Need help to get rid of spyware
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    Bump for me. :)
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Paul in Canada
    Paul in Canada Posts: 178
    edited June 2006
    I still can't get this crap off my computer. There is something on my C: called Defender25 that I can not delete and when I run ad-aware and spy-bot they can not fix command service and look 2 me. I'm having a hard time to type this message because of all the pop ups. Any help will be very appreicated.
    Polk RTi 8's
    Polk CSi 5
    FXIA4"s
    Outlaw Audio M200 x2
    Denon AVR 2805
    Sony CDP C345
    Paradigm PW2200 Sub
    Panasonic 50"
    "It's futile to have a battle of wits with an unarmed person." demaples July 29/08
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2006
    Format c:
    Then buy a MAC.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited June 2006
    This should do the trick for you. Let me know.
    Download AlcanShorty_en.exe
    to your desktop
    http://www.geekstogo.com/forum/index.php?act=dscript&CODE=showdetails&f_id=13
    double click the alcanShorty.exe file and follow prompts. It will make a folder on desktop called Alcan Shorty
    Open the folder & double click the run.bat
    This will download a file called BFU.exe and a BFU script. If your firewall asks for permission to connect then allow it
    a message box will pop up saying complete. Press OK
    Then BFU.exe will open.
    select the option to show log at completion
    Execute the script by clicking the Execute button.
    Note that you should see a progress bar while the script is being executed.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • Paul in Canada
    edited June 2006
    to your desktop
    Thanks for your suggestion. I tried what you said to do and it didn't work. I don't know if I even did it right or not, I'm not very good with computers. I did have a look at the Geeks to go site and they had step by step easy to follow instructions and I followed them and my computer seems to be working fine. Cheers to all the geeks out there. Before going to that site I ran scan after scan and the pop ups kept coming back, I wasted several hours over the last week trying to fix this mess. Thanks to eveyone who responded except for SCHWARCW. I'd put a Smiley Face here if I knew how.
    Polk RTi 8's
    Polk CSi 5
    FXIA4"s
    Denon AVR 2805
    Sony CDP C345
    Paradigm PW2200 Sub
    Panasonic 50"
  • honestaquarian
    honestaquarian Posts: 3,259
    edited June 2006
    Paul
    Did you try any of what i put in all my posts?
    Carlton
  • Paul in Canada
    edited June 2006
    Paul
    Carlton
    Yes your suggestions were also helpful and Major Geeks was also a good site. It seemed like different programs would catch some spyware but nothing would get everything. I am really not very familar with any of those programs and not very good with the computer so I really need some easy to follow detailed steps that I could follow. Thank you very much for taking the time to responed to my post and help me.
    Paul
    Polk RTi 8's
    Polk CSi 5
    FXIA4"s
    Denon AVR 2805
    Sony CDP C345
    Paradigm PW2200 Sub
    Panasonic 50"
  • honestaquarian
    edited June 2006
    Paul
    Paul
    Like i said ALL of the different antispy and antivirus programs have different blacklists.Which means they all look for different things.That is why you need more than one.You also must keep them updated with the latest definitions,because this crap is being created EVERY DAY!If you have any of the instant messenger services listed next to my handle then feel free to IM me.Or send me a private message and i will be happy to help you out.I have been where you are and had to largely learn all of this by myself.
    HATED IT!
    Carlton
  • honestaquarian
    edited June 2006
    Paul
    Also remember that Microsoft's Internet Explorer web browser(you know-the blue e that comes included in windows?)IS PART OF THE PROBLEM!!!Stop using Internet Explorer.Again read the information i posted previously.
