Exploded Rifle
Demiurge
Here's a mistake you only need to make once.
Shiny new, high-powered deer rifle.............. $1200.00
Quality, high-powered scope........................ $ 550.00
Bore sighting device..................................... $ 140.00
Forgetting to remove the bore sighting device prior to shooting? Priceless!
Thank God it wasn't mine!
Post edited by Demiurge on
You know... they tried to do this on Mythbusters for an entire episode, and NEVER got a gun (though I think they exclusively used shotguns) to peel back like that, even after WELDING the end closed and purposefully weakening the barrel.
So I meet this picture with a bit of skepticism.
If you will it, dude, it is no dream. -
So how did the shooter make out in this?My equipment sig felt inadequate and deleted itself.
bobman1235 wrote: »You know... they tried to do this on Mythbusters for an entire episode, and NEVER got a gun (though I think they exclusively used shotguns) to peel back like that, even after WELDING the end closed and purposefully weakening the barrel.
Yep, I know that they couldn't do it, but apparently :rolleyes: it's legit. Some guy posted it over at THR. Appears to be confirmed by some there. If it's a scam, a bunch of members there in good standing are in on it. -
I think it's cool regardless
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
So they are tying to tell us that the material that has the least strength in that equation is the gun barrel...which starts out made from a solid rod of high alloy Chrome Molybdenum steel with a tensile strength in excess of 100,000 lb per square inch (which are designed with greater strength than the shotgun barrel Mythbusters were testing). They want everyone to believe that barrel will be split before the bore sighting device is detroyed and forced out. I don't thik so. Hoax!"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
agreed, hoax. I watched that mythbusters (pretty good show if there isn't much else on, BTW) and they didn't get results that were anything like that. No way would the barrel peel back that much, even if it did give away.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I don't buy it. Its too clean, too perfect. Four equal clean splits? No way.
I don't believe this either.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/-N_jlF-sRqk"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/-N_jlF-sRqk" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object> -
Well met Demi:DI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
On Mythbusters they used a couple rifles as well as shot guns and they just couldn't get it to do it like the pic. The used and old Calvary rifle and it somewhat exploded the barrel but that was because the material used way back then was very weak compared to today's material.
It could be true.
We had a guy in the race shop who loaded his own "wildcat" loads" one time misread the gram scale and exploded a rifle so bad that the wood stock splintered into his face and shoulder.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
I don't think anyone questions whether a rifle can explode, but rather can it explode LIKE THAT, or anything even resembling that.If you will it, dude, it is no dream.
It wouldn't be that perfect. At best it qould have bulged and cracked the barrel. The barrels are designed to handle all of the pressure from a normal load contained within the barrel (worst case scenario) with no chance of injury. Readalot: Was it the barrel or chamber that blew up? My guess is something in the chamber blew.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Wait, was the guy's name Elmer Fudd? In which case I retract any objections.If you will it, dude, it is no dream.
I didn't get to see it jd but you are probably right on with your guess.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
fake!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It could be true.
That's what they're claiming. Not factory loads. Which I doubt MB was messing with.
Either way, knowing the cost of that rifle, it's one hell of an expensive stunt.
Having been around firearms for a very long time it is possible. The perfect look of the split is what's questionable for me. A number of things would have need to be exactly right, or wrong, as it were. -
Did they say who made the rifle?polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
bobman1235 wrote: »Wait, was the guy's name Elmer Fudd? In which case I retract any objections.
Yeah...but that only works if Bugs sticks his finger in the barrel...not some bore sighting device! :rolleyes:"Just because youre offended doesnt mean youre right." - Ricky Gervais
Looking at the way the bore sight peeled before it left the barrel it very possible could be true.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Or ties the barrel in a bow.....
There is no way that barrel banana peeled all the way back like that. I don't care if they were using triple loads in an aluminum barrel. When a barrel goes bad it just has a bulge, and a split in it. Even Damascus barrels don't "explode", they just separate. When there is a crack in the barrel the explosive gasses just vent out where it first split.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
c'mon fellas. it's easy to solve what happened here. it was cut with a saw. notice the barrel only splinters up the the stock and no further. you tellin' me the wood stock offers up that much reinforcement for the barrel to bring the rip to a stop?
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
This happens all the time, I have witnessed and I have been hit with shrapnel from this and still bare the scars from a shotgun blowing up. I have shot competition rifle and shotgun and 1000 yard benchrest where everything is pushed to the limit.
I saw mythbusters also and they just didn't do the right thing to get it to happen.
I have a friend who's shotgun blew up and got me, he had to have three fingers sewn back on. He still does not have full use of that hand.
As for the barrel split to where the barrel meets the stock that is exactly how most will split. I have also seen them split almost all the way back to the action. And I have seen them blown out the side and with some where they blew straight back and sheered the locking lugs.
Each barrel is tested and rated to certain pressures and has nothing to do with Size of the bullet Like a 45/70 at 19,000 lbs of pressure to a 223 (24 Caliber bullet) at 54,000 Pounds of pressure in the barrel. -
split that 'perfectly'? ........
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
http://fieldandstream.blogs.com/gunnut/2006/11/why_rifle_maker.html
http://message.snopes.com/showthread.php?t=6311
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
I would have thought the bore sight tool would have just shot out. Thats crazy.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I definitely stand corrected on this one.If you will it, dude, it is no dream.
