Piercing the Peerless Soft Dome?
schwarcw
I picked up a pair of Peerless soft dome tweeters off eBay. They arrived today, great condition. I bought them as I have been hearing one of the tweeters in my Monitor 7's acting up for several months now.
Polk pierced holes in the center of the Peerless domes to relieve pressure inside the dome. At least that's what I read here. I'm contemplating whether or not to pierce the domes on my newly arrived tweets. My first inclination is not to pierce it and see what it sounds like. Anyone have some experience to share as to the performance with and without the hole? Suggestions for piercing?
Carl
Post edited by schwarcw on
schwarcw wrote:Suggestions for piercing?
Make sure you wear clean rubber gloves use a sterilized needle.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Polk used the tip of a hot soldier iron, I would leave well enough alone and not risk destroying a presumably clean pair of 810665's.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
DarqueKnight wrote:Make sure you wear clean rubber gloves use a sterilized needle.
I'll wipe the dome with some alcohol on a cottom swab too!;)Carl -
RuSsMaN wrote:Polk used the tip of a hot soldier iron, I would leave well enough alone and not risk destroying a presumably clean pair of 810665's.
My thoughts exactly. I know some members have used the solder needle tip. I had visions of the dried silk dome surface lighting up, leaving me a jagged 1/4" diameter hole:eek:
CarlCarl -
I have a spare with the blowhole that works but is not a museum piece. It's yours if you would like for comparison.
schwarcw wrote:I'll wipe the dome with some alcohol on a cottom swab too!;)
Should this be performed by a rabbi, or can it be tried at home by a layman ?Sal Palooza -
mrbigbluelight wrote:Should this be performed by a rabbi, or can it be tried at home by a layman ?
No, it must be done by a Shochate and the remnants buried in the ground. Also must be done on the 8th day of its new life....:)UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team -
I think the hole is probably there to break up standing waves on the dome. Isn't it interesting that Peerless, who designed the tweeter, made it with the dome intact but Polk decided it needed a hole in it?
FWIW, I am sure y'all know the Peerless KO10DT tweeter was used in many, many speakers and also in DIY's. What you may not know is that early Teledyne-era Acoustic Research speakers used an OEM version of this same tweeter. I have a single, early AR14 with this somewhat unusual looking Peerless tweeter:
Here's a later AR-14 with a different tweeter:
And, finally, for comparison, here's a Polk Monitor 7A with the holey Peerless:
My Jennings Research uses the peerless tweeter too. Noticing what polk did, I took the tip of my soldering gun and tipped it. After I did it..I did noticed the Jennings were not quite as bright (alittle less harsh) but not affecting the stability of the peerless. Sounded alittle more natural IMO. But do it at your own risk..it is tricky, the dome melts quickly. So it doesnt take much touch at all.
JakeMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
mhardy6647 wrote:Isn't it interesting that Peerless, who designed the tweeter, made it with the dome intact but Polk decided it needed a hole in it?
Not really, by doing so Polk made it 'their own'.
Cheers,
Is the hole a penatration? I've examined the Peerless tweets in my Monitor 11s extensively and get the sense it's a dimple.
On my 7b's and the one I bought off of ebait, the silk is penatrated not just pushed in.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
No jive-butt dimples; they's holes in mines'es
They said penetration!!!"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I just looked over my four Peerless tweets and see that the tiny hole actually goes through the outer black dome and then is followed by an un-pierced off white layer. All four are holes look to be the same size and very uniform. I don't think that "I" could reproduce this nearly as well at home and so wouldn't try it unless it didn't matter if I messed up.
BlueMDPicker wrote:Is the hole a penatration? I've examined the Peerless tweets in my Monitor 11s extensively and get the sense it's a dimple.
Might be time for new bi-focals Mike:DCarl
