Amps stands!
Pepi28
I was just wondering if anyone here uses one of those amp stands that eliminate vibration going to their amp and if so does it make any difference to the amps performance. Probably a dumb question but who knows. Thanks.
58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
LSic center
LSiFX's sides
LSi7's rears
PS3
Wii
Post edited by Pepi28 on
I have never heard of such a thing... It doesn't seem to me that it would make a difference, but I have been wrong before.
Lots of people us amp stands. Often the amps are extremely heavy and people do not put them in racks. I for one am considering 2 of them to accommodate 2 heavy monos.Michael
NORTH of 60° -
I was going to use two amp stands in addition to my rack when I had my tube amps. More so for ventilation than weight.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Here's another in Canada. I have recently purchased some brass spikes for the Proacs from this guy. His stand look pretty good and he will customized them to your dimensions.
MYESOUNDMichael
NORTH of 60° -
although a tweak, a good amp stand or shelf is a necessity in trying to get all your gear has to give.
RT1 -
Vibration damping devices may or may not make a difference/improvement depending on how well the manufacturer has implemented vibration damping(if any) in the construction of the component. I have had components where vibration damping tweaks made a significant improvement and I have had very solidly built components where such tweaks made no audible improvement.
Another thing to consider is the stability of the floor under the amp. A vibration prone floor could negate any positive effects of a good amp stand.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »Vibration damping devices may or may not make a difference/improvement depending on how well the manufacturer has implemented vibration damping(if any) in the construction of the component. I have had components where vibration damping tweaks made a significant improvement and I have had very solidly built components where such tweaks made no audible improvement.
One other thing to consider. Some manufacturers tune their electronics case to resonate at a certain frequency so as not to interfere with the circuitry. You mess with that and you could muddy up the sound coming out of that component.
Case in point; I completely deadend my preamp's outer case with a load of sorbothane pods and sheets. When I listened it sounded like pure mud!!!Horrible! I removed the dampening materials and viola, back to normal. Now isolating the case from vibrations is a different story all together. -
That's yet another example of "everything effects everything" in audio.:p~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
