FS: Gear, Cables, and More Gear
RuSsMaN
RuSsMaN Posts: 17,985
edited December 2006 in For Sale (FS) Classifieds
Audio Mirror PP1 Tube Preamplifier
Killer tube preamp, less than 1 year old. Originally owned by Luther (wardsweb), and now by me. Tube line AND phono section. Remote volume and source selection. 4 inputs, 1 output, IEC power cord jack. http://www.audiomirror.com/ I'll hand select tubes for it to ship with, and post here later this evening (no you cannot have my Amperex German 12Ax7's). Reason for sale? Phono stage is wasted in the setup I'm using it in.
Retail $1199 - $old Dennis Gardner.
Sansui TU-777 AM/FM Analog Tuner
Not so common model, very sought after. Large planatary tuning dial. Immaculate condition - museum quality, top to bottom. I use a modded TU417 for my FM, and have had this one simply sitting out on top of my record cabinet on 'display'. Aligned, plug and play. Again, a piece of gear that needs to be listened to, not in my static displays.
$old hearingimpaired
Scott 350D FM Stereo Tube Tuner
The LAST of the Scott tube tuners, and probably the most diserable. Immaculate condition, and in full working order. Original optional Walnut case included. I had one other of these, and it went to Japan last year for $450. Aligned, plug and play. A peice I truely hate to see go, and would request first right of refusal, when and if from the buyer.
$old Amulford.
Kimber 4PR Speaker Cable, 5ft pair
Entry level Kimber, bare wire on one end, spades on the other. $30 to your door.
Canare LV-61S 75ohm Digital Cable, 3 ft
Solid digital cable, put on the level with entry MIT. $25 to your door.
Straight Wire Silver Link II, 75ohm Digital Cable, 5ft
High end cable, cannot be beat for the price offered here. My second favorite dig cable under my Tributaries Silver. $old AndyGwis
Straight Wire Silver Link I, 75ohm Digital Cable, 3ft
The line under the the Link II listed above, great silver digital cable. $old AndyGwis.
Straight Wire Silver S-video cable, 5ft.
High end cable, cool 'double run' of their video cable, gold s-video terminations. SEE a difference. $40 to your door.
Monster Cable Interlink 400MkII SACD/DVDA Cable Kit - 2m
In retail packaging - in a nutshell, six, 2m Interlink 400 interconnects. Feel free to spread them out, and cable your 2ch rig. $old Danny.
Versalab Wood Block - EMI/RFI Killers
Plugs in-line with your gear, attach your power cord to it's IEC connector. Great for digital, D/A converters, transports, and cd players. These are 'extra', I use one in my whole house rig on the CDP. 1 $old haimoc - 1 $old zombie boy 2000.
Sony TC-K909ES Cassette Deck
Might have had 10 cassettes played on it in its lifetime. 3 head, direct drive, Dolby S,B,C, HX Pro. Optional wood side panels. Immaculate. You won't believe how good cassettes can sound. Just a hair under my NaK Dragon - I don't need two badass decks. Retail was $790 $90 to your door.
Polk Audio Monitor 6 Series II Passive Subwoofer
Bandpass enclosure, dual 6.5" woofers. Speaker level (clip) inputs, external amp required. No need for filtering, the bandpass tuning does that for your. Run on your b outputs from your receiver or integrated amp, or inline with a pair of 8ohm speakers to present a 4ohm load. The bottom end of Polks first 'sub sat' system. Loads up GREAT in a small room, it will suprise you. $old hearingimpaired
Polk Audio PSW 550 Powered Subwoofer
Piano black, second owner, immaculate. Fast, articulate, and loads up suprising well in medium sized rooms. Great way to add bottom end to a pair of speakers. It was fast enough to keep up with my Maggie MMGs (what a rig, why did I bust it up?), so it will mate well with pretty much any dynamic speaker out there. Prefer local p/u, email to discuss shipping. $old kn505
More to come, detailed pictures, and additional info......
PLEASE EMAIL ME DIRECT [email][/email] - DO NOT USE PM's - my box will fill up WAY too quickly.
Cheers,
Russ
  • AndyGwis
    AndyGwis Posts: 3,655
    edited November 2006
    Gimme the Canare Coax. I'll pick up later this week / weekend
    . . . straight cash, Homie.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • amulford
    amulford Posts: 5,020
    Is that an HH Scott 350D? Get them pictures up.
    If it's the match to my integrated, it's mine.
  • RuSsMaN
    It is the match, the dead match. I got your tubes in yesterday, so I've got three boxes headed your way, the integrated, the tuna, and the Pioneer dual cassette promised many moons ago.
    Pics shortly on everything......
    Andy, rgr that.
  • seo
    seo Posts: 305
    What is the physical size of the Polk Audio Model 6?
    Signature goes here
  • RuSsMaN
    13H, 7.5W, 20D
    Similar look to a Bose Acoustimass.
  • RuSsMaN
    Quick pics added, more detailed on request.
  • AndyGwis
    Crap, may as well take your Silver Link I 3ft digital as well. . . looks too pretty to pass up.
    volume discount :)?
  • RuSsMaN
    Always, even bigger discount if you by these Thiels.
  • RuSsMaN
    *cough*
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Russ...
    I'll take one of the Versalab woodblocks, if you'd be so kind.
  • haimoc
    haimoc Posts: 1,031
    I take one Versalab Wood Block - EMI/RFI Killers.
  • haimoc
    haimoc Posts: 1,031
    PM sent for payment and address. Thanks, Russ.
  • AndyGwis
    Just FYI, I took both the Straight wire digitals yesterday (the 3' and 5') so they are gone, but the Canare is still up there. Ended up needing a longer one.
    And, got the Thiels while I was out there. They looked / sounded nice and the price was right. Higher girlfriend acceptance factor to boot.
    Thanks, Russ!
  • hearingimpared
    hearingimpared Posts: 21,136
    Russ did you get my email this afternoon about the Sansui TU-777 AM/FM Analog Tuner?
    Joe
  • hearingimpared
    Russ do you think the Polk Audio PSW 550 Powered Subwoofer is overkill for the Surroundbar???
    Joe
  • amulford
    Hell no, it would be killer...
  • ND13
    ND13 Posts: 7,601
    Russ,
    If you decide to ship the PSW 550, let me know what it'd cost to 47362. I'm actually going to put together a decent HT. I'd like to do it all Polk, too. I know all about the SVS over Polk subs arguement. I'll be just fine with the Polk. My little JBL just an outstanding job in my current 2.1 set-up, so I know the 550 will be an upgrade over it and a lot less $$$ than a SVS. Though, one of the passive SVS at a pre-owned price might change my mind, seeing that i have an amp to drive it with.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • kn505
    kn505 Posts: 380
    Russ,
    Emailed you on the Sony deck & PSW 550
  • RuSsMaN
    Guys, I'll sort through this when I get back late this afternoon. My 17 year old cat, Mr Max appears to be on his last leg, and I've got to take him to get put down.
  • AndyGwis
    And I just got to meet Mr. Max this weekend. . . I'm really sorry to hear that, Russ. That's really tough, but at least you got 17 great years of companionship. . .which is more than most marriages these days.
    Sorry again, bro.
  • zombie boy 2000
    Take your time Russ... no need to hurry on my end.
    Sorry to hear about Mr Max.
  • hearingimpared
    Sorry to hear about Mr Max Russ.
  • ND13
    ND13 Posts: 7,601
    Poor kitty. :(
    I love cats and will not know what to do when Scout, our 14 1/2 year old leaves us. We've had her since she was seperated from her mother at about 4 weeks. She was small enough to fit in the palm of my hand and I had to feed her with an eyedropper for 2 months. She hasn't a clue she's a cat and acts like it, too. As of now, she's in pretty good health, but her nerves are getting a little shot with the dog, rabbitt and 2 young boys, so she's on anti-anxiety meds so her hair won't fall out.
  • sucks2beme
    sucks2beme Posts: 5,703
    Sorry to here about the cat. I had one that had several strokes I had to put down a couple of years ago.
    The strange part was, for months afterward, I could swear I saw that orange furball out of the corner of my eye, only to remember he was gone.
    The new kitty is a much different personality. Good news is I no longer see the phantom orange kitty. As nuts as it sounds, the wife says she had the same thing happen to her.
  • amulford
    It sucks, but you're doing the right thing, bro...
  • RuSsMaN
    Hearingimpaired, you've got the 777 if you want it.
    Kn505, email me back - I sent you one about the sub/tape deck combo.
  • kn505
    kn505 Posts: 380
    Russ,
    Your email did not go through. Please resend.
  • hearingimpared
    Russ my internet and email have been up and down all day. I replied to your email but don't know if it went through. I have mailed a check today for the price stated in your email.
    Thanks so much for your generosity.
    This is the first house warming gift I have received.:D
    Thanks again,
    Joe
  • RuSsMaN
    Emails sent guys, kn505 / hearingimpared.
    pm for my cell # if the emails are out in the web somewhere.
  • hearingimpared
    Did you get mine Russ? I sent the check today.
