Common Ground?
Neskahi
Is there a simple way to determine if an amp is or is not common ground?
Thanks.
Thanks.
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
Take a multi meter, and set it for continuity. Take the leads, and test across the speaker grounds. If it has continuity then it is common ground. What kind of amp is it?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Pioneer M-90 at this time. Plan's are to bi-amp with Adcom GFA-535's.
[2.3's]SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
ben62670 wrote:Take a multi meter, and set it for continuity. Take the leads, and test across the speaker grounds. If it has continuity then it is common ground. What kind of amp is it?
Some people call "continuity," "resistance." That what is on my VOM. Or it may just have the omega symbol. -
Thank you Ben. That is kind of what I thought but was not sure.
So, why would a manufacturer make a non-common ground?
On another note, my wife is upstairs hogging the 2.3's and I get them after she
gets sleepy. But more importantly, I have the WAF for a set of 1.2TL's if
I can find them! Any ideas?SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
Non common ground amps are pretty rare. I just guessing that some manufacturers make non common ground amps to have completely different circuits. I have also heard of the positive being common in rare instances.
I hunt Ebay all the time, and craig's list.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Watch e-bay also, and I think those were your 2.3's up for sale a while back. Would have taken them for the wife [put her downstairs],but too far away.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
Mine were 3.1TL's, and I sold them here. I still have my SDA-SRS's:)Neskahi wrote:Watch e-bay also, and I think those were your 2.3's up for sale a while back. Would have taken them for the wife [put her downstairs],but too far away.
Ben -
Neskahi wrote:So, why would a manufacturer make a non-common ground?
In most instances you see non-common ground amps as a result of mono block designs or bridging stereo amps mono. -
Hi all: So if I bridge two stereo amps I would put the multimeter terminals on one negative of each amp to check for continuity. If the ohms read 0, then I'm good to go?
Thanks.
Brett -
On another note, my wife is upstairs hogging the 2.3's and I get them after she gets sleepy.
WOW! that must be awesome to have a wife who likes audio / listening to music so much that you have to wait your turn after her! I wish I could get my wife that interested. Then maybe she wouldn't give me such a hard time everytime she sees me searching ebay for more audio deals.Robert
zombie boy 2000 wrote:You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's -
Thanks.
Brett
Brett if you bridge two stereo amps mono they become two separate amps. The only way they can become common ground is to strap them. You need to call your amp manufacturer and ask them if once bridged they can be strapped together.
My Adcom 565s are strapped negative speaker terminal of the left channel to the right negative speaker terminal. I've also strapped the chasis. So it goes without saying that if I connected and ohm meter to the ground terminals I would get a zero reading the same with the chasis. -
hearingimpared wrote: »Brett if you bridge two stereo amps mono they become two separate amps. The only way they can become common ground is to strap them. You need to call your amp manufacturer and ask them if once bridged they can be strapped together.
So when I bridge, use a piece of speaker wire and connect the negatives of each amp together. Would you use the same terminal you use for the negative wire to the speakers? Also, when you strap the chassis, did you just loosen a case screw on each amp and connect them with speaker wire? I just don't want to burn anything up.
Thanks for your help. -
Yes. But you should be aware that some amps have a common ground connection through the positive output terminals rather than the negative terminals. Which amps are you using?Also, when you strap the chassis, did you just loosen a case screw on each amp and connect them with speaker wire? I just don't want to burn anything up.
That is what I did when I strapped my Adcom GFA-565 monoblocks together. Some amps will require the additional chassis strapping wire and some will not. The chassis strapping wire is for ground loop (hum) prevention.
I would also like to reiterate this excellent advice:hearingimpared wrote:You need to call your amp manufacturer and ask them if once bridged they can be strapped together.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I'm going to try out a pair of audiosource seven t amps. 200 x 2, 500 bridged.
Got the multimeter ready to check everything out after wiring.
I called audiosource and they seemed uninformed about strapping to obtain common ground.
A friend is loaning me an AI-1 to test with, also.
Will post results. -
Sounds excellent, but need an ai-1. Would like an original, I'm going to wait a while before I make a custom.
