Subs with Full Range Speakers
Early B.
Early B. Posts: 7,900
edited April 2007 in 2 Channel Audio
Just curious -- does anyone have/had full range speakers along with a subwoofer? If so, how did it sound compared to running the speakers without the sub? Where did you set the crossover?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    My 7b's are ran full range. They dont have much punch below 40hz, so I added a sub crossed over at 40hz. Once I got the system in phase, the sub really made a difference in the "feel" of the music.
    Also, IMO, when using full range speakers, sometimes you have to sacrifice very low bass for mids and highs. Having a sub, you can place it in the "sweet" spot for bass and place the mains in the "sweet" spot for mids and highs.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2007
    My mags hit down to 35Hz so their pretty close to full range and my 1B's were down in the low 30's as well. Now I have not heard the AR-9's or the amazings, but I have not heard a full range speaker not benifit from a subwoofer of comparable quality.
    On the maggies, I set the x-over between 40-45, the 1B's sounded better in the 60hz range. To me, the sound is just more full than before and a bit more dynamic, granted you need a decent sub. $500 from best buy's not going to cut it.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • pearsall001
    pearsall001 Posts: 5,295
    edited April 2007
    Early B. wrote: »
    Thanks.
    What's going on Early? What are you thinking of doing now? :eek: I've been tempted before with the sub idea. I guess it depends on how much of a bass head you are & what type of music you like. From what I've read almost any speaker, even full range, can benefit from a "good" sub. My only concern is the expense in buying a top notch sub (they ain't cheap) & then to get it to blend in seamlessly. My AAD 2001 monitors hit with plenty of punch down to 25Hz. For me personaly that's plenty. Would they benefit from a good sub - sure they would - but not worth the expense & aggrivation in my book.
    Phil
  • TroyD
    TroyD Posts: 13,124
    edited April 2007
    IF you can find a sub that mates well with your speakers and IF you can get it to blend properly...
    Those are big 'IF's' though...
    BDT
  • dkg999
    dkg999 Posts: 5,647
    edited April 2007
    I have a sub running with my Magnepan 1.6's. It's x-over at 45hz, and it's barely turned up. It's amazing how it just fills in the low end, adding depth and punch, and you don't realize how much until you turn it off.
    DKG999
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2007
    Early,
    A couple years ago I ran towers with an SVS+. If IRC, I had the xover set at 50Hz (the towers spec'd at 35Hz). It worked out well on paper (had a really good freq curve)...I just didn't care for the lumpy bass; I later sold the SVS to I-SIG, who still has it.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    Early - I've been interested in adding a sub to my 2-channel Thiel rig. The Thiel's mid-bass bumps pretty good, but the real low end just isn't there.
    But, it's hard to add a $500 sub to speakers that probably aren't worth quite that much, just to get the extra material from 20hz to 50hz.
    I assume that one day when I have more space (I have zero free space in my apartment right now), I'll add a decent sub. Probably will look for something used in the $200 - $300 range, but not sure much is available at that price point.
    Quick question: If I were to get a passive sub (like the SVSs Russman had for a bit), I would need to go from my integrated's preouts to an amp to a crossover, to the sub, right? A crossover would be needed for most passive subs, correct?
    Haven't used a passive so not 100% sure. Thanks for the help on that quicky, and sorry for jacking your thread. Least it was somewhat on-topic.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Early B.
    edited April 2007
    Just to clarify -- by full range speaker, I mean speakers that dip down at least to about 25 Hz and lower.
  • Early B.
    edited April 2007
    That last sentence is what I'm very, very curious about. I've read that, too, and I'm wondering how a VMPS sub would sound with my VMPS speakers. They use the same megawoofer. I'm thinking the sub would be crossed over at around 30 - 35 Hz, so only the lowest material would be played through the sub. I dunno, just thinking out loud.
    And yes, I'm a bass head.
  • polkatese
    polkatese Posts: 6,767
    edited April 2007
    I have LSi15 paired with REL Storm III, Brad. It blends very nicely, and no tweaking of the crossover. Plug and Play and it sounds great.
    The difference is, without REL, LSi15 bass sounds sloppy, with the combo, the bass sounds very tight and detailed.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • unc2701
    unc2701 Posts: 3,587
    edited April 2007
    I've done it... each set up is going to vary, but as a general tip, I'd say to cross it over as low as the sub will allow with a steep slope (if you have that option)... and you might even want to send a filtered signal if you don't have a slope setting.
    Backburner:Krell KAV-300i
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Early B. wrote: »
    To be honest, not many "average" full range speakers can do this. If yours can do this, then I would guess that they are high quality and I would think twice about mixing them with a sub.
    Most higher end "full" range speakers I have heard dip down below 35hz, but with not much "oompphh". So a good sub would fill in the blanks down in the subsonic area.
    But it all depends on how much bass you want. I would add because I am a bass head as well...:p Music or movies..I love it when my pictures shake on the walls and pots fall in the cabinets and glasses vibrate off the table...:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    edited April 2007
    If I had mains that dipped into 25Hz, even down 10dB, I wouldn't phutz with a sub---but that's me.
  • pearsall001
    edited April 2007
    Early B. wrote: »
    In theory you would assume that the VMPS sub would mate well with the VMPS speakers. A couple others come to mind - REL, JL Audio Fathom fl 13, ACI Titan XL, & Maestro XL. Now don't forget these babies are expensive. Out of curiuosity I tried my SVS for 2 channel & it was a disaster. They are dynamite for HT but don't handle the delicate stuff very well. At least in my opinion. Give VMPS a call & ask what they recommend. It sounds like a fun journey.
  • AndyGwis
    edited April 2007
    Has anyone tried a Thiel Sub? I was checking their website for info on servicing my speakers, and their Smartsub subwoofers look awesome! Never seen or heard one, but they look great, are Thiel (so you know they're probably good), and have sick specs. Their 10in has a 500watt amp and 99db output at 20hz. The bigger ones are even more impressive.
  • AndyGwis
    edited April 2007
    OK, nevermind. I just googled Thiel SmartSub and see the SS1 has a retail price of $2900. OUCH!!!
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited April 2007
    I don't have the most "HI-FI" system. That said I do not have my 3.1's bi amped. I have them crossed over at 80 hz filtered through the pre. The Adcom is pushing the 3.1's and the carver is running the VMPS. I enjoy this set up very much.
    The vmps is fast enough to deliver clean bass and meshes well with the 3.1's
    I don't have to push the Adcom or the Carver very hard.
    It works for me
    Steve
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2007
    steveinaz wrote: »
    I would agree, and even make that 30 Hz. Blending a sub for a 2 channel rig is not an easy task.
    SOPA
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2007
    I find it totally content dependent. If the track is fairly bass heavy, I listen both ways to see which sounds best. With some things bass is just too hot throwing off the overall balance, but others, especially newer material that's mixed to take advantage of the sub, want it. For example, Fiona Apple's first album is extremely bass heavy, the SDA 1Cs are plenty. Porcupine Tree's DVD As are as well, but you want the bass from a sub to achieve the impact they intend from their live performances. I run them full or cut at 60. Though I get good response down to the mid 20s in my room, the 1Cs don't deliver near the impact of the SVS +.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Normanality
    Normanality Posts: 297
    edited April 2007
    HTrookie wrote: »
    Absolutely agree!
    I've got the Innersound Eros Mk II's rated at 24 Hz. to 27 KHz. +/- 2 dB and I also have a Martin Logan Depth sub just sitting here unused. I tried to see if I could integrate it into my 2 channel with different placements around the room and trying all the phase adjustments. Since the mains already are like having stereo subs, I couldn't get any type of decent balance, so the sub just sits quietly 'unplugged' in the corner.
  • halo
    halo Posts: 5,616
    edited April 2007
    Only time you need to go that low is when you listen to Yello Norm :p;):D
    Most music doesn't dig deep enough, unless you like pipe organ music :confused:
    SCompRacer Posts: 9,112
    edited April 2007
    Absolutely agree!
    Like you needed any more bass output.....LOL
  • Early B.
    edited April 2007
    I'd love to try it out. Problem is -- my HT sub is passive with no external crossover, so I can't hook it up directly to my 2-channel pre. Maybe I'll borrow my friend's SVS to test it out.
    The other problem is -- WAF. I only have one place to position the sub which is in line with the fronts.
    Hmmm. Maybe another DIY sub project?
    So many choices....
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2007
    For my rig and placement having a sub is absolutely necessary. Even with my big SRS's I had a massive canyon (close to 10dB) in the mid-bass region from about 45-70hz edge to edge. There's an awful lot of bass information in those frequencies.
    With some time and patience trying different settings the SVS Steve sold me has worked wonders. It easily filled in my canyon and gave me a nice gentle 4dB rise all the way down to 25hz.
    With my room volume, I could probably use 2 of the PC+ 25-31's or a dual-driver Ultra box for movies, but for music the single cylinder is awesome.
    I will admit that with the bi-amp setup I have going now the SVS may not be quite as fast as I would like, but for what Steve sold it to me for and what the new Ultra boxes or a REL are going for I'd be better off spending money on a source upgrade and/or Halo amps.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2007
    Never heard a sub really add anything to make the rig sound more musical. More bass sure, more musical, well, not for me.
    RT1
  • madmax
    madmax Posts: 12,434
    edited April 2007
    It is so nice to not have a sub because of not having to futz around with it. Pretty much you become content with the curve of your present system, no matter what it is. With that said it sure would be nice to have one crossed over really low just to pick up that occasional sound. My guess is you should be able to play through 90% of your material without ever noticing a sub is connected. I've heard the Bag End sub and it tends to do this. Know nothing about it other than the name. Heard it (I think :)) but never saw it.
    madmax
    Vinyl, the final frontier...
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Yes 3.1's with 15" sub
    engtaz
    engtaz
    tonyb Posts: 33,072
    edited April 2007
    Early,maybe look for an amp with lots of juice to control those big woofers and tighten things up a bit.That was my main worry on my speaks,3 12 in on each side.Needless to say I don't miss a sub on music,maybe movies,but not music.Or look into your cables,when I switched,I noticed a huge improvement in the quality of the lower end...well,top end too.Good luck hunting.
  • Early B.
    edited April 2007
    tonyb wrote: »
    The issue is my amp. My amp is 200 wpc. The Odyssey amp I tried was less than that, but the bass was 10x more impactful. It's interesting because the reviews of the Marsh A400 says it does bass very well.
    However, I ain't changing out my amp because it sounds so sweet with everything else it does. To me, the bass is a minor issue, but I'm guessing a sub would be nice to experiment with. It's not a necessity by any means, but it should be fun to play around with.
    tonyb Posts: 33,072
    edited April 2007
    Yeah,you'll get that rap style bass but believe me,it wears thin after awhile.The thing that always bugged me was on some recordings,the bass is great,on others,too boomy,was always getting up to re-adjust.Don't have that problem with full range floor standers,and neither should you.Play around if you must with a sub,but make it a decent one or you will be dissapointed.Have you thought about bi-amping,Keeping the Marsh for the top end and finding some muscle for the bottom??Trial and error pal.....trial and error.
