Qustions about some amp
Shannon W.
Shannon W. Posts: 568
edited December 2002 in Electronics
Im looking for a amps that would run my new Polk LSi9's,LSiFX's,LSiC and LSi7's
Im looking at ether the Rotel RB-1075 and the Rotel RB-1055
or the Parasound HCA-1206 . any help would be great. thanks Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Post edited by Shannon W. on
  • phuz
    phuz Posts: 2,372
    edited November 2002
    Any of those in my humble opinion, would be just lovely. :)
    I wish I could afford one.
  • jmierzur
    jmierzur Posts: 489
    I am using the Rotel RB-980BX (current model RB-1070) for LSi9s and the RMB-1075 for the LSiC and LSiFX surrounds. The two extra channels will be for future use when I move to 7.1 and purchase LSi7s. This combination drives the LSi series very well. The low end for my system is rounded out by two Def Tech subs.
    If you like to listen to two-channel sources, consider using a two-channel amp for the LSi9s and a multi-channel amp for the surrounds.
  • mantis
    mantis Posts: 17,057
    Shannon,
    If you haven't heard Rotel and Lsi together....man your missing out.Go check out Rotels line up, even there receivers are really good sounding.
    I'd say if money is tight,go check into the rsx1055.I have heard so many good things about it.You can buy a 2 channel amp for the main channels and redirect the internal amp to the surround back channel.Now thats a cool **** feature.I love it.
    If your more power hungry,check out the rsx1065.Beast I will have to say.Alot of headroom.It's basically an intergraded,like all of Rotels stuff,amps come first then everything else falls in line.
    I'm 100% a fan and supporter of Rotel.
    Dan
  • Steve@3dai
    Steve@3dai Posts: 983
    Go Arcam, I love their stuff, and it matches GREAT with LSi equipment.
    LSi 9/C/FX
    Arcam AVR-200
  • Apex
    Apex Posts: 69
    How does Adcom rate?.
    H/K AVR7000
    "LSI25's bi-wired with 2.4s
    Mirage OM c2 Center "LSiC soon"
    FX300i rears "LSi15's soon for the rears".
  • phuz
    phuz Posts: 2,372
    Arcam is good stuff, but it's a bit costly for the average Polkie.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Arcam, Adcom, Carver, NAD, Rotel, Cambridge, Creek, Parasound, GAS (if you can find it), AMC, Anthem, the list goes on and on.
    Cheers,
    Russ
  • polkatese
    polkatese Posts: 6,767
    shannon,
    I've got 1065, boy, oh boy, it provided me with a lot of high juicy current for my LSi15 and Fx....
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mantis
    Oyeah the Rotel rsx1065..........sweat.
    Dan
  • inspire
    inspire Posts: 21
    I think it depend on your taste.
    I like warm sound so I chose B&K.
    superb on music. very smooth sound~
    I think Denon was very bright especially in high volume.
    the speaker tweeter seems like distorting.
    My Setup
    panasonic 50" plasma
    Monster Power 7000 SS
    Silicon Image IscanUltra Pro
    B&K reference 50 preamp
    B&K reference 200.7 amp
    Martin Logan Ascent i main
    Martin Logan Theater i center
    Martin Logan Decent Sub
    Polk RT 800 for side surrounds
    Polk FX300 for Rears
    F1nut Posts: 49,804
    inspire,
    Great, another Maryland guy! What area are you in? I think you make four of us. I'm in Brookeville, madmax is in Frederick and john d. strong is in Baltimore.
    F1nut
  • faster100
    faster100 Posts: 6,124
    So is that the only amp that works well with those? : (
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
