My Last Speaker Purchase (I'm serious)
Yep. I said it. And given my track record, Ill understand if you dont believe me. But these speakers are my last major HT speaker purchase for a loooonnnng time. Theres absolutely no reason to upgrade anymore because this is perhaps as good as it gets (in my price range).
I suppose youre wondering what kind of speakers I recently acquired? Oh yeah, they are .
(see next post)
(see next post)
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
..a fantastic pair of VMPS Tower II SE
:eek:
First, lets talk aesthetics. These speakers are HUGE!!! They are 44 high, 16 wide and 16 deep. Quite frankly, they overwhelm my 13 x 20 room. Because of that, the WAF aint very high on these. However, the finish is beautiful. I love the burgundy veneer and it goes well with the décor.
The speakers have 5 drivers each a supertweeter, tweeter, midrange, two 12 carbon fiber woofers, and a passive, downward firing 12 woofer. They also have three pots to tweak the treble, midrange, and supertweeter. There are dual binding posts with internal jumpers. A switch on the back of each speaker controls whether the speakers are to run full range or bi-wired/bi-amped. These speakers are very efficient and dip down to 20 Hz. Im guessing they weigh about 125 lbs. each.
So how do they sound? Well, the soundstage is exceptional far better than the Polk SDA-CRS+ they replaced, and the Polks were outstanding. Not surprisingly, the VMPS sound much fuller and thicker than anything Ive had before. In fact, these speakers make my entire system sound more like an actual movie theater.
The bass aw man, the bass. Exceptionally controlled and clean as a whistle. A few weeks ago I was using an Onix digital equalization system. The Onix works great and I said I would eventually buy it again, but these speakers sound just like I have the Onix hooked up because the bass is clean and is not localizable. My DIY 15 sub seems to sound more refined. For some reason, fewer things are rattling in the room, but all of the bass is still there.
For example, on one of these LOTR movies, there is a scene where mammoths are engaging the enemy in a battle sequence. With the VMPS, it sounds like the mammoths footsteps are charging right at you because the fronts can convey all of the bass. And when Darla taps the glass, the entire room becomes the fish bowl, not just the area surrounding the seating position.
The most impressive aspect of these speakers is that Im finally getting close to true surround sound. I didnt think it was possible in my room because the seating position is against the rear wall, but dammit, I feel like Im in the middle of the action. The front speakers are somehow working in tandem with the surround speakers and my surrounds sound better than ever.
Ive got bass all over the place the fronts go down to 20 Hz, my sub goes well below 20 Hz, and my center channel goes down to 27 Hz. If anyone ever tells you that low bass is not necessary for your fronts because you have a subwoofer, they dont know what the hell theyre talkin about. As many of you know, Ive tried a bunch of speakers, and the top three speakers Ive had all had substantial bass (25 Hz or less).
Bottom line this is the best sounding system Ive had by a very wide margin. I dont know what else to say.
Lessons learned:
1. Bass all over the place thats what I been preachin. Strive for it.
2. For HT, size matters. Buy the biggest, baddest speakers you can afford.
3. Sometimes you gotta make an executive decision and ignore WAF. Buying big **** speakers is one of those times.
4. Stop settling. Ive spent a lot of money over the years experimenting with speakers because I didnt pursue what I really wanted (the main reason fear of WAF). Buy big and dont look back.
5. When a good deal comes along and its an item youve been salivating for, jump on it. Dont even think twice.
In a few days I may be tempted to hook my tube amp and tube CDP up to the VMPS speakers and see what it sounds like. Hmmmm. I expect them to sound positively delicious in 2-channel mode.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Enjoy the pics...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
beautiful.....and 20Hz....impressive.
I understand the 9's decision now
Congrats._________________________________________________
GREAT speakers.
Looks like someone did some tweeter swapping. What's the dome from the Inifinity Kappa series, circa early-mid 90's?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Congrats Early, they look great. No problem filling the room now I'm sure.Michael
NORTH of 60° -
3 12" woofers? No wonder you're getting bass. What amp are you driving these with? Are you going to run phantom centre or try to find something that matches these sonically?
RuSsMaN wrote:GREAT speakers.
I dunno.
The seller is the original owner. He says he purchased them in 1999 and didn't modify them. I e-mailed VMPS to send me some info and specs on these speakers. I'll let you know what they say.
Follow-up: I just received an email from Brian at VMPS. He's still searching for more info, but he confirmed that the TII SE had the yellow Focal dome tweeter and Kappa Emit-R supertweeter.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Sami wrote:What amp are you driving these with? Are you going to run phantom centre or try to find something that matches these sonically?
I'm driving them with the receiver for the moment. The AAD 2002 center channel sounds great with them, IMO.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early B. wrote:Yep. I said it. And given my track record, Ill understand if you dont believe me.
I don't
JC approves....he told me so. (F-1 nut) -
Awesome EB!! Sho look snazzy...
All that talk about bass and you're rollin' with a supertweeter:DI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Love it EB!! LOVE IT!!!
I like your mantra.... "BUY BIG and DONT LOOK BACK!!"
I dont believe you when you say these are your last speakers as I'm sure that you will have a new thread in a few months about a new speaker that you just so happen to have acquired.
I think you've gone through more speakers in the past 2 months than many of us combined!
Surely would've loved an LSi9 vs Tyler review though....
Anyway, good luck with your new babies.. and I've heard much good things about the VMPS, hope you enjoy them for while!
JoeyMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I agree. There will be MORE.Michael
NORTH of 60° -
yea, VMPS used the Kappa tweeter back in the day. VMPS is good stuff, have fun with those monsters.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
fantastic looking speakers, without a doubt. Congrats- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nuttin' like some monster floor standers to shake your **** off the couch.
Enjot my friend!!:DHT SYSTEM-
lsi 9's -
Just finished playing some funky music through these speakers. Dayummm!!
Absolutely incredible. The bass is the real deal, baby.
The music was being played through my DVD player and receiver. I can't imagine how much better they'll sound with a CDP, a nice SS amp, or some tubes somewhere in the mix. Geez.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Shweet...
But who ya kidding???My Last Speaker Purchase (I'm serious) -
Those look nice. Nice large room also.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Those are a sexy pair of speakers. The veneer is gorgeous. Hope you enjoy them (as I have no doubt you will).Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
If I had a dollar for every time I said 'my last speakers'.......I would buy more speakers!:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
So true....wingnut4772 wrote:If I had a dollar for every time I said 'my last speakers'.......I would buy more speakers!:D
I'm serious, y'all. No more speakers! Ya gotta believe me this time...
...but only if the WAF lets me keep them. She hasn't said anything yet, but at any moment and "BAM!!" The teeth will start knashing and I'll get a verbal lashing.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
He gets a lashing. I get a BASHING...
Oh yeah, one more thing about these speakers -- I turned them up as loud as I'll ever play them and the carbon fiber drivers don't visibly move at all. I like that. These speakers are extremely well behaved.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early B. wrote:And given my track record, Ill understand if you dont believe me.
Kinda reminds me of what Liz Taylor said about Eddie Fisher (husband #4) being her "last".:D
Congrats on the new toys.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Nice choice!!
Just be careful with the poor WAF..............she could cut you in half and sail your **** down the river in speakers that big. Never to be seen again!:eek:HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Lookin' good! Better put an extra hanger on that elephant with all that bass.
Congrats, Brad! that's a good size speaks indeed, no doubt the bass is plentiful. Njoy!I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Very nice. They remind me of the vintage Legacy speakers.
