Should I have an airhole........
T_Unit616
Do I need an airhole in my sub box so it doesn't over-heat or anything?
Post edited by T_Unit616 on
What type of sub do you have? Give us some specifics here...
Typically I would not alter the design of any manufactured part without a thorough understanding of what your trying to do.
HBomb***WAREMTAE*** -
It is a Pioneer 400 Watt 12".
Like, I have an airhole in my box now, but should I seal it?
The airhole is not for cooling and its dimensions are designed for a certain amout of airflow. My subs are designed to actually allow the user to change the airflow and there are manufacturer guidlines in accomplishing this. Outside of that I would reccomend leaving "well enough alone".
Well, I have to subs and one of them is in a big hefty cardboard box! Lol yes very cheap but it pounds. The other is in a real box. For the cardboard one do I need the hole?
can you take some digital pics of your "Cardboard Sub" so some of the real experts on speaker design can chime in?
What kind of sub is made of cardboard? I just can't fathem that...
T_Unit616 wrote:Well, I have to subs and one of them is in a big hefty cardboard box! Lol yes very cheap but it pounds. The other is in a real box. For the cardboard one do I need the hole?
This is too funny.
PolkThug wrote:This is too funny.
I too am enjoying it but our new friend seems sincere...:D***WAREMTAE*** -
Shoot I don''t have my camera hear. Ok, try to envision this. There are handles on the sides right? covered one of them, and cut open the other prolly around 2 inches. Is it too big or do I need to cover it up to get more boom?
I know I know.....:D -
do you have a link you can share regarding the type of sub you have?***WAREMTAE***
Don't worry. I am getting a custom made box for it. Cardboard is temporary
HBombToo wrote:do you have a link you can share regarding the type of sub you have?
Ummmmm let me try to find one. It is an older kind of sub. -
This isn't mine, but it kinda looks like this. Letters are green, and imagine it older and used. http://www.strathfield.com/images/SimpleProducts/Medium/TSW306C.jpg
Oh my bad. I got it out of my garage. It is like a.....Amsoil?
If I knew what Amsoil was I may be able to draw some conclusions...***WAREMTAE***
Plus I ahve a problem with the Pioneer. It makes like a cracking, popping sound instead of bass. I am taking my amplifier back in like 30 minutes and getting a better one. I don't know what could be causing that sound though......
HBombToo wrote:If I knew what Amsoil was I may be able to draw some conclusions...
Lol....Amsoil....wait let me go give you the dimensions ans stuff. -
9 inches tall......14 inches wide......15 inches long
And it is Prime Oil.
if your sub has a hole.. don't plug it..
if your sub doesnt' have a hole.. don't make one.PolkFest 2012, who's going>?
It isn't the sub. It is the sub box.
This is beginning to sound like it should be in the automotive side of the house...***WAREMTAE***
Well it's trouble....
T_Unit616 wrote:Plus I ahve a problem with the Pioneer. It makes like a cracking, popping sound instead of bass. I am taking my amplifier back in like 30 minutes and getting a better one. I don't know what could be causing that sound though......
Your sub is toast. -
PolkThug wrote:Your sub is toast.
But here is the thing. I tried my other sub, it did the same thing. -
The other is Rockford something. 12". Doesn't tell me how many watts. A freind gave it to me.
