New Hummer Install Recommendations..?
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2007
    Phew...was hoping to hear that.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2007
    You think so, blackmax? Maybe so, maybe so.
    I would've gotten more power for the components, though. That PDX4.150 is what I'd put on ONE set of components. If I'm reading the specs about it right, it puts out 150x4 into 2 ohms, meaning it'll be putting out about 75x4 into your 4ohm speakers. I have 75 watts running to each tweeter and each mid in my Jeep. While that's admittedly more than necessary, I really wouldn't want less than 50 per component, especially if you're going with something as nice as the SR6500's.
    I haven't made up my mind for sure with the rear speakers, but I don't *think* you'll be dissapointed running the MOMO line in the back with the SR's in the front.
    I guess the HU is fine...I didn't really look at the video specs. However, it has 2V preamp outputs which, honestly, sucks!. I wouldn't buy anything less than 5 or 6, personally. At the moment I can't remember how many mine's putting out...6, I believe.
    I'm also not enamored (sp?) with your sub choice, but if you're not picky about it and are happy with it, that is the only thing that counts.
    Anyhoo, even with the nit-picky stuff I'm quarreling over, you certainly have a MUCH better system than stock, and still WAY better than what a lot of people are running for aftermarket.
    Here's to hoping you're blown away by it! :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • audiobliss
    edited April 2007
    I might would contact Toxis and see if his SR124DVC sub is still available. Probably a bit more expensive than your Apline you picked out, but boy would it tear it up.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,734
    edited April 2007
    audiobliss wrote: »
    When did you replace you 860 with something thatll put out 5 or 6V?
    -Cody
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2007
    That Alpine amp will be putting out 150 watts RMS in either a 2 ohm load or a 4 ohm load ;).
    I myself am only running a little under 100 watts RMS to my components up front, and they sound very nice. The other two channels are going to my rear speakers (really only used when I have passengers in the car).
    As far as the voltage..... 2V's should be fine....
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • audiobliss
    edited April 2007
    Oh, forgot the new Alpines were regulated like JL's amps...come to think of it, I might not have ever known. That should be pretty sweet, then.
    I guess my only quibble now, then, is the sub and HU. I still think you need higher preouts.
    And thanks for pointing out my mistake, Cody. I looked it up; my HU puts out 6.5V.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    edited April 2007
    More like 4.5ish:D
    -Cody
  • audiobliss
    edited April 2007
    Which is still 2.5ish (at least) more than a manufacturer rating of 2V.
    Do I have to have a perfect system to voice my opinion?
    If so, you should stay out of it. I can't remember the last time you actually had a system.
    :D:D:D:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wingnut4772
    edited April 2007
    Ok I gotta tell you guys it sounds SWEEET!!!! I Man those SR6500's are smooth. I can't wait to hear them all broken in.
    As far as the sub goes..it's fine I have it turned down but it will definitely boom. They seem to have integrated it very well at the shop. The Alpine amp plays really nice and clear to a volume way louder than I will ever listen for any extended time. It was my understanding that it was 150 at 4 ohm per channel. That's why I got it for the Polks.
    Now I just reading manuals and trying to figure stuff out. I pretty much have everything set flat how I like it.
    The Momos seem to be just fine doing back up so that is cool too.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • audiobliss
    edited April 2007
    Sweet!!!! Glad you're digging it! :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wingnut4772
    edited April 2007
    I am just shocked at how good the ipod actually sounds through this thing. All my music is Apple Lossless but I never heard it sound this good.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    Nice head unit
    engtaz
  • exalted512
    edited April 2007
    audiobliss wrote: »
    :D:D:D:D
    But my radio still has 6.6V rms outputs :)
    I would love for CEA to start rating head units...
    -Cody
  • wingnut4772
    edited April 2007
    exalted512 wrote: »
    -Cody
    I can't imagine what that difference ight be to me..? This sounds really good.:confused:
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2007
    Told ya so again! Running down to your local shop and talking to the pros and hearing the gear is always a good way to do things. ;)
    There wont be any difference. The amps have a gain on them which sole purpose is to match the head units output signal with the amps input. Higher voltage is good for getting the noise floor up nice and high but from an aftermarket deck youre not going to have a problem. 2 volt preouts will be fine.
    Those 6500's will fatten up quite a lot over the next couple weeks. Youll love them more and more!
    Excellent choice on gear also! Speakers, amps and everything is top notch!
  • 1996blackmax
    edited April 2007
    Glad things came out good for you.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • wingnut4772
    edited April 2007
    Thanks. I think the SR 6500s will break in nicely also and I am going to be listening for the difference. I won't be getting that much break in time on them though so it might take a while.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • black magic
    black magic Posts: 669
    edited April 2007
    Quite the nice setup you've got there. I was looking at getting that same 4 channel amp for my momo's but figured 100 would be fine. After all of this godly talk about those SR's I really wish I had a few extra hundred lying around.
  • wingnut4772
    edited April 2007
    If you are not in a hurry, I think I saw a few on Ebay for less than retail.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • black magic
    edited April 2007
    No, actually i'm not in a hurry at all. lol. I think I've spent more than enough on car audio. I'm planning on getting an engine swap for my car this summer. Perhaps some other little mods also. Then i gotta save again for school. Needless to say, I've surpassed my budget in the car audio area. lol. However, next summer (or if I strike gold) I'd like to get those SR components. In which case I'll probably also get that same Alpine amp or something similar. I've also been buying stuff for my brother b/c I'd feel bad if I decked out my car and didn't do anything for him. His taste isn't as big as mine so I have no problem doing it.
  • 1996blackmax
    edited April 2007
    I would try to go the authorized way....you can usually get the shops to come down in price some.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • wingnut4772
    edited April 2007
    I like warranties too.:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • MacLeod
    edited April 2007
    True. But its still comforting to know I have that 5/60,000 bumper to bumper warranty. :D
  • black magic
    edited April 2007
    lol. I'm just messing with you guys. Regardless of how useless a warranty might seem, obviously its still always a good thing to have.
    Finish my last exam today! And the weather outside is looking better everyday. Finally I can start my install tomorrow!
  • exalted512
    edited April 2007
    I envy you.
    -Cody
