RT3000P Subwoofer Amp DIYS Project
Pstoll
Pstoll Posts: 3
edited June 2006 in Troubleshooting
I needed a plate amp to complete my DIYS subwoofer project so I bought a pair of RT3000P Sub amps on eBay, only needed one. I mounted a 12" NHT speaker in a Parasound cabinet and tried to hook up the speaker directly to the amp. Not good but no harm. I found the wiring diagram on this forum, many thanks, and discovered I need the volume control that plugs into the board so I don't over drive the NHT again. Does anyone know where I can get a couple of these precious volume controls? I am very impressed with the way these amps are made, heavy too. I just joined this forum and am thankful for the information posted.
Peter
Post edited by Pstoll on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Check with customer service, they may have a couple left.
    The volume control is normaly located on the front of the speaker in the Polk logo.
    Good luck and welcome to the forum.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • bvette94
    bvette94 Posts: 356
    edited May 2006
    I have two pm me your address and i will send them to you.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Now THERE is a nice guy.:D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Pstoll
    Pstoll Posts: 3
    edited May 2006
    bvette 94 you are truly a GEM. Seems I do not qualify for PM yet. Need 10 messages and I only have 1. Please let me know what I can do to obtain those critical controls. Is this a great site or what. My email is pstoll@san.rr.com. I look forward to hearing fromyoou.
    Thanks!!!
    Peter
  • bvette94
    bvette94 Posts: 356
    edited May 2006
    tonyb Posts: 33,028
    edited May 2006
    Class act my friend,thanks for helping the man out.
    { feeling warm and fuzzy inside}:D
  • bvette94
    bvette94 Posts: 356
    edited May 2006
    volume controls sent via usps. enjoy
  • Pstoll
    Pstoll Posts: 3
    edited June 2006
    What a godsend this forum is. Bvette94 the volume controls worked perfectly and now I can finally enjoy this great amp. Had it not been for you and the wiring diagrams I would have been lost and probably burned up more components. BTW the Eric at Polk scavenged a couple of pots for the system as well. Thanks Eric. I now have spares I would be happy to share with someone in need. Thanks to all!!
    Peter
