momo vs db series
2
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2006
    Pawned? He pawned his box?
    As for the 400.4 bi-amping the Momos, that just aint the case. Now that is the only amp designed specifically to power the Momos but any 4 channel will work just fine as long as you have it crossed over properly.
  • howie777
    howie777 Posts: 357
    edited April 2006
    Just FYI this is from the MMC6500 manual
    "THIS INSTRUCTION IS ONLY FOR THE C400.4 POLK/MOMO AMPLIFIER. With all other amps, you MUST use the passive crossover network included with this product. Any other use will VOID THE WARRANTY."
    So if you skip the polk crossover network while using another brand 4 channel amp you void your warrenty. You can still do this, but polk wont cover damage if you amp somehow drops the filters and damage your tweeters. Just something to keep in mind.
    Howie
  • MacLeod
    edited April 2006
    Man, thats a little harsh.
    I can see the reason behind it cause Im sure there are a lot of dumbasses out there that would try to run tweeters down to 500 Hz but its still a little much.
  • exalted512
    exalted512 Posts: 10,735
    edited April 2006
    Not harsh at all IMO. Its to keep dumbasses from running speakers leads straight from their amps right to the speaker. Besides, if you know what youre doing you should never blow a speaker BECAUSE of bi-amping, it would be something else that was the culprit.
    -Cody
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    like wanting the speakers to get louder than they can
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • HiPerf360
    HiPerf360 Posts: 436
    edited April 2006
    If you know what you are doing you don't even pull the manual out of the plastic bag....
  • MacLeod
    edited April 2006
    Whats a manual?
  • exalted512
    edited April 2006
    macleod doesnt need no manual, he can build a box with only 4 sides!
    -Cody
  • MacLeod
    edited April 2006
    Go to the well much?
    You guys have really got to get some new material.
  • 98thumpin
    edited April 2006
    most boxes have six sides right.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • iworkfortweeter
    iworkfortweeter Posts: 53
    edited May 2006
    just cause i get awesome discounts on super high-end equipment doesn't mean that i go around buying subs just cause they say "polk" on the front. furthermore, if you like that sort of "noise" that is "rap" then go listen to it . otherwise blast some technical death metal and call yourself cool.
    currently in car:
    '00 Honda Accord LX V6
    AEM V2 cold air induction
    c400.4 amp powering a pair of momo 6500's
    and a pair of momo 6x9's
    alpine monoblock amp powering a jl w3 12''
    custom fab work for tweeters
    jl rca's, dist block and power/grounds
    alpine cda 9857 head
    three ground loop isolators
    ipod integration, all songs at 320kbs
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited May 2006
    Little late there? or looking for trouble?
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
    F1nut Posts: 51,809
    edited May 2006
    Hehe.......
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited May 2006
    I listen to rap and do not think that it's noise. It is not something I listen to alot, but sometimes when I am in the mood I throw one of my rap cd's in my player. I would not pay good money for my gear to listen to "noise". I actually do not like metal (never have), but just because I do not like it I would no call it noise. Just music that I do not enjoy.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
  • MacLeod
    edited May 2006
    Rap sucks and is not music. Its some dude talking about how tough and rich he is while somebody elses music is playing in the background.
  • exalted512
    edited May 2006
    like vanilla ice?
  • MacLeod
    edited May 2006
    Like any of them.
  • 1996blackmax
    edited May 2006
    I think the same about metal, at least that for me it sucks. I still believe it is music, just not the type I enjoy listening to. As for what you have said about rap, it just shows that you have no idea about what it is.... For me music is something that you listen to, and once in a while I enjoy listening to some rap. The only thing I really do not listen to is metal, and country.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • cam5860
    cam5860 Posts: 632
    edited May 2006
    I like some rap because of the beats they offer. But far as the lyrics it's completely ignorant. All they talk about is how much money there making and how they can rap better than other rappers.
  • MacLeod
    edited May 2006
    Except that heavy metal and country is actualy using instruments that are being played by musicians and then having a singer actually sing. Rap takes that music that was being played and samples it and then they talk over it. Poetry maybe, music no. Hell most rap I hear now doesnt even use those samples anymore. Its just deep big bass notes complete with some high hats. There is this restaurant I deliver to and the cooks in there are always listening to rap and all it is is BOOM tick tick tick BOOM with some dispshit saying the N word and "gansta" over and over again.
    Just because you listen to it doesnt mean its music. I listen to audio books, theyre not music and neither is rap.
    If you like rap thats cool, Im not saying you shouldnt listen to it and enjoy it. Just dont call it music.
  • 1996blackmax
    edited May 2006
    Well I do, just because you do not like it does not mean it is not ;).
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • MacLeod
    edited May 2006
    No it doesnt but the fact that nobody is playing any instruments or singing, and generally has no musical talent of any kind is what makes it not music.
    Its simply some dude talking over some electronically generated bass tones.
    Hell, I can download a tone generator, program it to play 40 Hz bombs and then start saying n*****, n*****, gangsta, gangsta. Does that mean I just wrote a song?
  • exalted512
    edited May 2006
    lol. I agree with both sides a little bit. While I dont think 'Lil Jon' is a musically enclined individual, there are a few good hip hop artists that I like. I do agree the rap/hip hop genre has a lot of crap in it, but if you listen to some of it, actually listen, a few of em actually do have meaning behind em. Every genre has their bad singers, rap/hip hop just seem to have more
    -Cody
  • 1996blackmax
    edited May 2006
    You hit it on the head Cody. I do believe rap has alot more crap to dig through though. Still does not mean that there is no talent there as Mac is stating.
    This statement "Hell, I can download a tone generator, program it to play 40 Hz bombs and then start saying n*****, n*****, gangsta, gangsta. Does that mean I just wrote a song?" just speaks volumes regarding his misunderstading of it. People could just say country is nothing more than whining, but it is alot more. Metal is just guitar noise, but again it's alot more. While I do not dig that music, I don't say it is not music. Country I can listen to at times.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
    F1nut Posts: 51,809
    edited May 2006
    Music: The art and science of combining vocal or instrumental sounds or tones in varying melody, harmony, rhythm and timbre, especially so as to form structurally complete and emotionally expressive compositions.
    As Mac pointed out, there is no singing or musical instruments in rap, therefore it is most decidedly not music.
  • 1996blackmax
    edited May 2006
    Your opinion....... Not mine.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
    F1nut Posts: 51,809
    edited May 2006
    Actually, Webster's. The latter is mine. :)
  • BOWLMAN
    BOWLMAN Posts: 47
    edited May 2006
    The older you get ,the more your mind opens up to different types of music.When your mood dictates,some music sounds better than others.
    Regardless of how it is made, it is all music.
  • exalted512
    edited May 2006
    "vocal or instrumental sounds or tones"
    It doesnt say anything about singing. There are country songs where they arent really singing, more just telling a story to background music. And if you call an electric guitar a musical instrument, a computer can most def. be classified as the same.
    -Cody
