finally done...
hey guys im finally done with my system, tell me what you think! Take a look--->http://www.polkaudio.com/forums/showcase/view.php?userid=72127
Post edited by schmilnik on
OhhhhhhhhhhNoYourNot!
You need more clearance above the receiver.....and howzabout a proper frame for that poster. -
And get a hair cut.
Frank Z wrote:And get a hair cut.
why are you so bitter...cant get laid??? -
Zero wrote:Schmilnik,
Awesome system. Great selections that compliment each other real well, I bet that HT is bangin'.
Now for suggestions;
First, your HK runs fairly cool for its design. Still, as Frank points out - you need more breathing room in the back. You run a good risk of damaging it as things are right now. Raise the glass payne if you can to the next notch, and you should be good to go.
Second, spread out those RTi-10's if possible. You will experience a total different sound (and for the better) with them a good 3-4 more feet apart and toed in slightly.
thanks for the suggestions i appreicate any help as i am somewhat new to this -
haha ok well then why??Zero wrote:Close. He's married.
edit: Now hop to and get that receiver some room to breathe... unless you want to be cleaning up smoke and picking out blown transistors. -
I cant really move it anywhere is it really a big issue?? -
Nice system enjoy.
From looking at your pics, you really don't have a lot of room.
If heat becomes a issue with the H-K then consider a cooling fan system to draw the trapped heat away from the unit. As far as speaker placement, seperate the 10's as far as possible in your tight quarters.
Don't get a hair cut, just keep it clean.
And no chewing gum in line.
Don't figit when I'm talking to you.:cool: -
My HK runs hot hot hot so I had to arrange things to give it 6-8 inches of top space to let it breath, no prob now. I'd check out the temp for yours after its been running for a couple hours. If you find it too hot then, yes it is a big issue.
Also, no plans for an amp? -
where do you think i could get a cooling fan?Drumingman wrote:From looking at your pics, you really don't have a lot of room.
by the way thanks for your input! -
ok im not completly done...i do still need a amp...pop my bubbleErn Dog wrote:My HK runs hot hot hot so I had to arrange things to give it 6-8 inches of top space to let it breath, no prob now. I'd check out the temp for yours after its been running for a couple hours. If you find it too hot then, yes it is a big issue.
heat can cause your HK to turn itself off if to much heat builds up and it might go into protect mode. also, heat build up will shorten the life of the receiver. or it could fry it completely. why risk any of those?
nice looking system.
enjoyPolkFest 2012, who's going>?
Zero wrote:schmilnik,
I will give you the short answer here. Most amplifiers generate heat when they are in operation - some more than others. It is a general rule of thumb to give them space so the heat inside the chasis can escape. If you block off part of the vents and prevent that hot air from escaping... the unit can over-heat and things can get very nasty. Blown caps, burnt resistors, blown transistors,.. and a lot more stuff that falls under the "not fun" category. There is also a good chance HK would not cover this damage as to most manufactorers, your set-up may constitute as abuse.
I have a 335 running an Lsi system and despite the load... it runs warm, not hot. There is a chance that things will be fine as is considering how easy your speakers are to drive.... but I wouldn't chance it.
If you can't find a way to safely raise that glass by an inch or so - consider placing that HK elsewhere or as suggested, find a fan to keep things cool. You may find that noise to be distracting though.
hey where can i get this cooling fan?? thats really crazy my receiver just turned off half way into a movie -
schmilnik wrote:hey where can i get this cooling fan?? thats really crazy my receiver just turned off half way into a movie
that's really strange. i've never heard of that happening before. Hmmmmm? :rolleyes:
and get a hair cut.
danger boy wrote:that's really strange. i've never heard of that happening before. Hmmmmm? :rolleyes:
and get a hair cut.
Hahahaha. I read somewhere that there is a reason the entire top portion of a receiver chassis has all those slits.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
mutelight wrote:Hahahaha. I read somewhere that there is a reason the entire top portion of a receiver chassis has all those slits.
I didnt know there were so many asshloes on this forum espeacially from someone whos system doesnt even compare to mine and im 19 -
oh and by the way sick flame decal on your 360! YAH!
haha -
I agree with the fan idea. Nice rig though.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Try downloading and installing Sense of Humor v.1schmilnik wrote:why are you so bitter...cant get laid???
Sean,
Married and damn proud of it too...I even have a place of my own. How's the basement treatin' ya?
How's that shoe leather tasting.
Asshat. -
You guys are hilarious!
You aren't done man. I had an Rti system and thourhg I was done. I sold it all and blew the amount of money I paid on 6 speakers all into a two channel system.
You're never done, you're only addicted, stop trying to trick yourself into thinking it's going to be over.
You could upgrade that sub BTW, that would make music and movies alot more fun.
Oh yea, and I'm 18.... -
Frank Z wrote:Try downloading and installing Sense of Humor v.1
Sean,
Asshat.
asshat?? haha you are a **** idiot -
schmilnik wrote:I didnt know there were so many asshloes on this forum espeacially from someone whos system doesnt even compare to mine and im 19
You're 19? I would have never guessed. Grow up a little and smoke a little more reefer it might mellow you out. For a person who knows little to nothing about the hobby you made quite an "investment" and made quite a bold statement.
In response to your other post, (since you don't seem to even understand how to use the edit button on the forum) sick placement of your overpriced receiver, you'll destroy it in no time! YAH! Now go fall off a skateboard. Haha// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
Photo Gallery
I think it sucks :mad: J/Kschmilnik wrote:hey guys im finally done with my system, tell me what you think! Take a look--->http://www.polkaudio.com/forums/showcase/view.php?userid=72127
. You asked for opinions schmilnik. Be careful what you ask for. It sounds like you just wanted a pat on the back about the new gear.
Some people are trying to give you good advice (move the shelf or the 335 if you can).
Try to relax and have some fun. Keep acting hostile and see where it gets you.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
So what happen to your HK receiver after is shut off. DId it work fine the rest of the movie. Has it happen again? How loud were you playing the movie?
Do you think it was heat build up that shut it down?PolkFest 2012, who's going>?
danger boy wrote:So what happen to your HK receiver after is shut off. DId it work fine the rest of the movie. Has it happen again? How loud were you playing the movie?
It shut off and i turned it on again and everything was fine. And it has happened a few times. And I was playing it moderatly low. -
Definately do your self a favor and get it some more space. Unless you really want to have to replace it in that case then **** it your not done.Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects -
Because your receiver isn't getting proper ventilation. Adur. Please also don't say my system doesn't compare to yours because it doesn't, mine would make you wet your cargo pants and dribble down onto your vans. I guess mine is inferior in the sense I can play it at deafening levels without distortion without blowing tweeters and it stays on. :rolleyes:schmilnik wrote:It shut off and i turned it on again and everything was fine. And it has happened a few times. And I was playing it moderatly low.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
Photo Gallery
mutelight - Your SVS would eat his PSW505.
Well the route I took with my system is, of course I wanted good clean sound, but I am a film as well as a sound major and when I watch movies I want to watch them with gusto. Which is why I did my research and descided on the SVS and the Pioneer as the powerplant to start off because I felt it would be a robust entry level system that I wouldn't risk damaging in that application. I felt it was a good performance/price ratio. Both systems are stong in their own aspects but flat out saying that his is better? I thought people grew out of that by his age.Halo wrote:mutelight - Your SVS would eat his PSW505.
Photo Gallery
I agree i am planning on getting a svs in the future
