Amps stands!
Pepi28
Pepi28 Posts: 248
edited April 2007 in Electronics
I was just wondering if anyone here uses one of those amp stands that eliminate vibration going to their amp and if so does it make any difference to the amps performance. Probably a dumb question but who knows. Thanks.
58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
Post edited by Pepi28 on
  • zingo
    zingo Posts: 11,258
    edited April 2007
    I have never heard of such a thing... It doesn't seem to me that it would make a difference, but I have been wrong before.
  • janmike
    janmike Posts: 6,146
    edited April 2007
    Lots of people us amp stands. Often the amps are extremely heavy and people do not put them in racks. I for one am considering 2 of them to accommodate 2 heavy monos.
    Michael ;)
    NORTH of 60°
  • halo
    halo Posts: 5,616
    edited April 2007
    I was going to use two amp stands in addition to my rack when I had my tube amps. More so for ventilation than weight.
  • beardog03
    beardog03 Posts: 5,550
    edited April 2007
    like Mike said...
    Lots of us "us" amp stands...!!!
    www.adonacorporation.com
    (no affil) of course
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • janmike
    edited April 2007
    Here's another in Canada. I have recently purchased some brass spikes for the Proacs from this guy. His stand look pretty good and he will customized them to your dimensions.
    MYESOUND
    Michael ;)
    NORTH of 60°
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2007
    although a tweak, a good amp stand or shelf is a necessity in trying to get all your gear has to give.
    RT1
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2007
    Vibration damping devices may or may not make a difference/improvement depending on how well the manufacturer has implemented vibration damping(if any) in the construction of the component. I have had components where vibration damping tweaks made a significant improvement and I have had very solidly built components where such tweaks made no audible improvement.
    Another thing to consider is the stability of the floor under the amp. A vibration prone floor could negate any positive effects of a good amp stand.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2007
    One other thing to consider. Some manufacturers tune their electronics case to resonate at a certain frequency so as not to interfere with the circuitry. You mess with that and you could muddy up the sound coming out of that component.
    Case in point; I completely deadend my preamp's outer case with a load of sorbothane pods and sheets. When I listened it sounded like pure mud!!!Horrible! I removed the dampening materials and viola, back to normal. Now isolating the case from vibrations is a different story all together.
    treitz3 Posts: 20,008
    edited April 2007
    That's yet another example of "everything effects everything" in audio.:p
