In-ground pool owners...
13
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2006
    Skynut wrote:
    They have not done the plaster yet.
    I guess they do the plaster and fill on the same day.
    Yes the interior plaster will not be done till the pool is ready to be filled, as soon as that is done the pool is filled, same day.
    BTW if local law requires fence or pool screen room around pool this will be added / completed first.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    They had to fix the fence and make the gate swing out.
    They said if the gate swings outward instead of inward then kids can not open it. I do not understand this logic at all. They don't care that I keep the gate locked.
    Plus we have to have alarms on any house door that leads to the backyard.
    Even though our kids know how to swim. My neighbor had to install alarms and there are no kids in the house.
    Gota love Cali.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2006
    Skynut wrote:
    Gota love Cali.
    that's what i was thinking before i read your statement.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Sami
    Sami Posts: 4,634
    edited August 2006
    Skynut wrote:
    You need the waterfall, that is to help the cooling of the pool as well as look nice.
    A 95 deg. pool is not real fun to swim in unless it is 65 deg outside.
    Depends on the size of the pool I guess. We have 100-110 degree weather in here and the pool temp is perfect, a little on the cold side actually when you get in. I have a large diving pool so there is a lot of water for the sun to heat.
  • disneyjoe7
    edited August 2006
    LOL,
    My last pool 8yrs ago we needed to door alarms, installed finial inspection then we removed. This new pool new laws no door alarms installed / removed. (We removed as these alarms would cause us to have sliding glass door closed all the time. We don't so they where disabled) This pool we needed like 35 holes drilled in the deck for a child proof fence installation, so this was installed for the finial inspection now it sits in the garage. That cost me $450 for a fence I don't use.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2006
    steve, you re-consider your stance on a jacuzzi? that would see year-'round use. pools only see a 3-4 month usage time. the rest of the time they lie dormant.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    Hot tubs are not fun in hot weather.
    Cold tubs are not fun in cold weather.
    So you need both. :D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2006
    i'd still make time for a jacuzzi in the hot arizona environment.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2006
    Nah. I had a very large Coleman spa before (5-person). Spa's do nothing for me. To think of the speakers I could have had with that $4,200 makes me cringe to this day, especially since my ex got to keep the spa. ****.
  • steveinaz
    edited August 2006
    Gota love Cali.
    Same in Arizona. minimum 5ft wall barrier/non-climable from your neighbors side of the barrier. All gates must swing out, have lock work 54" above the ground, yada yada. A 4" sphere must not be able to pass in any gate /barrier opening, etc. Alarms or 54" high-mount locks on all doors leading to pool. pool waterline must be minimum 4ft from property line, minimum 20" from any secondary barrier. Cover must be on when not in use, the list goes on and on..
  • Sami
    Sami Posts: 4,634
    edited August 2006
    In the winter, hot tub first then a swim in the cold pool. Repeat as necessary and then get a great good nights sleep...works for me. Sauna would be better but I'll have to wait a while before I build one.
  • steveinaz
    edited August 2006
    I got bored with my spa, it just became a pain and something else on my "to do" list...
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    I was with you till the cover part, no one has told me anything about a cover. In fact my neighbor had to buy a cover seprate.
    The cover traps heat. My neighbor uses his to get the pool warmer so if you "have" to have the cover on it will increase the temp of the pool.
    I also worry about my dog falling onto the cover and drowning.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • steveinaz
    edited August 2006
    Arizona cover thing is more about water conservation and evaporation. A covered pool evaporates much less.
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    Bummer about the water conservation deal.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2006
    i don't have a safety cover, but i do have a solar heating blanket. **** works! anyway, on a hot, non-humid day my water level can drop a full 3/4" from the surface a day (approx. 15,500 gallon pool) without a cover. it hardly drops at all with the cover on. for awhile there i though i had a serious leak in the piping somewhere! arizona sun for ya.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • disneyjoe7
    edited August 2006
    Hmmm,
    Pool Cover water conservation and evaporation to save water, the Water Fall is cause more evaporation then the pool water IMHO.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • szhleppy
    szhleppy Posts: 324
    edited August 2006
    BIZILL wrote:
    again, make sure the pool steps are set up so as not to allow the kreepy to become stuck.
    Hey Bill,
    Sounds like you have some problems with your kreepy??? I have the Polaris ATV, which has a reverse gear in case it gets stuck. The thing climbs walls and steps really well (always clean, and I don't sweep...only the pool guys who come once a week).
    I'm not saying this cleaner is any better than others out there, but I've been happy with it: pool is always clean, doesn't get stuck, and no maintenance or little "baggies" on it to clean.
  • steveinaz
    edited August 2006
    disneyjoe7 wrote:
    Hmmm,
    ...and its never enforced...it's a "feel good" law. Like the alarms and locks, they inspect once, you never see them again. The state requires the pool builders to provide a solar cover on a new build.
  • steveinaz
    edited August 2006
    Here's a pic of the layout in my teenie-tiny back yard. The bay window is our master bedroom, the wall on the right is 3ft wall off the patio, the wall on the left is the 4' wide x 71' long x 38" high retaining wall, and the square post is the first post on the 12 x 40 covered patio. The narrow end is 3.5' tapering quickly to 6' on the deep end:
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    That will be a nice pool.
    I like the bench in the deep end, I like how it is not sticking out into the deep end but is outside of the edge of the pool. I wish we had done that.
    Ours got cleaned out yesterday and is now waiting for the final inspection and plaster.
    I suppose I have to put up the stupid alarms now.
    I can't believe they do not have alarms that can be overidden from outside. We have to hear the alarm everytime we open the door from the outside.
    Total BS.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2006
    szhleppy wrote:
    Hey Bill,
    how much $? yes, my kreepy sucks, pun inteded. gets stuck every 30 minutes at least. so bad that i have to run the pump only when i'm at home otherwise it sits by the steps and wastes time and money. if i quit spending money on other ****, i could afford to purchase a new machine.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • venomclan
    venomclan Posts: 2,467
    edited August 2006
    Steve,
    Your pool looks a lot like mine, almost identical except by the bench on the deep end is the opposite side. Good luck.
    Venom
  • steveinaz
    edited August 2006
    Gracias, we're pretty damn excited. I'm scrambling now to get the gates, wall, doors, etc up to snuff; and redoing some landscaping to accomodate the waterfall feature. Can't wait til spring...
  • steveinaz
    edited August 2006
    I thought that was cool too. You don't lose any volume that way. Grant is a good designer, we worked with us before when we chickened-out on the first pool.
  • steveinaz
    edited August 2006
    GOOD information:
    http://www.poolsolutions.com
    http://www.poolforum.com
    Check out the "BBB" method....
  • disneyjoe7
    edited August 2006
    Steve,
    Looks nice, I know you will enjoy a pool I find it's makes the summers go easier ;) Also I would consider any future plumbing needs you may have now, I did and I worked out well my Electric for house and pump equipment is on the north side but future solar needed to be on the south side. Options where add solar piping under deck when built or add these pipes later across roof. I did the under deck thing and later added solar now my pool swimming time went from 4-5 months to 9-10 months.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2006
    Pools kill far more kids every year than guns do.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • shack
    shack Posts: 11,154
    edited August 2006
    steveinaz wrote:
    They'll start in late December with completion in early spring.
    Mine went in in 4 days. (fiberglass)
    Day 1 - Pool delivered and hole dug.
    Day 2 - Dropped in, leveled, pipes and fixtures attached, filled up with water and backfilled.
    Day 3 - Gravel base leveled, formed for concrete and poured and finished.
    Day 4 - Built small retaining wall and cut expansion joints, set up filter and pump.
    Landscaping at a later date.
    12 x 24 - 6500 gallons - run pump 24/7 at a cost of $50 per month - annual chemical and filter element cost $200-$250
    01.JPG 302.4K
    10.JPG 306.7K
    11.JPG 296.1K
    19.JPG 309.4K
    24.JPG 302.7K
    64.JPG 299.9K
    65.JPG 314.4K
  • disneyjoe7
    edited August 2006
    Hmmm, 24/7 pump run at $50 per month. I don't think so, I know my pump takes 9 to 10 amps to run at 240vac so my estimate is 14.2kw per day or about $1.50 a day... This is at 6hr pump running a day.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
