well im making a box....
mirra540ryder
OK... im going with the polk audio MM2154 15's in a seald box with a Profile AP2000 pumpin 320 watts to each sub at 4 ohm.
this is where i need help im ganna be droppin it in a 96 honda civic coup and i dont think there is enough room for the box specifications.
Width 19" (48.26cm) << per chamber...
Height 18-1/2" (46.99cm)
Depth 11-1/4" (28.57cm)
can i change that to....
width 17"
height 18"
Depth- 13-1/4"
or any combo like that:rolleyes: ??
width 17"
height 18"
Depth- 13-1/4"
Post edited by mirra540ryder on
ok i went out today and got 8-4 square foot thing of mfd wood or what not and some liquid nails and im ganna start tommorow with it. i decided to go with 2 12's instead of the 15's cuz 12's are not ganna make me go as deff as fast. im going with this lil plan i made.
its going to be 24 inches wide and 12 inches tall and 12 inches deep and a devider in the middle does this sound ok for 2 polk mono mm2124's??? its seald and really need to know by tommorow at about 3 cuz that is when im ganna start cutting. and uhh thats bout it. lol plz anybody tell me if they think im doing the right thing or what cuz i really have no idea what im going:eek: :eek: lol so plz help by then thanks -
never mind guys. i started my speaker box today its a dual 15" seald 1.5 cubic foot per chamber outa some bark i scraped off my tree in the back yard. but i was cuttin the wood and i was almost done and my saw went out so i was ganna try and finish it with a jig saw and it jamed so it was trash then i just decided to wait on a part for my saw so its put off til tommorow:(
lol no i was jp i am making it out of 3/4 mdf and im done i put it all together using a tube of liquid nails and 99 screws its all put together and i need to cut out the holes tommorow and i willl post a pic on here if somebody tells me how
just a html ?? -
[IMG][/IMG]
put the link in between those tags.cats.vans.bag... -
make sure you dont put a driver in there for like 2 weeks if you used caulk to seal the inside...
Sealed enclosure + caulk = acid fumes all up in that woofer.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
i just messured twice and i just got the worst results:(
my devider is to the right a half inch will that cause any thing???? i messured iwth a belt but still. its about one half to three fourths off... what kinda affect will that have. am i screwed?
Honestly...
I doubt for your application you will notice a thing.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
did you mean i wont notice a thing????:eek:
You wont notice anything...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
thang god. i was stressing.
I don't see any terminal cups. How are you going to get juice to the subs?
Vr3MxStyler2k3 wrote:make sure you dont put a driver in there for like 2 weeks if you used caulk to seal the inside...
Being that you build boxes so often, what would you recomend instead?1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
...waiting a week or two for the 100% silicone caulk to dry/cure.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Yeah, if you're going to wait for that to dry, you might as well spread some fiberglass resin inside of that. Seal up all those corners! You might be hittin so hard that those screws might loosen up. j/k
Yah, where are the ports for the wires? He must have some type of small hole drilled in there to run just the speaker wire through...1997 Toyota Supra TT
1993 Honda Civic K20 swap
2004 Honda Pilot EX
I WANT TO BUY: -
yea for now i just drilled a hole but im ganna put some in later
Resized your pics.
should i go with a ported box? i kinda want it to be louder. any ideas on how i would make one my self? im thinking making a seald box and then sticking a tube in it right
A ported box usually wants to be bigger, then you need to add the port. I don't think you can fit such a beast with two 15's.
For the divider, you can put some polyfill(pillow stuffing) in each chamber. Put about 2 massive handfuls in the big side. Now put a good 4 handfuls in the small chamber. That should balance them out again. In reality, the difference in performanece between the two speakers will be more than that caused by the box.
Why is the divider only fastened on one side, maybe two? -
Nice! Good luck
pics
jacks2start wrote: »pics
You're digging up 6 year old threads to ask for pics? 26 to go, can hardly wait.....:rolleyes:
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
