wire method for long sub run?
robertgray
robertgray Posts: 22
Currently have my PSW350 next to audio rack. Sub is hooked to Onkyo TX-SR600 via LFE. My turntable is picking up sub vibrations at higher volumes so I want to move sub across the room. This will be about a 25 foot run of wire. Can I continue to use LFE or is there another method I should use? If I should use another method, please describe. Thanks in advance.
Robert Gray
www.pamunkey.net
Onkyo TX-SR600 receiver
Polk CS245i center
Polk RT25i front and side surrounds
Bose Interaudio 2000 rear surround (Got one RT25i to round out my system? PM me.)
Polk PSW450 sub
plus........
Polk PSW350 sub
Post edited by robertgray on
  • trubluluc
    trubluluc Posts: 2,067
    edited October 2002
    I have a 25' run on my rear sub. using a monster LFE cable, and it works just fine.
    Use a decent cable and it should work well.
    -luc
  • mantis
    mantis Posts: 17,064
    edited October 2002
    You can purchase Line Level cable in bulk.Or order a custom premade one.Monster does make long sub cables.
    Dan
  • gidrah
    gidrah Posts: 3,049
    edited October 2002
    I've got a 6 meter Audioguest that suites me fine.
    Make it Funky! :)
  • scottvamp
    scottvamp Posts: 3,277
    edited October 2002
    YEP! Same here. Actually have two runs at 25'. Works great!
  • liv4fam
    liv4fam Posts: 311
    edited October 2002
    Use a quality cable like a Monster, straight, etc.. or you can custom make one yourself and buy some bulk wire from Transparent and solder your own ends them.
    Anything will be fine just as long as it is a 2 conducter with a drain wire.
    No coax, cat-5, romex, lampcord, blah blah blah.
    Have Fun
