Denon + Rotel Triggers
Sansui
I'm thinking of trying to find a Rotel RB-985 to go with my Denon 887 AVR. From what I can determine (from a downloaded manual) that Rotel doesn't require a trigger, correct?
According to what I read (detailed specs) on my Denon, it has an "assignable" 12 v(dc or ac?) output trigger. I give up. If it's got one, I can't find it on the back of my unit or in the manual. What am I missing *this* time?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
Very small 1/8" jack. 12v trigger is an option not a requirement.Michael
NORTH of 60° -
According to the chart there is no 12v trigger for your 887. Perhaps your manual is for more than model and it may show it for another model.
Denon Product ComparisonMichael
NORTH of 60° -
Buy a 12v power plug to 1/8 jack and plug into back power plug of denon and 1/8 into rotelengtaz
For the Rotel, correct? I don't remember any mention about it when I read their manual.Very small 1/8" jack. 12v trigger is an option not a requirement.
If it's an option and doesn't have to be used then what does it do? If the amp is off it will turn it on like the main power switch does?Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
You're correct. I missed the fact that there was no check mark for that feature. Duh...According to the chart there is no 12v trigger for your 887.Be gentle, I'm new to all this...
What kind of plug (AC or DC?) is it and if I need one where would I find it?Buy a 12v power plug to 1/8 jack and plug into back power plug of denon and 1/8 into rotelBe gentle, I'm new to all this...
regular a/c plug to 12v dc 1/8 plug into yhe back of your AVR.engtaz
So you're talking about a 12vdc rectifier into a 1/8" plug. Got it. Let me guess, the "tip" is "+".regular a/c plug to 12v dc 1/8 plug into yhe back of your AVR.Be gentle, I'm new to all this...
for some reason the 12v trigger's are standard Go figure nothing else is. LOLengtaz
Just something i found which worked with my 991 rotel. As you know the 991 does not trigger. So i bought a unit from http://www.bitsltd.net/ This comes with a 12v lead. The product is fairly knew and it worked. With this power strip i was able to trigger on my entire system through my Sunfire. Just a thought.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
With the link you supplied I couldn't find it. All I could find was surge protection outlet strips. What lable do they give it?Just something i found which worked with my 991 rotel. As you know the 991 does not trigger. So i bought a unit from http://www.bitsltd.net/ This comes with a 12v lead. The product is fairly knew and it worked. With this power strip i was able to trigger on my entire system through my Sunfire. Just a thought.Be gentle, I'm new to all this...
The strip i received is new and i don't think is pictured. I would contact them, and ask about the 12v strip which i have. Sorry i don't have their name, but they were most helful.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
I put a call to them,gone for the day. I will try back for info.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
