Denon PMA-2000IVR
KG Audio
This is Denon's integrated amp.
I just wanted to get people's thoughts on using this to push either LSi9's or LSi15's.
Thanks,
KG
Thanks,
KG
it will more than do the job, i had one that drove paradigm studio 60 v2 and
usher 6381's to ear splitting levels.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I am a Denon fan but what are you paying. I would be looking in the 200 watt amps like Adcom, Outlaw Audio, Rotel and such. Denon makes great products but price per watt is usually high for their amps.engtaz
Lets put it this way, I've used one to drive 4 Ohm SRTs before! :eek:
this is not your average denon, it is a high current model. when i first got mine i was usind 2 harmon kardon citation 24 100 watt high current (i thought) amps bi-amping my paradigm studio 60's, this 80 watt denon blew them out the water. it sounds lika 200 watt amp, it's only weakness is the preamp section, get a tube preamp and this is a hard to beat combo. the 2000ivr is based on this denon series of amps:
http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1183670390
go to www.audioreview.com and read the owner reviews of this amp.
marvinAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
it sounds lika 200 watt amp, ...
I concur with Marvin. It's very conservatively rated.
Click here for a peek inside: :eek:
http://www.crutchfield.com/S-1AMVjNI4LMW/cgi-bin/ProdView.asp?g=10450&tab=morephotos&i=033PMA2KIV&pi=6&display=XL#Tab -
Call me crazy but I am a sucker for the visuals of a unit
. Besides the insides, this unit is very SEXY
on the outside. Black, not too many knobs, basic, etc.
I should also mention that I love products that are from US companies made in Japan
KG -
I have the PMA 2000IVR and from my experience it is very accurate. Drive power is amazing. Even though many people consider that the preamp could be better it much better than most receivers on the market today. It is sounds better than my adcom GTP-500II. I'm driving a pair of RTA 11T's in a bedroom system. Just be sure to have a sturdy rack, my 30yr. old particle board with glass door rack is cracking from the weight, 58lbs!
Jockos -
let me make it clear, when i say the preamp section is the denon's weakness i'm not saying the preamp section is bad. it's that it is not the most transparant and the soundstage is a little closed in, most of the integrateds under $1500 have this same problem. it would take a much more expensive integrated amp to best the denon.
Puritan PSM156 -
I have no issues with it's pre-amp section whatsoever. My only complaint with it at all is that you can't use it's pre-outs/main ins at the same time, therefore effectively eliminating the ability for me to use it with any of my NHT active outboard crossovers. :mad:
