Holy SonoSub!
124
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    engtaz wrote: »
    Nice, Glad your enjoying it. What about the kids? Do they like it? My kids love the 15" Velo and the 10/12" Velo.
    They sure do. I had Ashley put her hands on the wall while playing on of those bass disk, and she says "why is the wall moving?". No it wasn't excessively loud. I do care about those little ears.
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    I know you take care of your kids just not your ears LOL
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    What did you adjust your ports to?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ben62670
    edited May 2007
    Actually I haven't modified the port yet. Most Music, and movies are set up not to go super deep, and I can't really hear below 30hz anyways. I should whack 10 inches off the port to flatten the hump a little, but I do run the SDA-SRS's which I set at 40-60 anyways. It just sounds to good to mess with. Also a concern is if I shorten it will there be more turbulence in the pipe?
    Thanks Ben
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Lowest bass is felt more then heard. Just drive next to a car with bass driving loud. You probably hear the car rattles better then low bass. LOL
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    ben62670 wrote: »
    Thanks Ben
    Actually.. the longer the port the more turbulance you have. If it sounds good dont mess with it.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2007
    All I know is it sounds good, and stuff falls from the ceiling when I hit it full blast! I don't know how much I trust my Rat Shack meter below 80hz either.
    Ben
  • ben62670
    edited May 2007
    Catastrophe. The cone had separated from the voice coil. SonoSub had recommended a volume of 10 cubic feet. Parts express said 6. Now they are talking about charging me for the replacement of the woofer. To me it looks like the glue failed that holds the cone to the voice coil. I don't know I'll see what they say.
    Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Damn..sorry dude. Hopefully its a manufactures defect, they should replace it.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2007
    jakelm wrote: »
    They are trying to blame it on a large volume cabinet. I have never seen the paper cone separate from th voice coil in such a manner. It has left a bad taste in my mouth. We'll see.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Free air is free air, it shouldnt matter what cuft you have. A ported system has little to no resistance on the driver. Its not like a sealed incloser that has preasure to stop the driver. The spider coils do that. From what I understand.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2007
    Well parts express contacted me today to tell me that they would not be warrantying my sub woofer. They stated that the box was to big. I had had this for only about 30 days, and the cone had separated during WOTW. It is rated at 800 watts RMS 1200 peak. I was putting 350 to it with Adcom power. the distortion lights barely flickered, and the sub stopped working.
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Is parts express the manufacturer or can you go the the manufacturer? That reaks.
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    engtaz wrote: »
    Dayton audio is PE, as far as I know.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    that's what I was scared of. Dang where does it say limites on enclosure size. All I saw we recommended enclosure.
    engtaz
  • ben62670
    edited May 2007
    They want 124.30 to replace the woofer they will eat the shipping.
    I have had better service from the flea market.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    ben62670 wrote: »
    How did the subject of enclosure get brought up?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2007
    jakelm wrote: »
    They asked for my box parameters, and I didn't think that running at 350 watts would kill a 800watt RMS woofer!
    Is there anyway you could pull up a max SPL reading on my sub with win ISD. I can't seem to find how to do it. They are recommending that I use a 5.8 ft box with a 4 inch port at 14 inches to get a fairly flat curve from 25, and up.
    Thanks Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Here with 5.8cuft enclosure... 25hz -3dbs
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Deadof_knight
    Deadof_knight Posts: 980
    edited May 2007
    Well I would have to say Dayton blows then , you know if you did this a second time I could see them not warrantying it . But first time whether its a 5 cube ported or a 10 cube ported driver doesnt know much difference theres no real resistance only mechanical q from the driver.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • ben62670
    edited May 2007
    I am just stuck at do I want to invest in a woofer that I can only power at half throttle (which is plenty for movies) and cough up the $125 clams, or pay double to triple to really put out what I want. My SDA-SRSs go down to 40 pretty darn good.
    Grrrrrrrrrrrrrrrrrrrr
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Check out TCsound. I believe the subs there are not much more. The TC-9 driver comes in 15" and is $215. Looks like one hell of a driver.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Deadof_knight
    edited May 2007
    refurbished 18 inch Fosgate ........they will handle the power
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    good luck
    engtaz
    heiney9 Posts: 25,403
    edited May 2007
    ben62670 wrote: »
    I wouldn't satnd for this from PE. I'd go as far up the ladder as you have to. It's completely bogus and you need to be the squeaky wheel. I don't do alot with PE, but they have been my prefered choice so far. Let them know you are involved in on-line communities that do alot of DIY and that you now can't rec. PE. I certainly wouldn't mention any names of specific sites like CP or DIYAUDIO, etc. But let them know you very unhappy with their service and you have no choice but to let others know of possible problems getting things taken care of at PE. Don't threaten, kust politely mention it ina concerning way.
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    well put H9
    engtaz
  • Deadof_knight
    edited May 2007
    Yes keep it professional and you will get far.... when you get a no answer just ask for their supervisor..and go on....
  • ben62670
    edited May 2007
    I already put out the $125 to get the replacement. I did spend quit a bit of time with them. Sales manager, and techs. The thing that gets me is the cone broke at the base near the voice coil. The paper tore. So when the paper tore it obviously scarped the insulation on the voice coil, and burnt part of it. I have never seen a driver come apart this way. I got the new driver today. I hope I have better luck with it. I have fried speakers over the years, but this one was definitely defective.
    Ben
  • Mazeroth
    Mazeroth Posts: 1,585
    edited May 2007
    ben62670 wrote: »
    I've been an active member on the PE forums for years and I've seen them do insane things to make customers happy. I can't believe they wouldn't help you out. I would DEFINATELY post about this over on their forums (you don't have to register to post, which is nice).
    http://www.pesupport.com/cgi-bin/config.pl
  • ben62670
    edited May 2007
    Mazeroth wrote: »
    Thanks for the heads up.I will do that.
    Ben
    Ben
