well im making a box....
OK... im going with the polk audio MM2154 15's in a seald box with a Profile AP2000 pumpin 320 watts to each sub at 4 ohm.
this is where i need help im ganna be droppin it in a 96 honda civic coup and i dont think there is enough room for the box specifications.
Width 19" (48.26cm) << per chamber...
Height 18-1/2" (46.99cm)
Depth 11-1/4" (28.57cm)
can i change that to....
width 17"
height 18"
Depth- 13-1/4"
or any combo like that:rolleyes: ??
width 17"
height 18"
Depth- 13-1/4"
Post edited by mirra540ryder on
0
its going to be 24 inches wide and 12 inches tall and 12 inches deep and a devider in the middle does this sound ok for 2 polk mono mm2124's??? its seald and really need to know by tommorow at about 3 cuz that is when im ganna start cutting. and uhh thats bout it. lol plz anybody tell me if they think im doing the right thing or what cuz i really have no idea what im going:eek: :eek: lol so plz help by then thanks
just a html ??
put the link in between those tags.
Sealed enclosure + caulk = acid fumes all up in that woofer.
Vr3Mods.com ///// Version3Audio.com
"No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
I doubt for your application you will notice a thing.
Being that you build boxes so often, what would you recomend instead?
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.php
Yah, where are the ports for the wires? He must have some type of small hole drilled in there to run just the speaker wire through...
1993 Honda Civic K20 swap
2004 Honda Pilot EX
I WANT TO BUY:
For the divider, you can put some polyfill(pillow stuffing) in each chamber. Put about 2 massive handfuls in the big side. Now put a good 4 handfuls in the small chamber. That should balance them out again. In reality, the difference in performanece between the two speakers will be more than that caused by the box.
Why is the divider only fastened on one side, maybe two?
You're digging up 6 year old threads to ask for pics? 26 to go, can hardly wait.....:rolleyes:
Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
