JL 500/5 amp
^^ Wow. That's seriously interesting. Amazing. This 'dark matter/dakr energy'...is that like black holes?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Thats String Theory. Its the leading candidate right now for a grand unified theory thatll explain everything.polkaudio sound quality competitor since 2005
Dark matter isnt black holes. They know black holes exist and have found a few. Dark matter is different and they dont know what it is.
If they take all the known matter in the universe it still wouldnt be enough to account for the gravitational effects we're seeing out there. Our own galaxy, if you took all the visible matter in it, would not be enough to keep the Milky Way together; way less than half actually. From what we can see, we should be flinging apart out into the universe. So obviously there is a lot more matter out there that we cant see but yet there is more of it than visible matter.polkaudio sound quality competitor since 2005
...wow. Isn't the world around us amazing?
*is in awe*
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
mac's pretty much hit it on the head...
unfortunately, no, black holes aren't it... black holes can actually be detected by a characteristic radiation pattern (stephen hawking recently showed that they actually 'evaporate')... the dark stuff is dark in every sense of the word... it's invisible and detectable in only one way - gravitational lensing... a good wikipedia article is here, but the gist of it is that matter bends light around it like a lens...
the canonical description of a massive body in space is to visualise a bowling ball on a sheet of rubber... the sheet of rubber bends a lot close to the ball, not so much the further away you go. now, start far away from the ball, and shoot a marble just to the outside of it... the marble will roll in a straight line until it nears the ball, then it will curve around the dip the ball has made in the rubber, then as it clears the dip, it will resume travel in a straight line... gravitational lensing around dark matter is the same thing, except the marble is a light wave, and the bowling ball is invisible
this is how they found the stuff... they saw the light bending, but there didn't seem to be anything there to make it bend! using precise measurements of the bending combined with accurate models of the motion of galaxies, you can actually reconstruct a map of the mass distribution in the universe, and it's totally mystifying, because we can only see bits and pieces of it...It's not good, very fundamentally simply not good. - geolemon
Dude, you have no idea. Thats what facinates me so much about astrophysics. Just trying to comprehend the size of our galaxy alone is staggering!!
Example:
The speed of light is 186,000 miles per second. You could orbit the earth 7 times in a single second at that speed.
The nearest start is Alpha Centuri and its 4 light years away. That means if you were traveling at the speed of light it would still take you 4 years to get to the NEAREST star.
Thats a single star yet there are billions of stars in the Milky Way which is several hundred thousand light years across. That means at the speed you could orbit the earth 7 times in 1 second, it would take you 200,000 years to cross the Milky Way!!!
The nearest galaxy, Andromeda, is 2,000,000 light years away!!!!!
There are billions of visible galaxies out there are grouped into clusters and there are billions of known clusters all billions of light years apart!polkaudio sound quality competitor since 2005
and that's why we use megaparsecs
1MPc = 3.32 million light-years, and the numbers are still incomprehensibly large... and yet, we also deal with scales down to 10^(-31) meters, the approximate length of the superstrings mac mentioned... It's not good, very fundamentally simply not good. - geolemon
What did I start......
And FWIW I don't subscribe to the "You can go forward but you can't go backwards"
theory. Most of this stuff is pure speculation and we have no way to prove most of it
yet. But if you can go forward then you get into quantum dimensionality which I am
not a beleiver of...
It sure is neat stuff to wrap the noodle around though...
Oh yeah, when I fire up my Line Array's for the first time, I think they are going to
create a magnetic field large enough to warp space time in a localized area!
is everyone in here a geniusesJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
^^ ROFLMREO!
Yeah, I think I'm....well...let's not go there....:p
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
im far from being a genesis soJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
"special"?audiobliss wrote:Yeah, I think I'm....well...
red230 - i hear ya on the speculation bit, that's why i qualified it with 'as far as we understand time and space'... pretty much all we know is that quantum bits are real things, not illusions, and that gravity is an **** for not bowing to our wishes and reuniting with the other forces... beyond that, strings, m-theory, and so on, it is all very 'theoretical'... like quantum dimensions (the 6 or 7 dimensions above and beyond our normal 3.5-4 dimensions), superstrings are just a way of describing the problem that yields the correct answer... doesn't mean it's the right way of describing the problem...
a good analogy i heard once:
an alien scientific task force decides to study earth, and the first phenomenon they hit on is a pro soccer game. these aliens, however, have the peculiar INability to see simple black and white patterns - their brain simply does not register them. so, the aliens study and study... they see the main players running in clumps and patterns, occasionally doing strange dances... sometimes one of the people at the goal will leap into the air, and half the crowd erupts each time this happens, but it's not always the same half of the crowd... they'll hear the occasional whistle, and the players will back up into some formation... so on and so forth...
so the big smart scientist aliens derive a huge set of complicated rules that perfectly describes every soccer game they've seen, and is completely correct from their point of view... then, one of the junior scientists proposes two radical things - that there is some particle that they cannot see, around which the game is focused, and that there is an invisible force governing some of the noises and patterns in the game... having postulated the existence of the ball and referee, they go back and re-analyse the game, and derive FIFA's rule book
in the same way, we are at the second step as far as quanta go, but probably very much at the first as far as superstrings go...It's not good, very fundamentally simply not good. - geolemon
you guys are very smart i give you all creditJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
oh god that was a dumb episode (the plastic block) -- lol.The Artist formerly known as PoweredByDodge
To quote Stephen Hawking who is smarter than all of us put together x10! "I dont believe time travel is possible. If it was, why havent we been visited by any time travelers then?"polkaudio sound quality competitor since 2005
Maybe we have and don't know it
. Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
you guys need **** alcohol.
and yes, we're all geniuses.The Artist formerly known as PoweredByDodge -
I have been tempted to go buy that 5L baby Heineken keg
. I do not drink very often, but thought about it for the Superbowl. Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
molson keg can.... 1/4 kegThe Artist formerly known as PoweredByDodge
Get ya a Warsteiner 5 liter keg. That REAL German beer right there!polkaudio sound quality competitor since 2005
My good friend was stationed in Germany and he said they are very serious about their beer
. Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
haven't you seen the Stewie movie? They're not allowed to disclose the truth.MacLeod wrote:"I dont believe time travel is possible. If it was, why havent we been visited by any time travelers then?"Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
family guy movie - retarded...
family guy show - awesome!It's not good, very fundamentally simply not good. - geolemon
MacLeod wrote:To quote Stephen Hawking who is smarter than all of us put together x10! "I dont believe time travel is possible. If it was, why havent we been visited by any time travelers then?"
We HAVE been visited! Look up John Titor on the net
Any guy that time travels in a Corvette has to be legit my friend! And I don't
care what Stephen says, I respect his opinion and I think he's a great guy and
I can listen to his speeches for hours.... But his opinion (however highly
educated it may be) is not fact.
Neo,
Cool analogy!
Some of us do need alcohol... I don't drink though! Make mine a diet Coke on
the Rocks!
yeah, i've read some of that titor guy, strange stuff...
of course, at this point, backwards time travel is totally up in the air, though leaning towards the side of impossible...It's not good, very fundamentally simply not good. - geolemon
I time travel every day or two
Go over to the music case, pull out something from the sixties and drop it in the player -
Crazy weather we are having huh?
deepinya wrote:Crazy weather we are having huh?
nope, not here
hiperf - very cool way of looking at it
I tried to build a time machine out of an old water heater but I ended up just loosing a finger.
While I was in the hospital I came up with this new approach...
To date I have lost no more appendages.
