Building a Dedicated Audio Room
245
  • halo
    halo Posts: 5,618
    edited April 2007
    seen this? link
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2007
    Look Here for the fixed, media type humidifier. I recommend the "upflow" model.
    Carl
    Carl
  • strider
    strider Posts: 2,568
    edited April 2007
    Halo wrote: »
    seen this? link
    Good link, I was just checking out their line of sound deadening products yesterday. Have you used any of them?
    Wristwatch--->Crisco
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2007
    schwarcw wrote: »
    Hi Ricardo!
    I have to ask, the foil backed insulation on the top side of the basement wall, is the insulation for the above grade portion of you wall?
    I owe you information on the humidifier. Basically, a solenoid valve opens a water valve when the furnace fan motor kicks on. The water flows down a ceramic media inside your hot air duct exiting the furnace. The excess water that is not evaporated collects and drains out to a floor drain (just like the condensate on your AC cooling coil).
    Wall looks good! Keep up the good work!
    The whole wall is below grade; not sure why the builders insulated only 1/2 of it, though I am leaning towards cost.
    Thanks for all the humidifiers info.
    SOPA
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2007
    I believe code only requires you to insulate 3' below grade. Below 3' you are then below the frost line and the earth is actually in the mid 50's F. It can only help to insulate below.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • halo
    halo Posts: 5,618
    edited April 2007
    strider wrote: »
    No I haven't. I just remembered coming across that info when I was looking into acoustic treatments a while back.
  • markmarc
    markmarc Posts: 2,309
    edited April 2007
    HT:
    i was thinking of RealTraps, or something homemade along those lines. You may also want inquire about a product called QuietRock, sound deadening drywall. Comes in various levels, if your budget allows.
    Former Staff Member TONEAudio
    2 Ch. System
  • Ricardo
    edited April 2007
    markmarc wrote: »
    HT:
    My plan is to use panels from GIK; have good feedback and seem to be one of the cheaper (if not the cheapest) in the market. After finishing the room I will be done with DIY for a long while, so will buy them.
    I'll use normal drywall with the green glue; this should be enough for my needs.
    http://www.greengluecompany.com/
    Thanks!!
    SOPA
  • Ricardo
    edited April 2007
    Framing and electrical done; during the week I'll build the box for the sump pump, and Saturday is drywall day. Should finish the ceiling this weekend, and depending on how much work I can do during next week, walls might be done a couple of weeks from now.I think I'm going to beat the 2 month target.
    SOPA
  • george daniel
    george daniel Posts: 12,096
    edited April 2007
    very nice work indeed,, someone's been busy
  • Cursed1
    Cursed1 Posts: 66
    edited April 2007
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Nice work. You could always come to FL and build me one. LOL
    engtaz
    engtaz
  • Ricardo
    edited April 2007
    Getting going with the drywall phase:
    -Insulation for the ceiling:
    -First drywall layer for the ceiling:
    -Green glue applied for the second layer:
    To be continued......
    SOPA
  • george daniel
    edited April 2007
    looking good ,Ricardo,,when is the houswarming party?;)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    you the man. coming along pretty well.
    engtaz
  • Ricardo
    edited May 2007
    Update; have been busy with other things (why do we need to work?????). This week I resumed with the room and am done with drywall.
    First layer of walls; used caulk to seal corners, wall/ceiling and wall/concrete:
    Starting second layer:
    Second layer DONE. Green glue used between both layers; continued with lots of caulk to seal everything:
    I will use textured paint everywhere (popcorn on ceiling and sand texture on walls), so I decided NOT to do tape/mud. Just caulk. Paint will cover any imperfection.
    Still need to build the box for sump pump, but will do after I finish painting.
    Still on track!!!!
    SOPA
  • JimBRICK
    JimBRICK Posts: 1,543
    edited May 2007
    keep up the good work I think we all are living vicariously through you when we read this thread
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2007
    Looks like you CD collection is just dying to move in. Looking good man!
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    Don't forget to run 3 dedicated 20 amp circuits to your stereo!
    Ben
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    ben62670 wrote: »
    For sure! I am jealous. It's coming along nicely.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    It coming along fine. Congrats.
    engtaz
  • Ricardo
    edited May 2007
    ben62670 wrote: »
    One dedicated 15 amp. I thought about using a 20, but when I finished the other side of the basement I pre-wired with AWG 14 for this "studio" room....not good for 20 amp.
    And.....we all know 15 amp is enough :)
    SOPA
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Not Tim the Tool man Taylor core values. LOL
    engtaz
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2007
    That Apex DVD player is gonna sound good down there!
  • Ricardo
    edited May 2007
    PolkThug wrote: »
    I know; was thinking on adding an external DAC, but it sounds so good it doesn't need it ;)
    SOPA
  • adam2434
    adam2434 Posts: 995
    edited May 2007
    Just a couple things to consider -
    Caulk will generally open up over time and could show your seams.
    Without mud, the tapered edges of the drywall will show, probably even through textured finish.
    Great work by the way.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2007
    Nice caulk. . . .ing!
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Ricardo
    edited May 2007
    adam2434 wrote: »
    Did you HAVE to say it???
    I know. I thought about that, but:
    1.-I will NOT do any more drywall finishing again in my life. I still have dust in some places from the last time.
    2.-Don't want to spend the extra money in having it done.
    3.-There will be so much coverage with panels that there will be little wall/ceiling to look at.
    4.-I will be busy listening to some tunes.
    5.-I am not doing it for anyone to come evaluate it...I could as well leave it as is :eek:
    6.-Do I sound like I'm trying to justify myself???
    SOPA
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    What eevvvver makes YOU happy is what counts. Go for it.
    engtaz
  • wingnut4772
    edited May 2007
    engtaz wrote: »
    How much for you to come to Miami and build mine out?:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
