RT3000P Subwoofer Amp DIYS Project
Pstoll
I needed a plate amp to complete my DIYS subwoofer project so I bought a pair of RT3000P Sub amps on eBay, only needed one. I mounted a 12" NHT speaker in a Parasound cabinet and tried to hook up the speaker directly to the amp. Not good but no harm. I found the wiring diagram on this forum, many thanks, and discovered I need the volume control that plugs into the board so I don't over drive the NHT again. Does anyone know where I can get a couple of these precious volume controls? I am very impressed with the way these amps are made, heavy too. I just joined this forum and am thankful for the information posted.
Peter
Peter
Post edited by Pstoll on
Check with customer service, they may have a couple left.
The volume control is normaly located on the front of the speaker in the Polk logo.
Good luck and welcome to the forum.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I have two pm me your address and i will send them to you.
Now THERE is a nice guy.:DSkynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
bvette 94 you are truly a GEM. Seems I do not qualify for PM yet. Need 10 messages and I only have 1. Please let me know what I can do to obtain those critical controls. Is this a great site or what. My email is pstoll@san.rr.com. I look forward to hearing fromyoou.
Thanks!!!
Peter -
email sent
bvette94 wrote:I have two pm me your address and i will send them to you.
{ feeling warm and fuzzy inside}:DHT SYSTEM-
lsi 9's -
volume controls sent via usps. enjoy
What a godsend this forum is. Bvette94 the volume controls worked perfectly and now I can finally enjoy this great amp. Had it not been for you and the wiring diagrams I would have been lost and probably burned up more components. BTW the Eric at Polk scavenged a couple of pots for the system as well. Thanks Eric. I now have spares I would be happy to share with someone in need. Thanks to all!!
Peter
