I think I finally got my mind made up! MONO BLOCKS
That Odyssey gear looks bad **** (inside & out)! I like the look of the silver & black in the photo. If it were me I'd buy black since the rest of my gear is black.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Odyssey dosnt make stuff up - the capacitors inside clearly tell you how much microfareds it has (uf) -
Each cap Klaus uses does 15,000 uF
And the Stratos standard has 4 per side, thats 60,000 uF.
Now when you get into current draw, its when you gotta call BS since there is no standard of measurement.
And yes, I had the upgraded Khartago. It was essentially a stereo Stratos in a Khartago case.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks for the pic. I hadn't popped the top on it yet. Heatsinks on the inside pretty much the only difference.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
Yeah you save about 300 bucks getting the Khartago Stratos....
The Khartago uses a much smaller case
and of course the sinks are on the inside...
I personally like big amps, sooo the Stratos move is my only option. Two big amps are even better. HAHA
Do not pop the top.
trust me on this.... it is a PAIN - and I do mean a PAIN to get back on.
It slides on and off and its incredibly hard to get that sucker back on.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Odyssey dosnt make stuff up - the capacitors inside clearly tell you how much microfareds it has (uf) -
Relax Trey....I'm not saying that they are making stuff up, just saying that I've not seen many amps with the capacitance(sp?) listed as specs. I actually think that small manufacturers are more on the conservative side;)_________________________________________________
Im not saying you are.
Ive been down the road before though... seen alot of wild specs.
I will tell you this - the Khartago dosnt break a sweat with the Taylos. I'm just retarded.
I have never been happier with a setup than I am right now. Its phenominal and has no weaknesses that I can think of.
My only weakness is the upgrade bug.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Belles for example, uses amperes....the 350a ref. has 64 amperes, whatever that means
The given amount of current that can flow from peak to peak on a cylce, how many electrons are dancing down the line, its an important spec. 64 is pretty darn good.
example=we have device we attach to people, its called a stun belt, when called for a button on a remote is pressed and the device issues of shock of 50,000 volts to the individual, however, at very very low amperage way less than 1 amp, I cant remember how low it is like .05 or something, so the person falls down, as their nureo system is interupted, sometimes they **** themself. This is how electrical stun devices work.
Who wants to come over and play??????????
RT1 -
Vr3MxStyler2k3 wrote: »Im not saying you are.
I'm not so sure I would call that a weakness. Besides power and capacitance, the Stratos seems to have a better chassis, less vibrations, the whole nine yards. In essence you will be even more happier once the amps arrive.
Now these should be the last amps you ever get...although I know, the upgrade bug...polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
reeltrouble1 wrote: »The given amount of current that can flow from peak to peak on a cylce, how many electrons are dancing down the line, its an important spec. 64 is pretty darn good.
RT1
Hope you don't have any of those around during polkfest
You've got a few more weaknesses than that! -
What? I like foreign trucks/cars? haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well, I did invite a couple of the Anti Audio Hi-Fi Insurgents........
Trey, do you know if Klaus goes so far as to actually tune the chassis?
RT1 -
Tune the chasis?
Say waaaahh?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I heard about tuning the chassis of amplifiers at HES, in which tuning is done to eliminate resonance in the cabinets. There is also such a thing as "tuning an audio rack," but I'm not sure if it makes any difference.
BTW, I have my mind made up about the Crown. Can you e-mail me?polkaudio RT35 Bookshelves
Shoot me another one- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I do not know if Klaus tunes the chasis.
I doubt he does.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Wimp. Go for the Mono Extremes or go home.
Congrats, man. You're really putting together a system you'll be hard pressed to outshine to any great degree ever.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Thanks.
Yeah, I think I am going after another VMPS Larger sub directly after the mono blocks - just to top off the craziness of my entire rig.
Add two more panels and upgrade some wiring.
Still will be finished up around October/November - oddly enough.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yep, and when I get stereo subs -
I will probally build isolation amp stands to go on top of the subs... load them with sand, with a floating top... floor saver spikes - should be very anti-vibration. They could house the Stratos.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The kids gone update crazy!! LOL
:eek: :eek:
engtaz
Hey Trey,your little Khartago is a factory Hot Rod :cool: The blue capacitors with gold stripes are high end Nichicon Muse and are in no way standard items, they are the same ones used in my mono extreme SE's except that i have 4 x400 va = 1600 va worth of Plitron transformers , 360.000 uf worth of Nichicon Muse capacitance and 65 Amps of current. they weigh 66 lbs per monoblock. i previously owned a pair of Khartago monoblocks and they were really sweet.Vr3MxStyler2k3 wrote: »Odyssey dosnt make stuff up - the capacitors inside clearly tell you how much microfareds it has (uf) -
And yes, I had the upgraded Khartago. It was essentially a stereo Stratos in a Khartago case.Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
He Does !Vr3MxStyler2k3 wrote: »I do not know if Klaus tunes the chasis.
I doubt he does.Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
Trey you do know that I need an amp, right?
So are you selling the Khartago?polkaudio RT35 Bookshelves
I am trading the Khartago in for full credit.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No problem. What about the Azur 540D?polkaudio RT35 Bookshelves
Its on the chopping block - but not an immediate chopping block.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks. Keep me posted!
Those monos do look really nice though.polkaudio RT35 Bookshelves
reeltrouble1 wrote: »I cant remember how low it is like .05 or something, so the person falls down, as their nureo system is interupted, sometimes they **** themself. This is how electrical stun devices work.
RT1
RT1, it has to be lower than .02 amps cause if there is enough voltage to push .02 through a persons heart it will stop it. 50KV is definitely enough to push that much. That thing must have some major step up xformers.
See I still remember some of the useless facts I learned in tech school oh about a hundred years ago.:D -
I wonder if those mono extremes are up to driving a pair of Magnepan's? I am assuming the wpc is at 8 ohm? I have been watching for a pair of Parasound Halo JC1's, but even used they are a lot more money than the Odyssey mono extremes.DKG999
