Common Ground?
Neskahi
Neskahi Posts: 297
Is there a simple way to determine if an amp is or is not common ground?
Thanks.
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Take a multi meter, and set it for continuity. Take the leads, and test across the speaker grounds. If it has continuity then it is common ground. What kind of amp is it?
    Ben
  • Neskahi
    Neskahi Posts: 297
    edited March 2007
    Pioneer M-90 at this time. Plan's are to bi-amp with Adcom GFA-535's.
    [2.3's]
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Some people call "continuity," "resistance." That what is on my VOM. Or it may just have the omega symbol.
  • Neskahi
    Neskahi Posts: 297
    edited March 2007
    Thank you Ben. That is kind of what I thought but was not sure.
    So, why would a manufacturer make a non-common ground?
    On another note, my wife is upstairs hogging the 2.3's and I get them after she
    gets sleepy. But more importantly, I have the WAF for a set of 1.2TL's if
    I can find them! Any ideas?
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • ben62670
    edited March 2007
    Non common ground amps are pretty rare. I just guessing that some manufacturers make non common ground amps to have completely different circuits. I have also heard of the positive being common in rare instances.
    I hunt Ebay all the time, and craig's list.
    Ben
  • Neskahi
    Neskahi Posts: 297
    edited March 2007
    Watch e-bay also, and I think those were your 2.3's up for sale a while back. Would have taken them for the wife [put her downstairs],but too far away.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • ben62670
    edited March 2007
    Mine were 3.1TL's, and I sold them here. I still have my SDA-SRS's:)
    Ben
    Ben
  • hearingimpared
    edited March 2007
    In most instances you see non-common ground amps as a result of mono block designs or bridging stereo amps mono.
  • BrettT1
    BrettT1 Posts: 560
    edited April 2007
    Hi all: So if I bridge two stereo amps I would put the multimeter terminals on one negative of each amp to check for continuity. If the ohms read 0, then I'm good to go?
    Thanks.
    Brett
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited April 2007
    Neskahi wrote: »
    On another note, my wife is upstairs hogging the 2.3's and I get them after she gets sleepy.
    WOW! that must be awesome to have a wife who likes audio / listening to music so much that you have to wait your turn after her! I wish I could get my wife that interested. Then maybe she wouldn't give me such a hard time everytime she sees me searching ebay for more audio deals.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • hearingimpared
    edited April 2007
    BrettT1 wrote: »
    Thanks.
    Brett
    Brett if you bridge two stereo amps mono they become two separate amps. The only way they can become common ground is to strap them. You need to call your amp manufacturer and ask them if once bridged they can be strapped together.
    My Adcom 565s are strapped negative speaker terminal of the left channel to the right negative speaker terminal. I've also strapped the chasis. So it goes without saying that if I connected and ohm meter to the ground terminals I would get a zero reading the same with the chasis.
  • BrettT1
    BrettT1 Posts: 560
    edited April 2007
    So when I bridge, use a piece of speaker wire and connect the negatives of each amp together. Would you use the same terminal you use for the negative wire to the speakers? Also, when you strap the chassis, did you just loosen a case screw on each amp and connect them with speaker wire? I just don't want to burn anything up. ;)
    Thanks for your help.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2007
    BrettT1 wrote: »
    Yes. But you should be aware that some amps have a common ground connection through the positive output terminals rather than the negative terminals. Which amps are you using?
    BrettT1 wrote: »
    That is what I did when I strapped my Adcom GFA-565 monoblocks together. Some amps will require the additional chassis strapping wire and some will not. The chassis strapping wire is for ground loop (hum) prevention.
    I would also like to reiterate this excellent advice:
  • BrettT1
    BrettT1 Posts: 560
    edited April 2007
    I'm going to try out a pair of audiosource seven t amps. 200 x 2, 500 bridged.
    Got the multimeter ready to check everything out after wiring.
    I called audiosource and they seemed uninformed about strapping to obtain common ground.
    A friend is loaning me an AI-1 to test with, also.
    Will post results.
  • BrettT1
    BrettT1 Posts: 560
    edited April 2007
    Sounds excellent, but need an ai-1. Would like an original, I'm going to wait a while before I make a custom.
