Not getting enough bass on the RTi10's
1lakerfan
1lakerfan Posts: 112
edited May 2007 in Speakers
I have the Polk Audio RTi10's and love them. I have read alot of reviews on this website and many of the people say that the bass is so good you dont even need a subwoofer. When I listen to music whith just the RTi10's I dont here that much bass. Do you need good speaker wire? I am using cheap speaker at the moment. I think the guage is like a 22. I do have an excellent subwoofer (Velodyne DLS-400R) so Its not that big of a deal to me but, I just wanted to know. The RTi10's are currently hooked up to a Denon AVR-2807,I am using the Polk Audio CSi5 as the center and some 3 Onkyo speakers as my surrounds. How do I get the bass out of my speakers.
Post edited by 1lakerfan on
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2007
    Sounds like a set-up problem.
    Are the fronts set to small or large?
    What is the crossover set at?
    My Rti's go pretty dang low with 220 wpc from a separate amp and quality speaker cables.
  • hangon
    hangon Posts: 228
    edited April 2007
    I had a Denon AVR-3805 hooked up to my old 10's and I was getting more bass from them than the rti12's. Then I hooked up my CineNova 300wpc amp #10 wire, and now I have more bass than the wifes china hutch can handle. You need power!!
    HT Theater
    SRS-SDA 2.3tl RDO's
    Custom Center made out of a RTA15tl
    Pioneer Elite SC-25 Receiver
    CineNova Grande 5 channel Amp
    Klipsch KA-1000-THX Sub Amp
    (2)Klipsch KW-120-THX Subs
    Basement System
    SRS-SDA 1.2 upgraded Xover
    ADCOM GFA 5500
    ADCOM GFA 5503
    Yahama P7000S Pro Audio Amp
    dbx 120x-ds Sub-harmonic Synthesizer
    2-JBL 4645C Subs
    1-Paradigm SW2200 Sub
    Klipsch Reference in wall's
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    Change your speaker wire first, and then get a good 2 channel amp. Watts don't mean anything when it comes to a receiver being able to handle the currant demands of good speakers when the bass kicks in.
    Welcome to Club Polk
    Ben
    Ben
  • 1lakerfan
    edited April 2007
    I had my fronts set to large but then put them back to small since it didnt seem like I was getting much bass from the speakers and it was taking away from my subwoofer. I dont really know about all the technicle stuff about home theatre but the crossover is set at 80 on my reciver. Thats what audioholics.com recommeneded. Heres the link to the pictures of my system.
    http://forum.ecoustics.com/bbs/messages/3/297154.html
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited April 2007
    If you weren't getting much bass even if they were set to large you may want to double check your speaker wires. Make sure that the positives on the receiver are hooked up to the positives on the speakers. Same for negatives.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • 1lakerfan
    edited April 2007
    Mike
    There are four terminals on the back of the speakers where the speaker wire connects. I put them on the top two terminals going across leaving the gold plate under the terminals right?
  • Midnite Mick
    edited April 2007
    Sure, that's fine...just make sure that the red post on receiver is hooked up to the red post on the speaker with the same individual run of wire. Same goes for black. If this is correct then it is about the best you can do for your given receiver until you get more power. You could also try and bump up the bass a few decibels if your receiver has those controls within it.
    Good luck,
    Mike
    Consonance cd120T
    Usher CP 6311
  • dane_peterson
    dane_peterson Posts: 1,903
    edited April 2007
    You could also try using the "LFE + Mains" for subwoofer output.
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    beyond checking the speaker connections.. also check to see if maybe your bass adjustment isn't set to - 2 or something like that.. set to zero for both bass and treble.
    post a picture of your system if you can.. speaker placement can sometimes affect bass output as well.
    first order though, would be to get heavier gauge speaker wire.. go for 14 guage at the minimum, 12 would be great, 10 is the largest i'd go. 12 is just right for most people.
    PolkFest 2012, who's going>?
  • JeffBowser
    JeffBowser Posts: 17
    edited April 2007
    I have the same issue with my RTi10's. They make plenty of bass to hear, but not much bass to FEEL, which is what I want. My sub compensates nicely, but my opinion is these speakers simply do not have big enough subwoofers built in to generate really pounding bass. I will say, though, if you are using 22guage speaker wire, that's waaaay too small, you'll be current limited there...
    F1nut Posts: 52,008
    edited April 2007
    IMO, people expect too much bass when listening to music because of the over emphasis on bass from HT and the over use of subwoofers in general. The key to good music reproduction is balance, not pounding bass.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited April 2007
    I agree...
    as if watts, quality over quantity any day of the week.
  • Midnite Mick
    edited April 2007
    A lot of people do confuse tight, controlled bass with a lack of bass.
    Mike
    Consonance cd120T
    Usher CP 6311
  • surfntomm
    surfntomm Posts: 185
    edited April 2007
    definitely get thicker gauge wire, 22 ga is like dental floss. my rti70's sounded infinitely better when i went from 18 ga to 12 ga on some sold **** pioneer receiver and now they sound great with my denon. once you upgrade your wire you will love the sound im sure. good luck.
    treitz3 Posts: 20,121
    edited April 2007
    1lakerfan wrote: »
    When I listen to music whith just the RTi10's I dont here that much bass. How do I get the bass out of my speakers.
    I have the Rti-10's and trust me when I say that there is no shortage of bass [or midbass]. Alot of it has to do with your amplifier. I have mine hooked up to a Carver M1.5t and there is absolutely no shortage of feeling the music accurately when played at performance levels. IMO you do need a sub to complete the entire spectrum of frequencies, just make sure that they are blending well [sub and speak's]. I have switched the amp out with other (lower powered, including Best buy's top of the line Denon [forgot the model #]) amps and the bass seems to dissapear a little bit [to alot], to the point where you don't feel the punch. The Rti'10s will reverb a 10x13' room quite nicely when suppied with an ample amplifier.
    See if you can borrow another amp that has some accurate juice and you'll see exactly what I am talking about.
  • MADGSF
    MADGSF Posts: 603
    edited April 2007
    I agree with most of the above and do think you should try heavier wire. However I think your main issue is a lack of power. I recently added the amp in my signature to my system and now run my RTi-10s full range and turn off the sub for music. It helped at all volume levels and with all kinds of music.
    Before with just the Elite powering them I had to use the sub if I played music which in my room would make some music sound too boomy, if that’s the right word. Now the sound is much more full, rich and stealing a term from F1 balanced.
    For HT I set the sub to “Plus” and the Rti-10s to “large” and there was a positive change. I did not think for HT the change in impact would be that great since I have an Ultra sub but it hits even harder now!
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • 1lakerfan
    edited April 2007
    danger boy wrote: »
    Heres the link to my set up.
    what should the crossover be set at? I do know that the speaker wire that I am using is to thin but will the speaker wire make that big of a difference? I thought for the most part buying thicker speaker wire was to help make the spekaers last longer.
  • 1lakerfan
    edited April 2007
    can someone give me a link to a website where I can buy 12 guage speaker wire at a good price. And what type of connectors should I use?
  • zombie boy 2000
    edited April 2007
  • 1lakerfan
    edited April 2007
    what brand of speaker wire should I buy. Everyone says that monster is a ripoff even though I am using that brand for my subwoofer.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2007
    Welcome 1LF! You were given a very good site right above your last post. These are well made cable & they won't bankrupt you.
    www.bluejeanscable.com
    Check them out.
  • crd2002
    crd2002 Posts: 174
    edited April 2007
    you are definately missing a amp cause I have the rti12 and a earthqauke cinenova7 and if I want I dont even have to use the velodyne sub there is plenty of bass coming from my speakers
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
  • Ern Dog
    edited April 2007
    80 Hz seems to work well for most people. Run some experiments and see what sounds good to you. I've got mine set at 40hz.
    Signal cable is also a quality company that makes decent cables at a good price. Plus you'll get a 5% discount if you mention that you're from Club Polk.
  • MSALLA
    MSALLA Posts: 1,602
    edited April 2007
    This is the smartest statment I have ever read about stereo by far. Car audio and rap music has also lead to the misconception about bass. It shouldn't feel like a hammer blow to your head.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
    F1nut Posts: 52,008
    edited April 2007
    1lakerfan wrote: »
    You have much to learn, Grasshopper. Stick around, we'll get you on the right path.
    F1nut Posts: 52,008
    edited April 2007
    MSALLA wrote: »
    We have a winner!
  • 1lakerfan
    edited April 2007
    What type of connectors should I use for the Rit10's. I am looking to buy twelve guage speaker wire. I am also going to buy the Polk Audio FXi5 surround speakers in the future, so should I also use a 12 guage.
    edited April 2007
    1lakerfan wrote: »
    Bananna style clips for the speaker end. I would recommend soldering them on -vs- screw on type deals based upon personal experience [and frustration].
  • MSALLA
    MSALLA Posts: 1,602
    edited April 2007
    I like banana clips, as far as wire goes the choices are endless. Get something you can afford. You can spen $10.00 at home depot or over $1000 from an audio wire mfg.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • JeffBowser
    edited April 2007
    Re:wire - don't let marketing departments fool you. It's all about guage when running speaker wire, not about fancy coatings and dielectrics, etc. (unless you live next door to a power plant and run your speaker wires for miles). Anyway, I reinvestigated my RTi10's last night after perusing this thread (and no, pounding bass did not originate with rap, my young posters). I discovered that my receiver cuts the output to the front speakers at 120hz, even whe I tell it I have large speakers. Deep bass was not even reaching my Polks.
