momo vs db series
beardog03
beardog03 Posts: 5,550
okay, I got a stupid question...
why are momo`s better than db`s ?
Is it the power handling, or are they that much better sound wise..
do they sound way better , or just a little ?
told ya it was a stupid question..!! :D
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
«13
  • neomagus00
    neomagus00 Posts: 3,899
    edited February 2006
    they sound better - how much i can't particularly say - and they're louder...
  • beardog03
    I`m looking for SQ in my 325i/M3..
    I want to get rolling, but I can only get the db`s from my local CC, and have to order the momo`s at more cost..
    C400.4 is the amp, a C500.1 with one 10" momo sub, maybe a 12"...not sure yet
    I need to get off the fence and get busy soon though..
    I will be dynamating today, but want to get the amps installed also...
    brettw22`s install is the driving force behind all this lately...
    Thanks alot brett..!!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • PolkThug
    PolkThug Posts: 7,532
    There are great deals on Momo's on eBay.
  • beardog03
    That`s what I have been looking at , but I thought that was a bad thing to do..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • audiobliss
    audiobliss Posts: 12,518
    If you get a 400.4, 500.1, and a 10" or 12" MOMO sub, db speakers would be very out of place. (Not that they would stand out sound wise...the MOMO series speakers would just be a better match.) Yes they sound better. Yes they're better. And yes, if you're putting them in a BMW, they're worth it.
    Get the MMC6500!
    Just my .02
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • beardog03
    6500`s won`t fit..
    5.25`s in the front
    6x9`s in the rear deck....or I could put the 6500`s in the rear deck, but it`s just a little fill back there anyway..
    I thought about the 4x6`s in the rear
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • audiobliss
    Nah, don't put the MMC6500 in the back. Are you sure they won't fit up front? I would look into the possibility of making a spacer of sorts to make them fit. But if they still won't, go for the MMC5250.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • beardog03
    I also am flirting with the idea of using the two C300.2`s for the car and puting the 4ch in the truck..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    MacLeod Posts: 14,358
    The Momos are built better and more durable. They have a much better crossover as well and they sound a lot better. You get your moneys worth and then some.
    Ebay is a bad thing. Buy from an authorized retailer. Sounddomain.com is one of the best places to shop. They have the entire Polk line and you can get them with free shipping. Better yet, they are fully authorized so not only will you be supporting Polk but you also get Polk's full blessing and warranty and you can be assured of getting first line, new in the box equipment.
    The MMC5250 would be a great choice for the front speakers and the MMC690's are an excellent choice for the rear. I owned a set of the 690's for over a year and think they are the best sounding 6x9 on the market!
    Get the 5250 and the 690 and power them with the 400.4. Then if youre only wanting a single sub, the best match would be the MM2124SVC and a 300.2.
  • beardog03
    those are the speaks I will settle on..
    Mac know his ****..!
    Use the 4ch amp and not two 2ch amps....okay
    C300.2, not the C500.1 for the sub..
    What box should I use for the sub..?
    Is q-logic a good choice ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    Q Logic makes some good boxes but just make good and damn sure theyre not made from PLASTIC! Q Logic is famous for making plastic boxes so make sure its an MDF box.
    Another good option is to visit your local shop. They will have plenty of premade boxes of high quality thatll fit your needs and better yet, they could whip up a custom fit box for you for not much more than the price of a premade one. It wont be fancy fiberglass with neon and all but it would be built to snuggly fit in your ride and take up as little space as possible and I seriously doubt if itd run ya over $200.
  • MacLeod
    You could use the 500.1 for a 2124 but youd only be using half its power. Not that thats a bad thing, just that with a stereo amp you be getting more of your moneys worth.
  • beardog03
    thanks for the help Mac..
    I want SQ like you have..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • brettw22
    brettw22 Posts: 7,623
    For that you must go with SR's.... ;)
    They have the 5.25 size out now, don't they?
  • MacLeod
    Yup, they sure do! Anything doing is worth doing right! :D
  • beardog03
    my money is kinda funny right now though...
    2 1/2 times what the momo`s go for....I can`t wait that long..!
    I spend too much time commuting not to have good sounds...my roadrage might rear it`s ugly head..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    LOL!! I hear ya bro. Have no fear, those Momos are among the best speakers on the market. You will be satisfied.
  • beardog03
    the rear deck buzzing will be my biggest challange I think..
    I have two very large roll of sound deadener so far..
    I have two MM124`s, and was thinking about using one...will it blend well with the speaks you suggested..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    Yes. The older generation Momo's sound pretty much like the new ones. The biggest difference in the two was power handling. The MM1's were rated to handle considerably more power than the MM2's.
    Another good trick for the rear panel is to cut out a piece of 1/2"-3/4" MDF and mount it to the underside of the deck. This will increase the rigidity of it and also make a great mounting surface for the rear speakers and basically eliminate any vibrations from the panel to the speaker.
    If not, a liberal dose of Dynamat will work wonders too.
  • cam5860
    cam5860 Posts: 632
    I had the polk db series in my truck, before I upgraded to the momo series. The momo series is much better than the db series. They are much cleaner at high volume for one. They are twice as loud for two. The bass is a lot fuller and punchy for three. So pretty much everything is better than the db series.
  • audiobliss
    I love the MOMO logo on the MM124s!! Man...they look great. I don't see a problem with them blending in with your other stuff.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • iworkfortweeter
    iworkfortweeter Posts: 53
    edited April 2006
    momo subs aren't all that great.
    currently in car:
    '00 Honda Accord LX V6
    AEM V2 cold air induction
    c400.4 amp powering a pair of momo 6500's
    and a pair of momo 6x9's
    alpine monoblock amp powering a jl w3 12''
    custom fab work for tweeters
    jl rca's, dist block and power/grounds
    alpine cda 9857 head
    three ground loop isolators
    ipod integration, all songs at 320kbs
    F1nut Posts: 51,878
    edited April 2006
    Some might say that working for Tweeter isn't either.
  • Red230SX
    Red230SX Posts: 211
    edited April 2006
    iwork,
    I guess if what you are looking for is a sub that will pound out Rap music then
    I suppose the Momo's aren't for that... But some of us prefer more "Musical"
    music, with a bass line that is more than generated from a computer.
    For some of us the Momo's are just fine and dandy.
  • cam5860
    cam5860 Posts: 632
    edited April 2006
    Momo subs are nice subs for the money. There are better subs out there but they cost a lot more. You won't find a better sounding sub for a 100 bucks than the momo series.
  • Red230SX
    Red230SX Posts: 211
    edited April 2006
    cam,
    I can't argue with that... There are some small companies (non mainstream)
    that do make better subs but you have to be in the know, to even know who
    they are. My Home Theater sub for example uses a 12" aluminum cone driver
    (real machined aluminum, not aluminum plated plastic) and has 23mm of Linear
    One Way excursion (results via DUMAX) and I paid $140.00 for the driver.
    But it's from a company most people have never heard of :)
  • kenstewart
    kenstewart Posts: 139
    edited April 2006
    Another tip I just found out when I got my MMC5250s ... if you get the 400.4 amp, it says in the manual that is the ONLY amp that you can use with the MMC5250s to use as active crossover vice passive. I don't know all the advantages to that since I get all my help from these same guys answering your questions beardog, but I'm sure there are benefits of it. I'm sure some of these guys can chime in on that.
    Eclipse CD8445 HU
    Image Dynamics CXS54 Chameleons component setup
    Two 8" Image Dynamics ID8D2v.3 subs
    MTX MXA6001 amp for subs
    MTX MXA3002 2-channel amp for comps
    Accumat and Peel-n-Seal
    Stinger and Knukoncpetz wiring
  • neomagus00
    edited April 2006
    ken - the 400.4 the only amp that includes a built-in group of settings for polk speakers, but you can get any 4-channel amp to work under the right conditions
    red230 - out of curiosity...?
  • exalted512
    exalted512 Posts: 10,734
    edited April 2006
    you have fosgate subs in a prefab bandpass....nuff said
    -Cody
  • Red230SX
    Red230SX Posts: 211
    edited April 2006
    -Cody
    And where I come from we call that.... PwNeD! :D
