The time is rapidly approaching........Sub options please....
1235
  • brettw22
    brettw22 Posts: 7,623
    edited April 2006
    Any other things I'm going to have to install as part of this thing?
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2006
    You have the wiring down, other than that I can't think of anything else. Where are you going to mount them. Do you have a board/rack already made for them?
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • brettw22
    edited April 2006
    I'm planning on mounting the 2 amps on the other side of the trunk from where the 400.4 is. The only problem is that the car jack is right there so I was thinking of some sort of hinged type of setup so I could access teh jack if I ever need it.
    I'm not going to prep anything until I have all of the pieces, but then I'm also going to try to build a sub box for the two things (yikes) so we'll see how well that goes over.
  • 1996blackmax
    edited April 2006
    Put put some shots when you get it going :).
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • brettw22
    edited April 2006
    Repeating what you said (I think) in English, I think you're requesting that I take some pics when I start the process......right?
  • exalted512
    exalted512 Posts: 10,734
    edited April 2006
    I think he means drink to a well done system
    -Cody
  • 1996blackmax
    edited April 2006
    Yes, please take some photographs for us.
    Yes, take some shots of some alcohol as well.
    Sorry, English is my second language.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • brettw22
    edited April 2006
    Now that I see you live in San Diego, I can understand this....;)
    I will slam the hardest beverage I drink (diet coke....lol) down once it's all complete.....and I'll take some pics.
    I was even gettin crazy and thinking that I could envision dynamat extreme-ing the inside of my car, but something scares me about wanting to rip apart the entire inside of my car.........
  • 1996blackmax
    edited April 2006
    I actually grew up in the San Francisco Bay Area ;).
    I hear you about the drink, I myself hardly drink alcohol. I prefer something that actually tastes good :D.
    Don't be afraid to rip apart the car. Just take your time doing it and you will be fine, or should I say, you car will be fine :). You may want to go with Second Skin for the sound deadening, very good product for less money than Dynamat Extreme.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited April 2006
    taking apart the trunk is hardly ripping apart your car. The sides are usually only held on by clips that can be pulled out by hand, and the bottom is of course your spare tire so its meant to be taken out
    -Cody
  • brettw22
    edited April 2006
    I meant the whole interior of the car. Seats, console, carpet, everything.......
    My interior was looking ok until chicago winter...........carpets are just looking worn and **** so I was thinking I might just replace the carpet. If I do that though, I'm going to dynamat (or whatever) the inside while I have everything torn out.....WHOLE different project than doing the trunk install (though I'll be having to go through the interior for the 1/0 gauge blah blah blah.
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    sounds like you got some hard work ahead of ya there
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • 1996blackmax
    edited April 2006
    Some pretty sore hands afterwards too....
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2006
    All the time youve spent with Russ and Mark over the years and thats the hardest you drink! I thought he had better powers of persuasion than that! ;)
  • brettw22
    edited April 2006
    Ok......how the hell do you cut 4 and the 1/0 gauge wires? I'm sure the hell not snipping with scissors, so what's type of tool is going to give you a clean cut of that stuff?
  • 1996blackmax
    edited April 2006
    I just used my wire cutters for my 4ga. I think it took a couple of bites.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • [Deleted User]
    [Deleted User] Posts: 763
    edited April 2006
    Here is how I do it. The tool is made by Wolfcraft and uses regular utility blades.
  • exalted512
    edited April 2006
    i use linesman pliers for 4 awg and 18" bolt cutters for 1/0
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2006
    i like josh's way best
  • 98thumpin
    edited April 2006
    a sawsall works quite well
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • brettw22
    edited April 2006
    Holy ****.........I could only imagine what a wire would end up looking like after meeting a sawsall.
  • brettw22
    edited April 2006
    The goodies have arrived..........now just waiting for the wiring and stuff to arrive so I can spend a few days getting everything built/installed and things should be fun..........(if I don't burn the car down somehow).
    MY TOYS!!!!!!
  • 1996blackmax
    edited April 2006
    It's always nice when you get new goodies :D.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited April 2006
    you might have mentioned it and i overlooked it, but where did you order them from? I didnt even know you could get them yet. In fact, I went on sounddomain yesterday to see if they had em and they didnt.
    -Cody
  • deepinya
    deepinya Posts: 199
    edited April 2006
    Isnt it the best feeling when new toys come to your home?
    My eyes light up like its Christmas!
  • brettw22
    edited April 2006
    Tweeter did me a HUGE favor and got them for me. They're shipping I believe in the next few weeks en masse....
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    You better seal that trunk up good. Those f'ers are gonna move a shitload of air. As I know you're more into SQ, I assume that you'll be going with a sealed enclosure, right?
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • brettw22
    edited April 2006
    That's the plan.......Neo's workin on a box design for me to start building......
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    That's gonna be a rockin' system. Can't wait to hear it when you come to Indy.
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    You're gonna have 500 watts going to each?
