SACD cable
kmartin971
What is the best cable available for sacd?
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
You need to be MORE specific.Political Correctness'.........defined
President of Club Polk -
SACD 5.1 for DVD player.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
I think you meant 5.1 or at least I hope you did because there are no 6.1 SACD's. DVD-A's or DipDisc's. The best cables are the ones that sound good to you and fit your budget, which is how much?Political Correctness'.........defined
There are 6 cables needed for sacd.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Skynut wrote:There are 6 cables needed for sacd.
Only if one wants to do a 5.1 set up. Otherwise only two are required for stereo SACD, which is much better anyway.Political Correctness'.........defined
If any knows what works best for SACD please offer suggestions. Ignore price for now.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Get a set of these, hook them up to your dvd & receiver & enjoy.
http://www.bluejeanscable.com/store/6channel/index.htm
Or you can get another kind of interconnects that strike your fancy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
There is NO SINGLE BEST analog interconnect for any given application. Interconnects are a matter of preference, how they sound to any given individual, how much they cost, etc...etc...etc... Some will have an opinion that the cheapest patch-cord that comes packed in a entry levels Sony CDP is fine while others will spend hundreds of dollars and swear they are worth every penny. Ask 40 people and you will probably get 38 different answers (some might actually agree). Try some...then try some different ones...until you are satisfied with the sound....then make up your own mind.kmartin971 wrote:If any knows what works best for SACD please offer suggestions. Ignore price for now."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Two packs of these and you're good to go...
http://www.bestbuy.com/site/olspage.jsp?skuId=4117887&type=product&productCategoryId=cat08053&id=1051384698663 -
you dont need to buy specific SACD cables, you just need RCA audio interconnects for 5.1 SACD. like everyone else has said, there is no "best" cable out there. Blue Jeans Cable and Signal Cable make some very affordable but quality cables. Audioquest, Transparent, MIT and Kimber are some of the high end manufacturers that come to mind if you want to spend a little more.
I found this at Amazon...
http://www.amazon.com/gp/product/B00022WNVU/sr=1-1/qid=1138638942/ref=pd_bbs_1/002-1165859-3563228?%5Fencoding=UTF8
At $99, they seem really expensive compared to the earlier post
I would go with Best Buy
Alternately, you could try Radio Shack - they seem to have good cables. Anyone's tried the Radio Shack brand of cables?Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes) -
Raymond Cable on e-bay sells sets for $130.00. You can get RCA or XLR for this price.
I have them and I like them.
He will make them any length you need and they are well built.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Skynut wrote:Raymond Cable on e-bay sells sets for $130.00. You can get RCA or XLR for this price.
I agree with Skynut on the Raymond Cables. very well made high end cables. sound is really good too. You can find them listed on Ebay usually.
If you need the phone number to Raymond Cable, let me know.
Also, these Cobalt Cables are a good investment, but more money. Another very good sounding and well made multi channel cable.PolkFest 2012, who's going>?
Ok, the best.....MIT Oracle V1.1, one meter cable is $4995.00 times 6 would be $29,970.00.Political Correctness'.........defined
F1nut wrote:Ok, the best.....MIT Oracle V1.1, one meter cable is $4995.00 times 6 would be $29,970.00.
If you have a seprate amp. = $59940.00
Add the Outlaw ICBM = $89910.00Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Can you find these on E-bay any cheaper?F1nut wrote:Ok, the best.....MIT Oracle V1.1, one meter cable is $4995.00 times 6 would be $29,970.00."Just because youre offended doesnt mean youre right." - Ricky Gervais
WAAAAAA!! You guys are CRAZY!!! :rolleyes:
Jeez all he needs are some flippen IC's! It's not rocket science, & there is no need to spend the equivilent of the national budget!
Go to Radio Shack & pick some up & be done with it!
I'm making a point here Cathy.
Steve, WAAAAAAAAAAAAAAAAAPolitical Correctness'.........defined
just use the ones that come in the box.
I have Cobalt Cable in my system and love them. But the cables for my SACD are some old Tara Labs a friend gave me to get me by til I get more. Which I keep forgetting to do...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
yeah i need to pick up 2 interconnects myself for 2ch. SACD.. good ones this time.
btw- to get the true "hi-rez" fidelity can i hook it up to the receivers CD input (receivers bass management) or do I still hook it up to the "Multi-Channel Out" L&R?
I've noticed when I hook it up on the regular aux. on the receiver you can degrade the signal by selecting DPL IIx and all that non-sense- yet it still plays the SACD layer.
better bass management or a purer signal? hmm....
