I think I finally got my mind made up! MONO BLOCKS
2
  • halo
    halo Posts: 5,618
    edited May 2007
    That Odyssey gear looks bad **** (inside & out)! I like the look of the silver & black in the photo. If it were me I'd buy black since the rest of my gear is black.
    VR3 Posts: 29,549
    edited May 2007
    Odyssey dosnt make stuff up - the capacitors inside clearly tell you how much microfareds it has (uf) -
    Each cap Klaus uses does 15,000 uF
    And the Stratos standard has 4 per side, thats 60,000 uF.
    Now when you get into current draw, its when you gotta call BS since there is no standard of measurement.
    And yes, I had the upgraded Khartago. It was essentially a stereo Stratos in a Khartago case.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited May 2007
    Thanks for the pic. I hadn't popped the top on it yet. Heatsinks on the inside pretty much the only difference.
    VR3 Posts: 29,549
    edited May 2007
    Yeah you save about 300 bucks getting the Khartago Stratos....
    The Khartago uses a much smaller case
    and of course the sinks are on the inside...
    I personally like big amps, sooo the Stratos move is my only option. Two big amps are even better. HAHA
    Do not pop the top.
    trust me on this.... it is a PAIN - and I do mean a PAIN to get back on.
    It slides on and off and its incredibly hard to get that sucker back on.
  • Ricardo
    Ricardo Posts: 10,634
    edited May 2007
    Relax Trey....I'm not saying that they are making stuff up, just saying that I've not seen many amps with the capacitance(sp?) listed as specs. I actually think that small manufacturers are more on the conservative side;)
    SOPA
    VR3 Posts: 29,549
    edited May 2007
    Im not saying you are. ;)
    Ive been down the road before though... seen alot of wild specs.
    I will tell you this - the Khartago dosnt break a sweat with the Taylos. I'm just retarded.
    I have never been happier with a setup than I am right now. Its phenominal and has no weaknesses that I can think of.
    My only weakness is the upgrade bug.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    HTrookie wrote: »
    Belles for example, uses amperes....the 350a ref. has 64 amperes, whatever that means:confused::confused:
    The given amount of current that can flow from peak to peak on a cylce, how many electrons are dancing down the line, its an important spec. 64 is pretty darn good.
    example=we have device we attach to people, its called a stun belt, when called for a button on a remote is pressed and the device issues of shock of 50,000 volts to the individual, however, at very very low amperage way less than 1 amp, I cant remember how low it is like .05 or something, so the person falls down, as their nureo system is interupted, sometimes they **** themself. This is how electrical stun devices work.
    Who wants to come over and play??????????
    RT1
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    I'm not so sure I would call that a weakness. Besides power and capacitance, the Stratos seems to have a better chassis, less vibrations, the whole nine yards. In essence you will be even more happier once the amps arrive.
    Now these should be the last amps you ever get...although I know, the upgrade bug...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Ricardo
    edited May 2007
    RT1
    Hope you don't have any of those around during polkfest ;)
    SOPA
  • rskarvan
    rskarvan Posts: 2,374
    edited May 2007
    You've got a few more weaknesses than that!
    VR3 Posts: 29,549
    edited May 2007
    What? I like foreign trucks/cars? haha
  • reeltrouble1
    edited May 2007
    HTrookie wrote: »
    Well, I did invite a couple of the Anti Audio Hi-Fi Insurgents........
    Trey, do you know if Klaus goes so far as to actually tune the chassis?
    RT1
    VR3 Posts: 29,549
    edited May 2007
    Tune the chasis?
    Say waaaahh?
  • Serendipity
    edited May 2007
    I heard about tuning the chassis of amplifiers at HES, in which tuning is done to eliminate resonance in the cabinets. There is also such a thing as "tuning an audio rack," but I'm not sure if it makes any difference.
    BTW, I have my mind made up about the Crown. Can you e-mail me?
    VR3 Posts: 29,549
    edited May 2007
    Shoot me another one
    VR3 Posts: 29,549
    edited May 2007
    I do not know if Klaus tunes the chasis.
    I doubt he does.
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2007
    Wimp. Go for the Mono Extremes or go home.
    Congrats, man. You're really putting together a system you'll be hard pressed to outshine to any great degree ever.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    VR3 Posts: 29,549
    edited May 2007
    Thanks.
    Yeah, I think I am going after another VMPS Larger sub directly after the mono blocks - just to top off the craziness of my entire rig.
    Add two more panels and upgrade some wiring.
    Still will be finished up around October/November - oddly enough.
    VR3 Posts: 29,549
    edited May 2007
    Yep, and when I get stereo subs -
    I will probally build isolation amp stands to go on top of the subs... load them with sand, with a floating top... floor saver spikes - should be very anti-vibration. They could house the Stratos.
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    The kids gone update crazy!! LOL :D:D :eek: :eek: :D:D
    engtaz
  • Serendipity
    edited May 2007
    engtaz wrote: »
    Agreed.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited May 2007
    Hey Trey,your little Khartago is a factory Hot Rod :cool: The blue capacitors with gold stripes are high end Nichicon Muse and are in no way standard items, they are the same ones used in my mono extreme SE's except that i have 4 x400 va = 1600 va worth of Plitron transformers , 360.000 uf worth of Nichicon Muse capacitance and 65 Amps of current. they weigh 66 lbs per monoblock. i previously owned a pair of Khartago monoblocks and they were really sweet.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • W WALDECKER
    edited May 2007
    I doubt he does.
    He Does !
  • Serendipity
    edited May 2007
    Trey you do know that I need an amp, right?
    So are you selling the Khartago?
    VR3 Posts: 29,549
    edited May 2007
    I am trading the Khartago in for full credit.
  • Serendipity
    edited May 2007
    No problem. What about the Azur 540D?
    VR3 Posts: 29,549
    edited May 2007
    Its on the chopping block - but not an immediate chopping block.
  • Serendipity
    edited May 2007
    Thanks. Keep me posted!
    Those monos do look really nice though.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    RT1
    RT1, it has to be lower than .02 amps cause if there is enough voltage to push .02 through a persons heart it will stop it. 50KV is definitely enough to push that much. That thing must have some major step up xformers.
    See I still remember some of the useless facts I learned in tech school oh about a hundred years ago.:D
  • dkg999
    dkg999 Posts: 5,647
    edited May 2007
    I wonder if those mono extremes are up to driving a pair of Magnepan's? I am assuming the wpc is at 8 ohm? I have been watching for a pair of Parasound Halo JC1's, but even used they are a lot more money than the Odyssey mono extremes.
    DKG999
