My Last Speaker Purchase (I'm serious)
Early B.
Early B. Posts: 7,900
edited April 2008 in Speakers
Yep. I said it. And given my track record, I’ll understand if you don’t believe me. But these speakers are my last major HT speaker purchase for a loooonnnng time. There’s absolutely no reason to upgrade anymore because this is perhaps as good as it gets (in my price range).
I suppose you’re wondering what kind of speakers I recently acquired? Oh yeah, they are….
(see next post)
"God grooves with tubes."
Post edited by Early B. on
«13
  • Early B.
    edited November 2006
    ……..a fantastic pair of VMPS Tower II SE :D:D :eek: :D:D
    First, let’s talk aesthetics. These speakers are HUGE!!! They are 44” high, 16” wide and 16” deep. Quite frankly, they overwhelm my 13’ x 20’ room. Because of that, the WAF ain’t very high on these. However, the finish is beautiful. I love the burgundy veneer and it goes well with the décor.
    The speakers have 5 drivers each – a supertweeter, tweeter, midrange, two 12” carbon fiber woofers, and a passive, downward firing 12” woofer. They also have three pots to tweak the treble, midrange, and supertweeter. There are dual binding posts with internal jumpers. A switch on the back of each speaker controls whether the speakers are to run full range or bi-wired/bi-amped. These speakers are very efficient and dip down to 20 Hz. I’m guessing they weigh about 125 lbs. each.
    So how do they sound? Well, the soundstage is exceptional – far better than the Polk SDA-CRS+ they replaced, and the Polks were outstanding. Not surprisingly, the VMPS’ sound much fuller and thicker than anything I’ve had before. In fact, these speakers make my entire system sound more like an actual movie theater.
    The bass – aw man, the bass. Exceptionally controlled and clean as a whistle. A few weeks ago I was using an Onix digital equalization system. The Onix works great and I said I would eventually buy it again, but these speakers sound just like I have the Onix hooked up because the bass is clean and is not localizable. My DIY 15” sub seems to sound more refined. For some reason, fewer things are rattling in the room, but all of the bass is still there.
    For example, on one of these LOTR movies, there is a scene where mammoths are engaging the enemy in a battle sequence. With the VMPS’, it sounds like the mammoths’ footsteps are charging right at you because the fronts can convey all of the bass. And when Darla taps the glass, the entire room becomes the fish bowl, not just the area surrounding the seating position.
    The most impressive aspect of these speakers is that I’m finally getting close to true surround sound. I didn’t think it was possible in my room because the seating position is against the rear wall, but dammit, I feel like I’m in the middle of the action. The front speakers are somehow working in tandem with the surround speakers and my surrounds sound better than ever.
    I’ve got bass all over the place – the fronts go down to 20 Hz, my sub goes well below 20 Hz, and my center channel goes down to 27 Hz. If anyone ever tells you that low bass is not necessary for your fronts because you have a subwoofer, they don’t know what the hell they’re talkin’ about. As many of you know, I’ve tried a bunch of speakers, and the top three speakers I’ve had all had substantial bass (25 Hz or less).
    Bottom line – this is the best sounding system I’ve had by a very wide margin. I don’t know what else to say.
    Lessons learned:
    1. Bass all over the place – that’s what I been preachin’. Strive for it.
    2. For HT, size matters. Buy the biggest, baddest speakers you can afford.
    3. Sometimes you gotta make an executive decision and ignore WAF. Buying big **** speakers is one of those times.
    4. Stop settling. I’ve spent a lot of money over the years experimenting with speakers because I didn’t pursue what I really wanted (the main reason – fear of WAF). Buy big and don’t look back.
    5. When a good deal comes along and it’s an item you’ve been salivating for, jump on it. Don’t even think twice.
    In a few days I may be tempted to hook my tube amp and tube CDP up to the VMPS speakers and see what it sounds like. Hmmmm. I expect them to sound positively delicious in 2-channel mode.
  • Early B.
    Enjoy the pics...
  • Ricardo
    Ricardo Posts: 10,636
    beautiful.....and 20Hz....impressive.
    I understand the 9's decision now :)
    Congrats.
    SOPA
  • RuSsMaN
    RuSsMaN Posts: 17,986
    GREAT speakers.
    Looks like someone did some tweeter swapping. What's the dome from the Inifinity Kappa series, circa early-mid 90's?
  • janmike
    janmike Posts: 6,146
    Congrats Early, they look great. No problem filling the room now I'm sure.
    Michael ;)
    NORTH of 60°
  • Sami
    Sami Posts: 4,634
    3 12" woofers? No wonder you're getting bass. What amp are you driving these with? Are you going to run phantom centre or try to find something that matches these sonically?
  • Early B.
    RuSsMaN wrote:
    GREAT speakers.
    I dunno.
    The seller is the original owner. He says he purchased them in 1999 and didn't modify them. I e-mailed VMPS to send me some info and specs on these speakers. I'll let you know what they say.
    Follow-up: I just received an email from Brian at VMPS. He's still searching for more info, but he confirmed that the TII SE had the yellow Focal dome tweeter and Kappa Emit-R supertweeter.
  • Early B.
    I'm driving them with the receiver for the moment. The AAD 2002 center channel sounds great with them, IMO.
  • george daniel
    george daniel Posts: 12,096
    I don't :)
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Awesome EB!! Sho look snazzy...
    All that talk about bass and you're rollin' with a supertweeter:D
  • Joey_V
    Joey_V Posts: 8,600
    Love it EB!! LOVE IT!!!
    I like your mantra.... "BUY BIG and DONT LOOK BACK!!"
    I dont believe you when you say these are your last speakers as I'm sure that you will have a new thread in a few months about a new speaker that you just so happen to have acquired. :)
    I think you've gone through more speakers in the past 2 months than many of us combined!
    Surely would've loved an LSi9 vs Tyler review though....
    Anyway, good luck with your new babies.. and I've heard much good things about the VMPS, hope you enjoy them for while!
    Joey
  • janmike
    I agree. There will be MORE.
    Michael ;)
    NORTH of 60°
  • hoosier21
    hoosier21 Posts: 4,418
    yea, VMPS used the Kappa tweeter back in the day. VMPS is good stuff, have fun with those monsters.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    VR3 Posts: 29,437
    fantastic looking speakers, without a doubt. Congrats
    tonyb Posts: 33,072
    Nuttin' like some monster floor standers to shake your **** off the couch.
    Enjot my friend!!:D
  • Early B.
    Just finished playing some funky music through these speakers. Dayummm!!
    Absolutely incredible. The bass is the real deal, baby.
    The music was being played through my DVD player and receiver. I can't imagine how much better they'll sound with a CDP, a nice SS amp, or some tubes somewhere in the mix. Geez.
  • amulford
    amulford Posts: 5,020
    Shweet...
    But who ya kidding???
  • wingnut4772
    wingnut4772 Posts: 7,519
    Those look nice. Nice large room also.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • haimoc
    haimoc Posts: 1,031
    The speakers look very nice. Congrat.
  • Refefer
    Refefer Posts: 1,280
    Those are a sexy pair of speakers. The veneer is gorgeous. Hope you enjoy them (as I have no doubt you will).
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • wingnut4772
    If I had a dollar for every time I said 'my last speakers'.......I would buy more speakers!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Joey_V
    Joey_V Posts: 8,600
    So true....
    Joey
  • Early B.
    I'm serious, y'all. No more speakers! Ya gotta believe me this time...
    ...but only if the WAF lets me keep them. She hasn't said anything yet, but at any moment and "BAM!!" The teeth will start knashing and I'll get a verbal lashing.
  • amulford
    He gets a lashing. I get a BASHING...
  • Early B.
    Oh yeah, one more thing about these speakers -- I turned them up as loud as I'll ever play them and the carbon fiber drivers don't visibly move at all. I like that. These speakers are extremely well behaved.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Kinda reminds me of what Liz Taylor said about Eddie Fisher (husband #4) being her "last".:D
    Congrats on the new toys.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Nice choice!!
    Just be careful with the poor WAF..............she could cut you in half and sail your **** down the river in speakers that big. Never to be seen again!:eek:
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Lookin' good! Better put an extra hanger on that elephant with all that bass. ;)
  • polkatese
    polkatese Posts: 6,767
    Congrats, Brad! that's a good size speaks indeed, no doubt the bass is plentiful. Njoy!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • bdaley6509
    bdaley6509 Posts: 1,167
    Very nice. They remind me of the vintage Legacy speakers.
