speaker set up
steelervic
steelervic Posts: 142
edited January 2003 in Speakers
hi, looking for opinions on which speakers to use and where (mainly between fx500 or rt800 rears) in a 5.1 system here is what i have,
pair rt800
pair rt2000i
pair fx500
cs350ls
psw250
thanks
Post edited by steelervic on
  • faster100
    faster100 Posts: 6,124
    edited January 2003
    I would think either the 800's or 2000's up front, I;f i understood the question correctly?? and i would use the fx500's for rears, and of course center and sub accordingly. Not real familiar with the 2000's but are those powered mains? If so maybe use them for mains, and the rest mentioned above. Good luck
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • mantis
    mantis Posts: 17,057
    edited January 2003
    rt800's as suround back and the fx/500 as surround.......
    Dan
  • organ
    organ Posts: 4,969
    edited January 2003
    Sorry but I disagree with you there mantis. I would use the 800i's as mains. To me they sound better for HT than the single woofer speakers in the RT line.
    Steelevic, you should test them out and use the ones you like the most.
    Maurice
  • mantis
    edited January 2003
    organ,
    the rt200's have 3 woofers.1 midbass and 2 8 inch.I assume you know that.The rt800's, well I wouldn't put them up front over the rt2000's.The rt2000's sound much better to me at least.
    The amount of drivers don't yield better sound quality,most of the time less is more.
    Dan
  • organ
    organ Posts: 4,969
    edited January 2003
    Oops I meant 2 mid-woofers. I ignored the 2000i because he's got a sub already. I have compared the 800i to the 600i and 35i and preferred the 800i because of the increased dynamics in the mids but that's just my ears. I just hope our posts are not making Steelevic's decisions more difficult.
    Maurice
