A DAC Question
Early B.
Early B. Posts: 7,900
Let's assume I'm using a DAC with a CD player as the transport. How the hell does the CDP know to "turn off" its internal DAC and defer to the external one? [scratching his head...] I'm figurin' the signal runs through the CDP's internal DAC before it got to the outputs where the external DAC is connected. What say you?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • Ricardo
    Ricardo Posts: 10,634
    edited December 2006
    My understanding is that if you use the digital out, you skip the internal DAC; if you use the analog outs, you are using the internal DAC.
    SOPA
  • hearingimpared
    hearingimpared Posts: 21,136
    The digital out of the CDP bypasses the internal DAC.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Yeah, what he said. Digital to Analog Converter.
    Your stereo RCA outputs are Analog, your coax, bnc, ebu, toslink are digital (yet to be converted).
  • Midnite Mick
    Midnite Mick Posts: 1,591
    bnc, ebu,
    and don't forget about the T&A
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I don't think anything is bypassed, but you don't use the other output. So you use the optical / coax output, the RCA analog is still working.
    Look at this like if you got HOT water in the sink in the kitchen, doesn't your wife still get HOT water in the shower? The hot water tank is the same water output.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Early B.
    Oh, I got it now. Damn, that was easy. I forgot I had a dig out on the CDP.
    Thanks, fellas.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    If I make any adjustments to the water while my wife is in the shower, she usually cuts off my analog input. The only nekkidness I see for a few days is strictly digital, as in downloads..............;)
  • Ricardo
    She doesn't if your hot water tank is too small.....or if your water pressure is too low....or if she just wants cold water....:cool: :cool::p :D
    SOPA
  • disneyjoe7
    Ok Dennis maybe this will not work for you ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Early B.
    Sex and audio -- is there anything else you guys think about?
    Just wonderin'.
  • disneyjoe7
    Drag Racing.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Dennis Gardner
    What else is there????????????
  • Ricardo
    beer and wings
    SOPA
  • hearingimpared
    Audio & Sex!!!
  • hearingimpared
    That's what my wife says! and in that order too!
