setup, I am completely happy. As far as my Home Theater setup goes, I don't have lots of time for critical movie watching so it all works for me there, too. I'm an electronics rep for various home A/V lines and my system is still pretty basic. Just because I can buy it dirt cheap doesn't mean I want to spend all my money on it! But I like it never the less.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I'm never 100% satisfied, but then again, I'm just getting started.
    I thought I would never touch my HT, because 2 channel is my focus and my speakers / components for HT were adequate for my current setup.
    But, if a good deal comes my way (like the B&K ST-1430, giving me matching power for my front soundstage) I still jump on it. Hell, I'm even thinking of getting a Ref 20 and moving to separates.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited June 2007
    I am very pleased at this point, but I have noticed that following the long period of research and anticipation that I normally go through prior to acqiring a new component, once I have acquired the component, I repeat the cycle.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    madmax wrote: »
    madmax
    Hey you made me blow snot on my belly:D
    Ben
  • halo
    halo Posts: 5,618
    edited June 2007
    a_mattison wrote: »
    hmmmm..... I really NEED.... LSi15's (or maybe, as a stretch goal, some Von S. VR2's...this is Halo's fault)
    My fault? :confused: The VR-2's belong to my brother, Greg.
    If you want to take it further back blame Darla. Right after I borrowed a pair of LSi7's from SCompRacer I was contemplating picking up some LSi9's (7's didn't dig deep enough & I personally never cared for the 15's) when Darla dumped her all LSi set up in favor of an all Von Schweikert set up. This made me remember hearing the VR-1's & VR-4jr's at decibel audio. I didn't really want a bookshelf (I preffer a floorstander) so the VR-1 and the LSi9 were out. I couldn't afford a pair of VR-4jr's so I figured I'd split the difference with the VR-2's. The VR-2 was also the Absolute Sound "editor's best buy 2004" and is very "tweakable" to match your room's acoustics. You can add shot (or not), add or subtract polyfil, adjust the "ambience" driver, placement, toe-in, etc. I also liked the finishes that are available on the Von's. So I go to the 'gon, got lucky & found a good deal on a pair of VR-2's and, until I heard the Eros at Rich's, I was perfectly happy with them.
    After hearing them again @ the PF (in a better set up than when I owned them - IMO) I realized how much potential they have for further enjoyment. I can not say enough good things about them and if I had the means for a 2nd rig I'd be all over the VR-2's.
    As far as my current 2 channel :
    After I've pretty much copied SComp's / Normanality's rig(s), I am, once again, perfectly happy. I might try some different tubes but I think all I really want is a spare set for the ModWright modified Sony & the VTL. I don't want or even feel a desire to change anything. It's all come together and I'm very happy with it. That may change down the road. Who knows what the future holds? I know better than to declare "I'm done". The HT is good for me but definitely has room for improvement / change.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2007
    Halo wrote: »
    If you want to take it further back blame Darla...
    Mwah ha ha ha ha ha..........:p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
