A DAC Question
Early B.
Let's assume I'm using a DAC with a CD player as the transport. How the hell does the CDP know to "turn off" its internal DAC and defer to the external one? [scratching his head...] I'm figurin' the signal runs through the CDP's internal DAC before it got to the outputs where the external DAC is connected. What say you?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
My understanding is that if you use the digital out, you skip the internal DAC; if you use the analog outs, you are using the internal DAC._________________________________________________
The digital out of the CDP bypasses the internal DAC.
Yeah, what he said. Digital to Analog Converter.
Your stereo RCA outputs are Analog, your coax, bnc, ebu, toslink are digital (yet to be converted).Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
RuSsMaN wrote:Yeah, what he said. Digital to Analog Converter.
bnc, ebu,
and don't forget about the T&A
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
I don't think anything is bypassed, but you don't use the other output. So you use the optical / coax output, the RCA analog is still working.
Look at this like if you got HOT water in the sink in the kitchen, doesn't your wife still get HOT water in the shower? The hot water tank is the same water output.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Oh, I got it now. Damn, that was easy. I forgot I had a dig out on the CDP.
Thanks, fellas.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
If I make any adjustments to the water while my wife is in the shower, she usually cuts off my analog input. The only nekkidness I see for a few days is strictly digital, as in downloads..............;)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
disneyjoe7 wrote:Look at this like if you got HOT water in the sink in the kitchen, doesn't your wife still get HOT water in the shower?
She doesn't if your hot water tank is too small.....or if your water pressure is too low....or if she just wants cold water....:cool: :cool::p
Ok Dennis maybe this will not work for you
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sex and audio -- is there anything else you guys think about?
Just wonderin'.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Drag Racing.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
What else is there????????????HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
beer and wings_________________________________________________
Audio & Sex!!!
That's what my wife says! and in that order too!
