SRS 1.2TL advice.
Janne
Janne Posts: 139
edited June 2007 in Vintage Speakers
Hi new here! I bought my speakers back in Saudi Arabia 1992 and have been dragging them with me through Thailand and now to China. I have been reading about XO upgrades and tweeter changes in some of the threads. I have now XO BE-2001-C and SL3000. Would an upgrade be possible or improve the sound. The left speaker also sounds a little dull and it looks like it is taking less power from the amp. Not that the meters on the amp would be any reference but it looks and sound like the left channel has less high frequencies. Any advice is highly appreciated.
Serial R7122 & L7107
HT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
Post edited by Janne on
«13
  • Polk65
    Polk65 Posts: 1,405
    edited June 2007
    Welcome. I believe you now hold the long distance record for moving a pair around. Before the upgrade goblins start their chants, there are a few other things to consider. The SL3000 tweeters have a finite life. When? No one knows but eventually their fluid will dry or clump up. The polyswitch is a tweeter protection device on the crossover and can often make tweeters do some funky stuff. If you have a multimeter, here is the SDA checklist in .doc format which you can use for troubleshooting. http://www.polkaudio.com/forums/showpost.php?p=564265&postcount=13
    edit: Some of the crossover components have an expected lifespan of around 20 years so upgrading these parts is a good idea and does benefit the sound.
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2007
    Welcome; yes, you can upgrade your X-overs, and get the new silk replacement tweeters. You'll hear improvements with both (More with the X-over upgrade IMO, though others might disagree...).
    Use the search function and you'll get lots of threads on the subject. Here's one (If you are going to do the x-overs, I'd recommend using Sonicap capacitors instead of Solen; they cost more, but the different in sound is worth it):
    http://www.polkaudio.com/forums/showthread.php?t=37333&highlight=1.2TL%27s
    SOPA
  • Janne
    Janne Posts: 139
    edited June 2007
    Thanks! The SL3000 were made back in Jan-91 so they have a few years on them. The polyswitch was probably glowing until Customer service adviced GET A BIGGER AMP!!!!!! I now run an old McIntosh MC500 which is nicer to the tweeters than the previous 200+200W Denon.
    I will try that XO upgrade. It does not look that hard to do the upgrade.
    Thanks to both of you!!
    I lost the wife between Saudi and China but I am not letting these babies go! :) I would miss them more!
    HT/2 CH
  • madmax
    madmax Posts: 12,434
    edited June 2007
    Janne wrote: »
    You should fit in well here. :D
    madmax
    Vinyl, the final frontier...
  • rskarvan
    rskarvan Posts: 2,374
    edited June 2007
    Well.... a small wife would be easier to misplace than those big speakers!
  • Janne
    Janne Posts: 139
    edited June 2007
    Eight tweeters and two polyswitches were ordered last night. 48USD a piece +120 USD shipping :eek: . Anyway it will hopefully be worth it.
    I am having trouble finding an online store that have the recommended Sonicap capacitors. The Partsconnexion.com only has Solen capacitors. Anyone who knows a store?
    How important is it to get the capacitance exactly as per the instructions. I saw on the Partsconnexion.com page that the tolerance for Solen capacitors is +- 5%. That would mean if I buy a 12 and a 1.5 and piggyback for the 13.5 uF requirement, max could be 14.2 uF and min 12.82.
    For Jensen capacitors that cost 10 times more than the Solen the tolerance is -10 +20% ?? this is getting confusing.
    Would you advice to use two different brands?
    HT/2 CH
    F1nut Posts: 51,813
    edited June 2007
    A few comments.....
    You can leave out the delrin binding post insulators as they still require an oversized hole with flat shoulders on each side. It was easier to just do the flat sided holes for the Cardas binding posts. At that point, if you want, you can use red and black pin strip material to mark the posts. This job is not that easy and requires some forethought. It requires drilling and filing with miniature files to get the right shape. If you round out the holes, that is, if you end up with more than flat sides the posts will spin in their holes or worse, will slip thru.
    Think long and hard about changing the interconnect cable socket from the stock socket. If you're bent on changing the cable, you can do that and still use the stock socket by terminating the ends with a pin and blade connector. If you plan on needing the AI-1, I'd leave cable socket stock, period.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2007
    Janne wrote: »
    I wouldn't install the polyswitches, I would bypass. However bypass them only if you are confident that your amp has enough headroom for those bigguns!
    BTW welcome to the club!!!
  • Janne
    Janne Posts: 139
    edited June 2007
    Thanks!
    I have the McIntosh MC 500 power amplifier. It has a soft clipping circuit to protect the tweeters. I believe it works as I have not had any damaged tweeters for years. Well last night when I was measuring up the speakers I found one dead tweeter. But I am not sure if that was from loud playing or old age.
    HT/2 CH
  • Janne
    Janne Posts: 139
    edited June 2007
    Lasareath wrote: »
    Here's the email I got from Joe (Hearingimpared):
    Sonic Craft http://www.soniccraft.com/ ;
    Call to order, 501-620-4444, you will be speaking to Elliot.
    Sonic Craft Generation 1 http://www.soniccraft.com/sonicaps.htm
    “Sonic Capacitors Generation 1”
    Ask for Custom Matched & as close to 1% tolerance as possible:
    Qty Rating
    6 12uf (he was able to get the 1% tolerance for me)
    2 0.25uf (he is going to have problems matching this and will probably get within 8% tolerance which is okay.
    2 13.5uf (he could get 3% tolerance here for me)
    2 27uf (2% tolerance for me on this one)
    Mills Wirewound Resistors – non-inductive http://www.soniccraft.com/mills_resistors.htm
    All should be rated 12 watt
    Qty Rating
    2 2.7 Ώ
    2 7.5 Ώ
    2 11.5 Ώ (you may have to settle for 11 ohms here)
    2 15 Ώ
    2 22.5 Ώ (if you can only get 22 ohms that is okay)
    SDA InterConnect upgrade and Speaker Binding Post upgrade
    15’ of what ever speaker wire you are using currently to 1.2 TLs.
    Hopefully something no smaller than twin lead 12 ga wire.
    10 Cardas CCGR short http://www.soniccraft.com/products/connections/bindingpost/cardas_ccgr.htm
    Four red and 6 black delrin binding post insulators.
    http://www.cardas.com/content.php?area=oem&content_id=14&pagestring=Insulators
    Two heavy ¼ “ gold spades that will accept up to 6 guage wire. http://vampirewire.com/mcart/index.cgi?code=3&page=1&cat=7
    All of the above except for the spades can be ordered from Elliot.
    To summarize, you will be ordering 12 capacitors, 10 resistors, 10 Cardas posts, 10 delrin insulators, two heavy gold spades.
    Raife recommends using Monster Z2 for the SDA IC upgrade but he says to use the same wire that you used to connect your amps to the speakers.
    Thanks for the very detailed instruction!
    Would it make a difference to go for more high end capacitors? I am not really on a budget and if I will do the upgrade I would hate to read in a thread later that someone bought some better capacitors and the result was just fantastic :eek:
    I was reading this page and this guy seems to have tested most of the capacitors.
    http://www.humblehomemadehifi.com/Cap.html
    How about the coils? Would a swap do any improvement there?
    I really appreciate all your advice! This is a great forum!
    HT/2 CH
  • george daniel
    george daniel Posts: 12,096
    edited June 2007
    I have replaced the inductors(coils) on the crossover boards of my SDA 1C,ONLY because I had to.
  • george daniel
    edited June 2007
    Lasareath wrote: »
    George,
    Did you notice any sound difference?
    And why did you have to?,
    Las
    Honestly,,I could not tell/hear a difference,,, I replaced the inductors because they had become dislodged in transport,,I used sonicaps and replaced the vc/inductors at the same time, so I never did an A-B comparasion. What I can say is that they sound Very Good. I purchased the inductors from madisound IIRC,,.
  • hearingimpared
    edited June 2007
    Janne wrote: »
    The way I understand this is that the even high priced capcitors cost like two to three time more than the Sonic Caps but don't perform two or three time better. They may sound a little better but not the same ratio of their cost. Unless your coils are shorted out or open there should be no need to replace them.
    F1nut Posts: 51,813
    edited June 2007
    If I was going to use Mundorf's, I would only use the Silver/Oil caps as the Silver/Gold present a slighty different sound. Having said that, real estate is a problem on the crossover boards. Fitting the Sonicap's is a challenge in it's self, fitting the Mundorf's is impossible without mounting them remotely. You will be very pleased with the Sonicap's, they are excellent.
  • hearingimpared
    edited June 2007
    My Sonic Caps have just completed the burn in cycle and I agree, they are excellent!
    heiney9 Posts: 25,450
    edited June 2007
    I have Sonic caps in my 1C's as well and they sound fantastic. However I never had a chance to hear the 1C's (recently) with the stock x-overs as these were bought already modified. But I have no doubt it's a huge improvement and well worth the cost, time and effort.
  • Janne
    Janne Posts: 139
    edited June 2007
    Sonicap's it will be! I totally forgot the size factor. Being a metric guy. Inches does not make sense before you take out the calculator :o
    HT/2 CH
  • Janne
    Janne Posts: 139
    edited June 2007
    HTrookie wrote: »
    In the link to the upgrade 4 pcs 750 pF SilverMica were used. Are they still needed?
    HT/2 CH
  • george daniel
    edited June 2007
    good question,, some do, some use a .1uF sonicap in place/instesd of the silver mica,,and lately it is just replaced with a jumper instead.I believe that Darqueknight and F-1 have alot of experience when it comes to the pro's and con's of the 750 sm,my last set of 1C's,I used a jumper in place of the polyswitches and silver mica's. You may want to pm them and get their opinion. Have fun :)
  • george daniel
    edited June 2007
    Lasareath wrote: »
    He needs more posts before he can PM
    oh,,, well,in that case,,I'd just use a jumper,,but if he wants to use the silver mica's,,someone here,I can't remenber who,, just received a bunch of silver mica's that I sent them,,,maybe post a wtb for them.
  • hearingimpared
    edited June 2007
    Janne wrote: »
    Take the SilverMicas out and place a jumper between R2 & P3. Look at the picture here. In the lower left hand corner you will see where the jumper goes.
  • Ricardo
    edited June 2007
    Janne wrote: »
    Janne,
    When I did the 1.2TL's I replaced the Silver Micas with new ones. I later did the upgade on a pair of 3.1TL's, and used Sonicap capacitors, using a Sonicap Platinum as the by pass. F1Nut had recommened that I could eliminate the by pass because using high quality capacitors did not require it, but I wanted to hear for myself and used it. I removed the by pass later and liked the sound better. Here's the link to the 3.1TL's upgrade thread:
    http://www.polkaudio.com/forums/showthread.php?t=47929&highlight=crossov%2A
    Bottom line, if you use Sonicaps I'd recommend you just eliminate the silver micas (and place the jumper as Joe says....I didn't need it because the 3.1TL's single by pass is a direct by pass, while one of the 1.2TL's is not and the jumper is required).
    SOPA
  • hearingimpared
    edited June 2007
    There is one part of the upgrade which is very hairy. Look at the first picture. There is a royal blue capacitor half way up the board on the outer left hand side. This cap is butted up against the front of an inductor. One set of inductor leads is literally wound around the middle portion of the leads of the capacitor and soldered. You must be very, very careful when removing this cap from the board and from the inductor leads which are very fragile.
    The next pictures display how the new Sonic Cap is installed. When installing the new cap proceed with caution as not to break the inductor leads. . . if you do, you are in deep ****.
  • Janne
    Janne Posts: 139
    edited June 2007
    Guys! Soniccraft needs a schematic of the XO Where can I find one for the 1.2TL?
    HT/2 CH
    F1nut Posts: 51,813
    edited June 2007
    Las posted a parts list on page one, but here it is again.
    Caps:
    (2) .25uF (closest they have is .22uF, which is fine)
    (6) 12uF
    (2) 13.5uF
    (2) 27uF
    They will custom match and ask for close tolerance.
    Resistors:
    (2) 2.7 ohm
    (2) 7.5 ohm
    (2) 11.5 ohm (11 is close enough)
    (2) 15 ohm
    (2) 22.5 ohm (22 is close enough)
    All are 12 watt.
  • Janne
    Janne Posts: 139
    edited June 2007
    Caps:
    (6) 12uF
    (2) 13.5uF
    (2) 27uF
    Resistors:
    (2) 2.7 ohm
    (2) 7.5 ohm
    (2) 15 ohm
    All are 12 watt.
    I have sent these data already. I dont know why they are asking for schematics?
    HT/2 CH
  • Ricardo
    edited June 2007
    They don't really "need" it; they should just fill your order with no questions asked.
    I emailed you the file, if you want to send it; just make sure they don't convince you of buying anything extra (like a few platinum caps for by-pass) ;)
    Edit: cannot attach anything using the forum email option; PM me your email address and I'll send it. Too big to attach here.
    SOPA
  • Janne
    Janne Posts: 139
    edited June 2007
    HTrookie wrote: »
    Thanks! Its 05:00 in the morning here and I cant wait to order the parts to do the upgrade. They know it and just want to make me suffer. I found this one in the forum. I hope it is the right one.
    SRS1_2TLSchematic(1).pdf
    HT/2 CH
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    HTrookie, thanks for the insite (I didn't need it because the 3.1TL's single by pass is a direct by pass, while one of the 1.2TL's is not and the jumper is required). I was still wandering about weather it was reqired for the 3.1's.
    engtaz
  • Ricardo
    edited June 2007
    Janne wrote: »
    That's the one.
    SOPA
