SACD cable
kmartin971
kmartin971 Posts: 236
edited January 2006 in Speakers
What is the best cable available for sacd?
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Post edited by kmartin971 on
    F1nut Posts: 52,244
    edited January 2006
    You need to be MORE specific.
  • kmartin971
    edited January 2006
    SACD 5.1 for DVD player.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
    F1nut Posts: 52,244
    edited January 2006
    I think you meant 5.1 or at least I hope you did because there are no 6.1 SACD's. DVD-A's or DipDisc's. The best cables are the ones that sound good to you and fit your budget, which is how much?
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    There are 6 cables needed for sacd.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    F1nut Posts: 52,244
    edited January 2006
    Only if one wants to do a 5.1 set up. Otherwise only two are required for stereo SACD, which is much better anyway.
  • kmartin971
    edited January 2006
    If any knows what works best for SACD please offer suggestions. Ignore price for now.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2006
    Get a set of these, hook them up to your dvd & receiver & enjoy.
    http://www.bluejeanscable.com/store/6channel/index.htm
    Or you can get another kind of interconnects that strike your fancy.
  • shack
    shack Posts: 11,154
    edited January 2006
    There is NO SINGLE BEST analog interconnect for any given application. Interconnects are a matter of preference, how they sound to any given individual, how much they cost, etc...etc...etc... Some will have an opinion that the cheapest patch-cord that comes packed in a entry levels Sony CDP is fine while others will spend hundreds of dollars and swear they are worth every penny. Ask 40 people and you will probably get 38 different answers (some might actually agree). Try some...then try some different ones...until you are satisfied with the sound....then make up your own mind.
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
  • mldennison
    mldennison Posts: 307
    edited January 2006
    you dont need to buy specific SACD cables, you just need RCA audio interconnects for 5.1 SACD. like everyone else has said, there is no "best" cable out there. Blue Jeans Cable and Signal Cable make some very affordable but quality cables. Audioquest, Transparent, MIT and Kimber are some of the high end manufacturers that come to mind if you want to spend a little more.
  • crazy
    crazy Posts: 443
    edited January 2006
    I found this at Amazon...
    http://www.amazon.com/gp/product/B00022WNVU/sr=1-1/qid=1138638942/ref=pd_bbs_1/002-1165859-3563228?%5Fencoding=UTF8
    At $99, they seem really expensive compared to the earlier post
    http://www.bestbuy.com/site/olspage.jsp?skuId=4117887&type=product&productCategoryId=cat08053&id=1051384698663
    I would go with Best Buy
    Alternately, you could try Radio Shack - they seem to have good cables. Anyone's tried the Radio Shack brand of cables?
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    Raymond Cable on e-bay sells sets for $130.00. You can get RCA or XLR for this price.
    I have them and I like them.
    He will make them any length you need and they are well built.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    I agree with Skynut on the Raymond Cables. very well made high end cables. sound is really good too. You can find them listed on Ebay usually.
    If you need the phone number to Raymond Cable, let me know.
    Also, these Cobalt Cables are a good investment, but more money. Another very good sounding and well made multi channel cable.
    PolkFest 2012, who's going>?
    F1nut Posts: 52,244
    edited January 2006
    Ok, the best.....MIT Oracle V1.1, one meter cable is $4995.00 times 6 would be $29,970.00.
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    If you have a seprate amp. = $59940.00
    Add the Outlaw ICBM = $89910.00
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • shack
    shack Posts: 11,154
    edited January 2006
    Can you find these on E-bay any cheaper?
  • cfrizz
    edited January 2006
    WAAAAAA!! You guys are CRAZY!!! :rolleyes: :D
    Jeez all he needs are some flippen IC's! It's not rocket science, & there is no need to spend the equivilent of the national budget!
    Go to Radio Shack & pick some up & be done with it! :p:D
    F1nut Posts: 52,244
    edited January 2006
    I'm making a point here Cathy.
    Steve, WAAAAAAAAAAAAAAAAA
  • Toxis
    Toxis Posts: 5,116
    edited January 2006
    just use the ones that come in the box. :p
    I have Cobalt Cable in my system and love them. But the cables for my SACD are some old Tara Labs a friend gave me to get me by til I get more. Which I keep forgetting to do...
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    yeah i need to pick up 2 interconnects myself for 2ch. SACD.. good ones this time.
    btw- to get the true "hi-rez" fidelity can i hook it up to the receivers CD input (receivers bass management) or do I still hook it up to the "Multi-Channel Out" L&R?
    I've noticed when I hook it up on the regular aux. on the receiver you can degrade the signal by selecting DPL IIx and all that non-sense- yet it still plays the SACD layer.
    better bass management or a purer signal? hmm....
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
