Denon + Rotel Triggers
Sansui
Sansui Posts: 372
I'm thinking of trying to find a Rotel RB-985 to go with my Denon 887 AVR. From what I can determine (from a downloaded manual) that Rotel doesn't require a trigger, correct?
According to what I read (detailed specs) on my Denon, it has an "assignable" 12 v(dc or ac?) output trigger. I give up. If it's got one, I can't find it on the back of my unit or in the manual. What am I missing *this* time?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
  • janmike
    janmike Posts: 6,146
    edited May 2007
    Very small 1/8" jack. 12v trigger is an option not a requirement.
    Michael ;)
    NORTH of 60°
  • janmike
    edited May 2007
    According to the chart there is no 12v trigger for your 887. Perhaps your manual is for more than model and it may show it for another model.
    Denon Product Comparison
    Michael ;)
    NORTH of 60°
  • engtaz
    engtaz Posts: 7,674
    edited May 2007
    Buy a 12v power plug to 1/8 jack and plug into back power plug of denon and 1/8 into rotel
    engtaz
  • Sansui
    Sansui Posts: 372
    edited May 2007
    janmike wrote: »
    For the Rotel, correct? I don't remember any mention about it when I read their manual.
    If it's an option and doesn't have to be used then what does it do? If the amp is off it will turn it on like the main power switch does?
  • Sansui
    Sansui Posts: 372
    edited May 2007
    janmike wrote: »
    You're correct. I missed the fact that there was no check mark for that feature. Duh...
  • Sansui
    Sansui Posts: 372
    edited May 2007
    engtaz wrote: »
    What kind of plug (AC or DC?) is it and if I need one where would I find it?
  • engtaz
    engtaz Posts: 7,674
    edited May 2007
    regular a/c plug to 12v dc 1/8 plug into yhe back of your AVR.
    engtaz
  • engtaz
    engtaz Posts: 7,674
    edited May 2007
    Radio Shack
    engtaz
  • Sansui
    Sansui Posts: 372
    edited May 2007
    engtaz wrote: »
    So you're talking about a 12vdc rectifier into a 1/8" plug. Got it. Let me guess, the "tip" is "+".
  • engtaz
    engtaz Posts: 7,674
    edited May 2007
    for some reason the 12v trigger's are standard Go figure nothing else is. LOL
    engtaz
  • doug lang
    doug lang Posts: 261
    edited May 2007
    Just something i found which worked with my 991 rotel. As you know the 991 does not trigger. So i bought a unit from http://www.bitsltd.net/ This comes with a 12v lead. The product is fairly knew and it worked. With this power strip i was able to trigger on my entire system through my Sunfire. Just a thought.
    Oppo bdp 93 Blue Ray
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Polk LSiFXs (surrounds)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • Sansui
    Sansui Posts: 372
    edited May 2007
    doug lang wrote: »
    With the link you supplied I couldn't find it. All I could find was surge protection outlet strips. What lable do they give it?
  • doug lang
    edited May 2007
    The strip i received is new and i don't think is pictured. I would contact them, and ask about the 12v strip which i have. Sorry i don't have their name, but they were most helful.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • doug lang
    edited May 2007
    I put a call to them,gone for the day. I will try back for info.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
