finally done...
  • schmilnik
    schmilnik Posts: 44
    edited September 2006
    mutelight wrote:
    Because your receiver isn't getting proper ventilation. Adur. Please also don't say my system doesn't compare to yours because it doesn't, mine would make you wet your cargo pants and dribble down onto your vans. I guess mine is inferior in the sense I can play it at deafening levels without distortion without blowing tweeters and it stays on. :rolleyes:
    Mine does not distort and my tweeters were not blown it was my ipod.
  • schmilnik
    schmilnik Posts: 44
    "mine would make you wet your cargo pants and dribble down onto your vans"
    I have to admit thats pretty funny ;)
  • danger boy
    danger boy Posts: 15,722
    well heat does build up.. even at low volumes.. or no volume at all. My Adcom amp heats up pretty good just in "on" and no putting out any sound. once i have it powering up my front speakers. which are very easy to drive. it heats up in about 30 to 45 mins. and it kicks out some serious heat then. Amps I think may be designed differently than receivers.. in that heat is a given from an amp.
    My old Marantz receiver used to put out some heat too. that's why i placed it on the top shelf of my audio rack.
    Also, if somehow speaker wires may have touched each other at some point.. will also cause a receiver to turn itself off, esp if you're running bare wire.
    PolkFest 2012, who's going>?
  • ronnie
    ronnie Posts: 150
    you can find a great cooling fan on ebay....windywillys . I have one and at very high volumes my reciever is very cool to the touch, even after hours of listening.. it sits right on top of your reciever and sucks the heat right out..i highly recommend to anyone....By the way, theres some ballbreakers in here, but , all in all there all great people
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • schmilnik
    schmilnik Posts: 44
    Awesome I will have to pick it up. thanks man I appreciate it!
  • schmilnik
    schmilnik Posts: 44
    hey do you think you could link it to me I cant seem to find it on ebay or anywhere at that.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
  • schmilnik
    schmilnik Posts: 44
  • halo
    halo Posts: 5,616
    This is an excellent fan: link Very quiet & it moves a lot of air.
  • mutelight
    mutelight Posts: 1,054
    Well I am glad you took it as a joke because that is all that it was. Enjoy your system man and from all the great help on these forums I am sure you will. :D
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • schmilnik
    schmilnik Posts: 44
    Ya, thanks and just to let you guys know i got a fan for my receiver as well as my 360 so hopefully I can keep everything coool:cool:
  • wingnut4772
    wingnut4772 Posts: 7,519
    I use the Parasound ZBreeze to cool of my wickedly hot Anthem Statement D2.It works very well and it is low profile.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Drumingman
    Drumingman Posts: 348
    For cooling fans look up
    http://www.activethermal.com/default.htm
    In most radio stations and a lot of commerical equipment we always used a fan called The Boxer, it's a stand alone unit, about 3 to 4 inches square, known for it's quiet operation and reliability. A Boxer is about 20 to 30 dollars.
  • faster100
    faster100 Posts: 6,124
    leave it to you to have a cutting edge cooling fan :D Looks cool,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Sherardp
    Sherardp Posts: 8,038
    system looks good man, follow the advise and use them as your guidelines, if you decide to buy into an amp, are you planning to buy a new rack as well? Anyway enjoy your setup, youre going to be in for a shocker once you put an amp on those fronts. Good job though.
  • schmilnik
    schmilnik Posts: 44
    Hey thanks man, ya i am going to get and amp in the future and i got that fan for my receiver so hopefully it should be fine? If not I will get a new rack.
  • wingnut4772
    Ha :D . Thanks Cliff. It's really nice and quiet. I really like it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Willow
    Willow Posts: 11,234
    Doesn't the 335 have a built in fan ?
    Mine has 3" of clearance on top tons on the side and about 8" behind it.
    Also you might want to swap out those brass jumpers for better ones and not to nit pick but you could use some clean up in the cable area, those comming from the TV
  • ronnie
    ronnie Posts: 150
    if i could suggest an amp for you it would be the adcom gfa555 or the 555II...these amps are powerhouses and can be had for around 300 to 400 bucks. 200watts a channel of clean power and will surely wake your 10's up
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • Willow
    Doesn't Isig have a cool running amp which pumps out 200WPC?
  • schmilnik
    schmilnik Posts: 44
    Brass jumpers?? What do you mean?
  • Willow
    you have 4 binding posts. in between each of them you will see a flat brass connector. Replace those with speaker cable.
    Check :
    http://www.polkaudio.com/forums/showcase/closeup.php?userid=56220&pic=227_22_big.jpg
    BTW, nice system for any age but more so because of how young you are and what a fine system you put together. So stick around. You'll lurn tons.
  • schmilnik
    schmilnik Posts: 44
    Check :
    Ok but will exactly will this do? thanks for the comments and help! much appreciated!
  • Willow
    Instead of using some paper thin connection you are using bigger AWG connection, it should prove the same as bigger sepaker cable will make a difference.
    You don't have to buy jumpers like mine, you can make your own. Some speaker cable and either bare ends or you can terminate them if you wish.
  • ronnie
    ronnie Posts: 150
    i use 12 gauge wire for my jumpers....drastic difference in sound, but everybodys ears hear different things...goodluck with your system...when you decide to add an amp to those babies you are gonna be blown away. A recievers rated power is not always true. A 100 watt seperate amp will surely blow away your avr. this hobby is an addiction , like tatoos..i got my first one at 17 and now have 28....since i started loving home audio i cant tell you the money i have spent...IM AN ADDICT...for tats and home audio,,, thats where all my extra money goes. Trust me, my sig changes about every 3 months
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
